to convert from text to binary, you would do something along the following lines..
1. have the user enter a string.
2. loop through the string (for each char in stringEntered..)
3. convert the character to binary using the methods provided to you by your language of choice
For the reverse (binary to text):
you must take 8 bits of data (which would be a single character), and convert it to text using the methods provided by your language of choice..
To use Connection String, we have to set the
Connection String to a valid Connect String and then calling the Open method we
can open the Connection by passing the connection string as first argument. Now
a command object is created with Record set Open method that is given as argument.
Then command is executed by command.Execute
metod and resulting amswer is saved in recordset created.
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
Use ADO and create a connection string for a Jet file (version matters here when creating the string). Then use ADO commands and return recordsets to buffer your data.
A book shop maintains the inventory of books that are being sold at the shop. The list has details like author, title, price, publisher and stock position. Whenever a customer wants a book, the sales person inputs the title and author and the system searches the list and displays a suitable message if it is not available. If it is available, the system displays the book details and requests for the number of copies required. If the copies are available, the total cost of the copies requested is displayed, otherwise the message ‘copies not in stock’ is displayed. Design a system using a class called BOOKS with suitable member functions and constructors. Use new operator in constructors to allocate required memory space.
Use a compare (instr) command to search the sentence for punctution and spaces. Increment a variable for each word found, resetting the search string and retaining the start position of each find.
