Question about Tricity Bendix WDR1040W Front Load Washer / Dryer
Broken programme dial knob - tricity bendix washing machine WDR1040W
The programme selector dial on my 10 year old washing machine broke so it spins freely and therefore the machine cannot be used at all. I have now resolved this - but wanted to post this so others can follow the fix, as when I spoke to Tricity Bendix/Electrolux, their only solution was to replace the whole machine for the sake of a snapped bit of plastic that I have now replaced for 7 pounds. So - to fix 1) Unplug the machine 2) Remove the top lid by removing 2 screws at the back of the lid 3) Remove the centre of the programme selector dial by reaching down behind the front panel with a screwdriver and release the two plastic tabs holding the centre of the dial into the outer ring. Pull out. 4) Remove the outer ring of the programme dial by undoing the metal nut on the front, then reaching down and release the 3 plastic tabs that hold it onto the front panel piece. 5) This outer dial was what was broken - it should have a ring of teeth and tabs in the centre on the back that fit into the yellow Cam wheel. 6) Purchase Part number 1248201004 as replacement. This is actually for machine CAW1010, but is physically the same part. Note the WDR1040W part number for the obsolete dial is 1321499301, but the number printed on both is 12477630 - this is the moulding number, not the part number. I paid 6 pound+VAT. 7) (While waiting for delivery, mark on the yellow cam wheel the programme positions you need, and turn it with a screwdriver to still use the machine) 8) The new part has the numbers printed in the wrong place - hold the old and new together and mark the numbers by hand ! 9) Refix the dial (it only goes on way round - align the larger tab in the centre ring with the gap in the yellow cam. Replace the nut, click the centre cap back in place et voila. Saved having to buy a new machine. 10) Don't forget to plug it back in before you shift the machine back under the worktop!
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
  • 86 Answers
SOURCE: tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Posted on Mar 18, 2009
beltronic205
  • 1474 Answers
SOURCE: tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Posted on Oct 31, 2009
SOURCE: what is the quickest wash cycle for the tricity
This is relating to the 2006 model.The times are not printed in most manuals like they used to but on this machine most probably the quickest prog. would be( 4 ) this is 3 rinses and a long spin at 40 deg. If you are experiencing long times on your washes do check that your water pressure is good as that will shorten the duration of all cycles and save on electric.
Hope this was helpful.
Good Luck
Posted on May 06, 2010
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Setting fast colours at 3 keeps jumping to 6
Ensure you are programming correctly check your instruction book. Some programmes will ignore your commands if they are not compatible.
Jul 24, 2014 | Tricity Bendix WDR1040W Front Load Washer...
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Load size dial won't set anymore, just spins freely
Most likely the knob is defective, order a new one.
Apr 25, 2017 | GE Profile WPRE6100G Top Load Washer
The fast spin cycle on my creda 1000 will only spin slowly,leaving clothes wet,any thoughts
This machine has a variable spin-speed setting. You can set the spin-speed RPM (between OFF and 1200RPM) using the smaller dial located next to the main wash programme selector dial.
I hope I'm not stating the obvious, but appliance "faults" are often simple and don't require taking the machine apart or calling a service engineer. If you've already tried the above suggestion and your washing machine is still spinning slowly, please post back and I will try to assist you further.
Regards,
BElectric
Nov 27, 2010 | Creda W100FW Front Load Washer
Tricity Bendix WDR1040W Front Load Washer / Dryer Logo
208 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
