Question about Tricity Bendix WDR1040W Front Load Washer / Dryer
Broken Programme Dial Knob on Tricity Bendix WDR1040W washing machine
The programme selector dial on my 10 year old washing machine broke so it spins freely and therefore the machine cannot be used at all. I have now resolved this - but wanted to post this so others can follow the fix, as when I spoke to Tricity Bendix/Electrolux, their only solution was to replace the whole machine for the sake of a snapped bit of plastic that I have now replaced for gbp7. So - to fix 1) Unplug the machine 2) Remove the top lid by removing 2 screws at the back of the lid 3) Remove the centre of the programme selector dial by reaching down behind the front panel with a screwdriver and release the two plastic tabs holding the centre of the dial into the outer ring. Pull out. 4) Remove the outer ring of the programme dial by undoing the metal nut on the front, then reaching down and release the 3 plastic tabs that hold it onto the front panel piece. 5) This outer dial was what was broken - it should have a ring of teeth and tabs in the centre on the back that fit into the yellow Cam wheel. 6) Purchase Part number 1248201004 as replacement. This is actually for machine CAW1010, but is physically the same part. Note the WDR1040W part number for the obsolete dial is 1321499301, but the number printed on both is 12477630 - this is the moulding number, not the part number I paid gbp6+VAT. 7) (While waiting for delivery, mark on the yellow cam wheel the programme positions you need, and turn it with a screwdriver to still use the machine) 8) The new part has the numbers printed in the wrong place - hold the old and new together and mark the numbers by hand ! 9) Refix the dial (it only goes on way round - align the larger tab in the centre ring with the gap in the yellow cam. Replace the nut, click the centre cap back in place et voila. Saved having to buy a new machine.
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: help me to wash!!
hi
    this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
cliff
Posted on Oct 16, 2007
barkencoa
  • 3463 Answers
SOURCE: washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Posted on Dec 12, 2008
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
SOURCE: what is the quickest wash cycle for the tricity
This is relating to the 2006 model.The times are not printed in most manuals like they used to but on this machine most probably the quickest prog. would be( 4 ) this is 3 rinses and a long spin at 40 deg. If you are experiencing long times on your washes do check that your water pressure is good as that will shorten the duration of all cycles and save on electric.
Hope this was helpful.
Good Luck
Posted on May 06, 2010
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Washing machine will not start
we had a very similar problem, our machine is only 12 months old and the filter at the bottom front of the machine has a small fan in it the filter was blocked with a coin blocking the fan from turning after reomoving the coin the fan was able to turn and the machine functioned correctly. hope this helps. tony
Jul 19, 2012 | Tricity Bendix AW1000W Front Load Washer
What is the quickest wash cycle for the tricity bendix wdr1040w front loader
Good Luck
May 04, 2010 | Tricity Bendix WDR1040W Front Load Washer...
Bendix Washer/Dryer WDB 1074T
Well well well - Welcome to the Bendix Club!
Here is the secret!
Push all 4 buttons in!
Turn on the Cold water only!
Set the first dial on 3 dots before the GREEN #12
Set the second dial to snow or cold
Set the third dial to one dot after the green 7....
If this doesnt work...the something is wrong with the machine!
Or email me.
Apr 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Tricity Bendix WDR1040W Front Load Washer / Dryer Logo
42 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
