Question about Garden
How do I replace the starter cord on my Troy Bilt mower
Model 11A-436M011
  • 1388 Answers
SOURCE: replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Jan 11, 2009
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 37 Answers
SOURCE: Need to know how to change the oil in my Honda
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Posted on Jun 06, 2009
I over tightened the blade on my mower so the pull cord is too tight how do i loosen it
If you used the pull cord to hold the shaft while you tightened the blade, you damaged something in the pull cord assembly.
Sep 05, 2014 | Troy-Bilt Troy Bilt Genuine Troybilt Mower...
Pull cord engaging
recoil clutch fingers are broken or stuck. Take the recoil cover off and look at it while pulling the cord to see if the fingers arent coming out. If the fingers are still coming out then you have worn out grooves on starter cone where fingers engage to turn the motor. If the recoil is damaged a new one can be purchased as a unit from Troy Bilt online for a reasonable price.
Jan 25, 2013 | Troy Bilt 5.5hp Self Propelled Mower
How do I replace the pull cord on the Troy Built Mower model # 12AI867Q011 serial # 1E098KC0419
You have two options. look up your models starter assy. at a dealer like www.arcolawn.com and replace it as a whole or purchase the rope remove the starter, charge the spring by twisting it all the way tight, back it off one turn and install the new rope. Tie your knots and reinstall the starter.
Thank you
Joe
Oct 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
What tool should i use to change the oil on a push Troy Bilt lawmmower Model 11A-439R766 XVS 6.5HP 190CC
The drain plug is made to fit the square end of a 3/8" wratchet extension.
Jun 14, 2010 | Garden
Lawn mower
Always start by checking the spark plug. If you are getting spark and still not starting, it's probably a carburator problem.
May 06, 2010 | Troy-Bilt Pony Garden Tiller
I have a TROY-BILT model 566 Smart Touch mulching mower. The starter pull cord (for lack of a better term) did not rewind when I tried to start the mower last weekend. I rewound the cord once by hand and...
sometimes these are shot dogs; these are what come and grap the engine and the cord is loose for about an inch or two and then you feel restance from the engine commpresion to start these DOGS are plastic and cheap
Apr 10, 2010 | Troy Garden
How to change the pull starter cord.
drill out rivets then re-rivet or use self tapping screws
Oct 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Need replacement belt guard for sovereign lawnmower
  1. Discount Troy Bilt Partsupstateoutdoorpowerequipment.com Save Up To 35% on Troy-BIlt Parts. Save Up To 35% on Troy-BIlt Parts.
  2. Troy-Bilt Partswww.partstree.com/troy_bilt_parts Need Troy-Bilt Parts? Look Up Parts and Diagrams for All Models.
  3. Troy Bilt PartsSearsPartsDirect.com
HERE IS THE ACTUAL PART YOU CAN BUY FROM EBAY!!!!!!!!!!!!
http://cgi.ebay.com/Troy-Bilt-NEW-Bumper%2FGuard-Attachment--Part-%2311045_W0QQitemZ280344217654QQcmdZViewItemQQimsxZ20090511?IMSfp=TL0905111310008r5209
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
253 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
