Question about Fujitsu 30CLX HALCYON Wall Mounted Mini Split Single Zone A/C Only 15 SEER -
Fujitsu aou30clx compressor location detection error
How to fix this unit not running
  • 96 Answers
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
Posted on Oct 20, 2013
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Fujitsu Air conditioner won't start after been off for 3 months
Knocking or hammering at the compressor is indicative of liquid refrigerant in the compressor. The compressor can't compress liquid. You'll need to call someone out to possibly evacuate and recharge the unit to remove the liquid in the compressor
Aug 09, 2016 | Fujitsu Heating & Cooling
How to fix Fujitsu a1 error code for 15rls2 heat pump.
Try cutting power to the indoor and outdoor units for a couple of minutes. Restore power and see if the error returns. The A1 error for this line of units indicates high compressor discharge temperature, which translates to overheating outdoor unit.
If this error code remains after a hard power reset, it's time to pick up the phone. Either you have a refrigerant leak which has resulted in a loss of freon, or a blockage in the refrigerant plumbing that is backing up pressure in the system. Both conditions will require a major repair by an authorized service tech to get your heat pump up and running again. 25361378-awph1b3yhxdrnyqdcrsrelkr-4-0.jpg
Please mark my answer as helpful.
Jan 09, 2015 | Fujitsu 15RLS2 Halcyon Wall Heat Pump Air...
Fujitsu heat pump error code for floor mount asta18lcc.
if they both flash 5 times it means Compressor Failure. Not a great fault to have. could either be the inverter board or could be a stuffed compressor
May 26, 2014 | Heating & Cooling
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
I have a fujitsu AOTR30LCT, when turned on the green timer light and the red power light blink 3 times. Only the fan works and does not cool.
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Jan 24, 2011 | Fujitsu Heating & Cooling
Fujitsu Air Conditioning split unit Model
Your compressor is seized up. shut down unit and let compressor cool down, it may start again but probably needs to be replaced.... sorry for the bad news,
Nov 10, 2009 | Fujitsu 24C1 Air Conditioner
3 Compressor in 6 years. Is this normal? As a consummer iam left with no warranty and support...
Multi-Compressor Failures
1st time a compressor fails the service tech is suppose to determine the cause of the
Failure and fix it. Is it no oil return or oil being washed out of compressor do to low sump superheat,
liquid slugging do to thermostatic expansion valve or orifice flooding compressor,starving
for refrigerant do to thermostatic expansion valve or orifice not supplying enough refrigerant to keep the compressor cool, or is the reversing valve shifting properly or electrical,such as bad defrost board, capacitor,relay or electric component or connection, etc.
With multi-compressor failures until you determine the cause and fix it you will keep having this problem
And when a heat pump compressor fails if it’s a burn out, such as electric short or long running at high temperatures and pressures or low on refrigerant level not enough cooling back to the compressor, Causing the refrigerant to break down and create an acid. You need to check the oil in the bad compressor to see if there’s acid in it, then replace the compressor, reversing valve, accumulator (the oil and contaminents will accumulate here and you can‘t get it out), thermostatic expansion valve or orifice, liquid drier, suction line filter drier (if it’s on the lineset outside of the unit then you need to put it inside the unit as close to the compressor as possible).
And after running the system for a couple of days, then the liquid drier and suction filter should be replaced again, depending on how bad the burnt out was or if there‘s acid still in the system you might need to replace them again.
It’s hard to say who would be responsible but there’s something other than the compressor causing the problem and you need to find out what it is.
Apr 20, 2009 | Heating & Cooling
Fujitsu 30CLX HALCYON Wall Mounted Mini Split Single Zone A/C Only 15 SEER - Logo
458 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
