Question about Seiko Smart Label Printer 100 Thermal
My Smart Label Printer 100 starts printing then stops and turns off - just started this out of the blue
I have reinstalled the printer, and it continues to do the same thing -
SOURCE: I have a Smart Label 100 printer that won't print.
WHEN THIS HAPPENED TO ME, I DELETED THE PRINTED AND REINSTALLED IT...
Posted on Aug 20, 2009
  • 232 Answers
SOURCE: how do I export from outlook to my seiko 440 smart printer
I'm not familiar with this printer but usually you export details as a .csv file which you can import in to most other software packages. If you need more help, please can give more detail. Thanks :)
Posted on Dec 12, 2009
nicarta
  • 506 Answers
SOURCE: How do I set the printing preference for my smart
I guess you want to make this printer your default printer.
These are the steps
1 Click start then Printer and Fax
2 Locate the Printer you want set as the default Printer
3 Right click the computer and choice Set as Default Printer
this will set the printer to the preference printer.
Posted on Dec 30, 2009
rulds2008
  • 3866 Answers
SOURCE: My smart label printer 100
This skipping could be caused by a roller not turning causing the paper to be forced to much into the thermal.
Repair is quite difficult the unit would need to be taken apart and the feeder investigated. You could put some machine lube on the roller part, but its quite involved.
Another reason could be the module inside not working correctly causing it to print like it is.
If you update me with additional info I could be more of a help to you.
Regards,
Rulds2008
Posted on Jul 21, 2011
SOURCE: Smart LabelPrinter Seiko 440
These printers are designed to use only the labels with the ink bar on the back. the ink bar is the guide that tells how much to print.
Posted on Oct 24, 2011
How do I transfer saved labels from Smart Label Printer 100 to Smart Label Printer 620?
In the SmartLabel directory under Program Files look for a file named label.sll This file holds your SmartLabel 100 addresses. After installing your new SmartLabel printer, copy the label.sll file into the new SmartLabel directory under Program Files. When you open the SmartLabel software, if you don't see your addresses, you may have to use the Import command on the label.sll file to bring your addresses into your new SmartLabel Application
Feb 27, 2015 | Seiko Smart Label Printer 100 Thermal
Seiko smart label printer 100 not printing
A censor within the printer probably needs cleaning.
Apr 08, 2014 | Seiko Smart Label Printer 100 Thermal
Can Cymo lables be used in the Smart Label Printer 100
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
Feb 13, 2014 | Seiko Smart Label Printer 100 Thermal
Hi there I just got a new computer and try to copy the old smart label printer over, but when I try to print the label out, I got a message says.." SLP print manager can not start" What I...
when you say uyou copied the old printer over I assume you actually reinstalled the Printing Application from scratch?
You cannot just copy the seiko directry over, t doesnt load the .dll files
reinstall the application
biffo
Sep 08, 2011 | Seiko Smart 440 Thermal Label Printer
My smart label printer 100 is backing up at times when I try to print a label and doesn't print right, it skips letters or numbers and continues with the rest of the info. Like abcde will be abe
Regards,
Rulds2008
Jul 21, 2011 | Seiko Smart Label Printer 100 Thermal
After each label I print the printer automatically advances 3/4 of the way through the next label. Is there a setting to stop at the end of each label?
I don't know the particulat incantations for this printer, but it sounds like the "form length" or "label length" is not set correctly. Normally the printer will advance to the beginning of the next label once the printing is complete. Check the menu or setup program for the label length.
Let me know if you can not find this and I'll research the exact commands.
Thanks,
Dan
Aug 12, 2010 | Seiko Smart Label Printer 100 Thermal
Jan 16, 2009 | Seiko Smart Label Printer 100 Thermal
Printer working fine - when it stopped printing in mid of alabel♠
If reinstalling the drivers doesn't work... sadly I think it's time for a new one..!
Mar 30, 2017 | Seiko Instruments Smart Label Printer 430...
Hi, My Smart Label Printer 430 was working fine until I unplugged the back 2 cords to change the tape in it. How do I get it to print again?
unplug your Smart Label Printer (slp430) from your pc,
go into your control panel, then to add/remove programs.
remove the slp430 software then reboot your pc.
DONT PLUG IN YOUR SLP430 yet...
reinstall the software that came with the label printer.
follow on screen instructions.
plug power in for the printer
then attatch to your pc.
if this doesnt work let me know ; )
Jan 05, 2009 | Seiko Instruments Smart Label Printer 430...
Seiko Smart Label Printer 100 Thermal Logo
183 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
ray gallant
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
