Question about Lakewood HV-12-c Floor / Box Fan
NEED A MOTOR
Do you know where I can buy a motor?
I have a champion generator with a Briggs and Stratton 12 up motor that someone put antifreeze and oil in and it froze up is there anyway this can be fixed
the generator section is ok just motor needs to be repaired or replaced if you know how to rebuild a small motor can buy a rebuild kit but you might encounter internal damage cracks in blocks which would make a replacement motor more cost effective or depending on power needs might be cheaper to buy another unit compare costs of repair ,replacement or complete replacement
Aug 28, 2016 | Briggs Electrical Supplies
Broken motor mounts?
Would you not ask that question at an auto parts store
or go to an inline parts site?
Why not also install yourself?
I don't think a repair shop will appreciate you
walikg in with new parts as they loose the 20% or
more your trying to save.
On a Taurus you replace the motor & transaxle mounts
All of them,I think that is 3 in total.
Jan 21, 2013 | 1991 Ford Taurus
Chevy Aveo TIming Belt Broke, how do I get my car on the road??
buy a haynes or chilton repair manual for your vehicle it will show you what you need to expect to do for rebuilding engine $2000 from what you say will be a rebuilt motor not bad --since you state dont know how to rebuild a motor look at buying a donor car with a good motor our a junkyard --if you buy a crate that might be an option but priced higher than rebuild quote --the above options are better than you trying to rebuild your own motor with labor assistance and never done motor work before --first you would need the tools and equipment to remove the engine from the car --once out need to tear it down to see exactly what is damaged and needs to be replaced head and block will need to be sent out and checked $$ will need cams and crank also sent out $$ then full gasket kit --bearings- bolts -pistons-rings-valves-lifters-ect need to be bought and replaced so $2000 to get engine done not bad price and remember its in an 05 aveo what is the vehicle condition and worth verses repair --but buy the repair manuals first to review all options
Jun 08, 2017 | Cars & Trucks
No I need to know how to change fan motor freezer is fine.fridge on top is warm.fan motor not running.How do I get to it?
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 26, 2010 | GE GBS18KBP Bottom Freezer Refrigerator
Im buying a motor at the junk yard it has 98000 miles do i need to buy the odometer or just the icm so i know how many miles are on the motor im buying i dont want to have my old odometer reading since...
It is illegal to change the Cluster or modify the odometer reading , unless the mileage on the cluster in your car now is documented, the mileage and date of the new cluster when installed is also documented. You do not have to change the cluster just because you change the motor. The mileage only is there for the vehicle not for the engine. Hope this helps, Not sure if you were asking about the legal aspects. Cobra.. :-)
Jun 12, 2010 | 2002 Ford Explorer
I Need The Parts Breakdown For A GE Electric Motor 5KCR49TN2262Y
I check with our suppler that came up as N/A you may have to buy another unit. sorry I could'nt help
Oct 13, 2009 | Craftsman Air Tools & Compressors
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
I have a Kenmore series 80 that I bought it used two years ago, it now has a bad motor, it was manufactured in '96. I replaced the motor coupling a month ago. My question is, is it worth replacing the...
hello, i'ld say buying a new motor is far cheaper then buying a new unit unless the maching is in bad condition for a new motor your looking at anywere from 50.00-175.00$ depending on the model number of your machine. good luck on making your decision, and if you decide to buy the new motor and need help finding one let me know i can help you find the motor you need.
Mar 22, 2009 | Kenmore 24442
1993 Ford Probe needs motor mounts
is the model with the V6 mazda motor, if so it can be a bit difficult if you have little mechanical experience, but it is doable without removing the motor or transmission. we would allow 3 hours to complete the whole job.
Dec 23, 2008 | 1993 Ford Probe
Lakewood HV-12-c Floor / Box Fan Logo
44 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
