Question about Miele Dishwashers
Miele dishwasher trips power switch
I have an old Miele dishwasher that has worked perfectly for years. However for no apparent reason it now keeps tripping the safety switch even when it's not switched on (just plugging it in is enough to trip the switch). The wiring in the house was redone professionally 2 years ago with a plug specific to the dishwashers power requirements put in place so I'm wondering is there some safety mechanism in the dishwasher that's causing the problem or is it simply just time to buy a new one.
watugot
  • 290 Answers
SOURCE: dishwasher is tripping off our safety switch
It depends on what kind of test he was doing. He was probably checking the amp draw which checks how much power the whole machine was pulling. This would be the way to check the problem you have as long as he checked it with everything running, motor, heater,..etc. If you find the amp draw to be too high, then you go to individual components.
Posted on Oct 05, 2007
  • 185 Answers
SOURCE: trip switch
is the dishwasher on its own circut breaker if so whats the size
Posted on Mar 28, 2008
SOURCE: my dishwasher when switched on keeps throwing the trip switch
have same problem with a dx6451 suspect either element or circulation pump any help out there
Posted on Apr 16, 2008
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Posted on May 22, 2008
bigg t
  • 640 Answers
SOURCE: Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Posted on Apr 11, 2009
How to fix leak in miele dish washer g1202 svi has F70 fault and small leak into catch pan
The reason the pump keeps running when F70 fualt appears is that the water leak circuit has tripped which causes the dishwasher controller to empty the dishwasher to avoid flooding of the motor and pump area.
The sources of leaks could be many, to start with hoses and water inlet valve. If you feel you can handle such repairs then go ahead otherwise call a technician.
Make sure the mains power is turned off when you are working with the dishwasher internals.
Aug 10, 2012 | Miele Dishwashers
Miele Advanta G2170 working fine 2 yrs, suddenly starts popping breakers and won't run (on any outlet) Electrical system in home is about 3 yrs old only.
Hi dear.If the washer is tripping circuit breaker,as long as you plug in,there is a Interference filter capacitor inside of the machine.Main power gets connect there first.It should be faulty & needs to be replaced.I hope that helps Thanks.
Aug 31, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Why is it dead?
Check power at the source; there could be a tripped breaker. If power is getting to your dishwasher, there may have been sudden failure of a part, such as the heater.
Apr 14, 2010 | GE Dishwashers
Have a hotpoint dishwasher full of little black
I have a Bosch SMS 4012 works fine till cycle finished. when I turn it off it trips the power safety switch at the switch board. To prevent trips happening I have to switch off at the power point and unplug .The washer is 20 years old and the problem started around 3 months ago.Is it a major problem.
Frank. C
Feb 15, 2010 | KitchenAid Dishwashers
My dishwasher keeps telling me F51 cannot find in the book what that means can you tell me please have cleaned all filters
On Miele F51 is pressure switch error.
The pressure switch is located in the drain system. Its function is determining if there is water inside the tub.
Trip the circuit breaker or disconnect the power cord for a couple of minutes. Inspect the drain system for blockage. The pressure switch can be tested by a technician bypassing it.
To get parts or repair service, call the number listed on the user manual.
Dec 19, 2009 | Miele Dishwashers
Miele G572 blowing circuit breaker near end of every cycle
first check you power box ..remove toe cover.. power box under front... check wire nuts ..make sure power is off... if nut are good you can check heater and door switch...if you have a meter
Sep 21, 2009 | Miele Premier-Plus Built-in Dishwasher
Circulation pump on my Miele dishwasher
Miele makes a special tool that you use to free up circulation pump.The price for that pump is about 800-900 dollars.Call miele and ask for that tool.
May 08, 2009 | Dishwashers
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Feb 22, 2008 | Dishwashers
My dishwasher when switched on keeps throwing the trip switch
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
27 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
