Question about Autotrol 263/740 Performa Logix Control Valve
Iron filter how to hook up
How do I time a bobbin hook on a 153W Singer
all sewing machines are basically the same, the hook that rotates to pick the cotton up off the needle must just enter behind the needle when it's on it's way back up which then grabs the cotton to form the stitch, so you must remove the sole plate to expose the shuttle case remove the shuttle and put to one side, now rotate the hand wheel on the sewing machine in the correct rotation and watch the hook rotate round until it goes behind the needle, just as the needle is starting back up from it's lowest position the hook should just be going behind the needle to pick up the cotton, if this is not the case then loosen the screws that clamp the hook assembly to the shaft and rotate the hook assembly gently until the hook is just going behind the needle and make sure the hook is close to the needle before retightening the clamping crews , and final give it a few turns by hand to make sure the hook locates the same all the time and the hook is not catching the needle, when your happy, then reassemble.
Happy sewing
Feb 16, 2015 | Singer Sewing Machines
How do i make a banded treble stitch please
  1. Yarn over hook three times, then insert hook into next stitch.
  2. Yarn over hook and draw yarn through stitch (there are five loops on the hook).
  3. Loop yarn over hook and draw through two loops (there are now four loops remaining on the hook).
  4. Yarn over hook and draw through two loops (there are now three loops remaining on the hook).
  5. Yarn over hook and draw through two loops (there are now two loops remaining on the hook).
  6. Again, loop yarn over hook and draw through the last two loops on the hook (there is now one loop remaining.)
  7. This completes one double treble crochet.
Jan 30, 2015 | PTAJ Marketing Crocheting Stitches
Where do springs hook on carburetor model 12s907-1411-b1?
ok, if this is the one you have? pay attention. their should be a small metal hook with a loop on top, hook the Z shaped end into the butterfly of the carb. the other end goes to the gov,plastic lever, sticking out..the bigger longer spring hooks to the speed ajustment lever hook the other end in the big loop on the hook. the small spring, hooks to a flat metal post sticking up. the other end hooks into the big loop as well.to keep everything from bouncing around
May 10, 2014 | Mtd 22" Yard Machine Push Mower
What is Kahle Snelled Hooks
The Eagle Claw Snelled Kahle Hook is a pre-snelled kahle style hook designed for live and cut baits when fishing in saltwater or freshwater. The snelled kahle hook, from Eagle Claw, are constructed around an offset, up-eye kahle hook which exhibits a wide bend that is ideal for using live, cut or prepared baits. The Kahle style hooks are preferred by some anglers due to their tendency to hook fish more securely. Highlighted by a wider gap, the Kahle hook design places the hook farther back in the fish's mouth to eliminate tearing out the lip. Because the Kahle hook's eye and point are on the same plane, the hook is much easier to remove. The hooks are pre-snelled with premium monofilament line offering an easy alternative to tying up your own snelled hooks. We offer the #147 Eagle Claw Snelled Kahle Hooks in ten sizes: 14, 12, 10, 8, 6, 4, 2, 1, 1/0 and 2/0. The hooks are bronze in color and come 6 per pack.
Feb 21, 2014 | Eagle Claw 147 Kahle Snelled Hooks
Hello, My bobbin thread was caught and as I was trying to get it out the hook system (I believe that is what it is) came out. How do I replace it?
You have a CB hook on your machine and this is very easy to remove and replace. In fact, you should remove the hook to clean the hook race and give it a drop of oil every few bobbins-worth of thread anyway, so if you're not doing that, your machine is probably trying to tell you something !!! I am assuming that the hook has simply dropped out of the mechanism and not that the whole hook and hook driver have come out, leaving a big hole in the hook race - if this has happened, you will need to replace the hook driver and its screw in the correct orientation, otherwise the machine timing will be out - if this is the case, you may be able to do the job yourself - contact me. Assuming it's just the hook, first-off, remove the bobbin/bobbin case from the central shaft on the hook. I am assuming the black plastic hook retainer has dropped-down and is laying on the bobbin door ... if not, you're in trouble !!! Rotate the handwheel on the machine until the needle is at the top of its travel. Look in the bobbin door at the hook race and you will see that the hook driver (a black plastic disc with a metal part curving round one edge) is positioned with the metal part on your left. Pick up the hook by the shaft and orientate it so that the metal is on the right - i.e. its a mirror to the hook driver. Carefully insert the hook into the hook race until it drops into the race itself and sits with the point downwards and a little bit of play between the hook and hook driver. It should stay there if there's a bit of oil in the hook race. You might like to use the opportunity to put one drop of Bernina oil into the hook race so that it flows into the groove that runs around the inside. Once the hook is sitting in the hook race, you only need to close the black plastic retainer onto it and press it until the lever on the left clicks into place firmly - that's probably why it dropped-out in the first place. Before putting the bobbin back in , just rotate the handwheel once to make sure nothing is binding - this will also distribute the oil if you've oiled it. Refit your bobbin/bobbin case, close the door and off you go.
Aug 13, 2011 | Bernina Virtuosa 160
There's no place on modem to hook router
Look for Ethernet jacks. You want to hook both your computer and your daughter's laptop to the router to out ports i.e. usually on the front side. The back side of router would hook using probably another Ethernet jack to your modem.
Jul 02, 2010 | Belkin (F5D7230-4) Router (587009)
RACE AND HOOK NOT ASSEMBLED CORRECTLY IN MACHINE 534FB
Turn the hand wheel until the hook race ON YOUR MACHINE is in the left position ...insert your hook ( semi circular hook) to the right side( jagged edge to the bottom)...insert the hook race cover ( circular, with the two jagged points facing inwards and in 12 o'clock position) and snap back the two hook retaining arms. Ready for inserting bobbin case. Good Luck
Apr 30, 2009 | Singer 8280 Mechanical Sewing Machine
Oil prablem
Remove the bobbin case.Snap the two retraining arms outwards.Remove the hook race cover and the hook. Oil on right hand side about 4 O'clock... 1-2 drops of oil.Turn the hand wheel until the hook race is in the left position...replace the hook...replace the hook race cover and snap back the two hook retaining arms. Good Luck
Feb 02, 2009 | Singer 1120 Mechanical Sewing Machine
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Autotrol 263/740 Performa Logix Control Valve Logo
241 people viewed this question
Top Autotrol Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Autotrol Heating and Cooling Expert? Answer questions, earn points and help others
