Tan^5xdx integrate the function by evaluating
Can anybody tell how does the value 8.66 occurred? Tell me from S.. Whats that arc?
It's arcus sinus, which, as opposed to the sinus function, returns the angle.
For example:
sin 30 = 1/2
arc sin 1/2 = 30 deg.
If you want to use a scientific calculator to evaluate your calculations, please make sure to use degrees. These calculators usually have 3 settings: deg (degrees), rad (radians), grad (gradius).
Arc sin, arc cos, atan actg are often referred to sin-1, cos-1 tan-1 ctg-1.
Nov 27, 2015 | Cars & Trucks
How to put infinity limit in fx-991ms calculator
You cannot. Just put a number that is large enough so as to minimize the error in the evaluation of an integral. You must have an idea how the function behaves for large argument.
May 12, 2014 | Casio Office Equipment & Supplies
Only one button which is used for integration/differentiation is not responding
I am not sure what you mean. The key allows yous to calculate the definite integral of function which you enter on the command line. You must also enter the lower and upper limits. When used do differentiate, you must enter the function, and specify the point at which the first derivative is evaluated. Try the two features with simple functions to test whether the calculator is working.
Jan 14, 2014 | Casio Fx-991es Scientific Calculator
Where is the rear window defrost fuse located and what color is it for a 2006 Ford Taurus?
A combination fuse and circuit breaker panel (called the fuse junction panel) and is under the steering column. Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 - - Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 - - Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 - - Battery Saver Relay 35 - - Driver Unlock Relay 36 - - Rear Defrost Relay 37 - - Interior Lamp Relay 38 - - Driver Power Window Relay (One Touch Down) 39 - - Accessory Delay Relay Since rear defrost is a relay, not a fuse, you're looking for a big black square that plugs into the board with three prongs. If it rattles when you shake it, it's probably bad.
Oct 24, 2013 | COATES HEATER FUSE F3 SC30 30A480V...
How can i solve integrals with ALGEBRA FX 2.0 PLUS
The syntax for the evaluation of definite integrals (integrals with boundary limits) is as shown on the screen capture below.
$ (function , variable , lower bound, upper bound)
By default the name of the dummy variable is x. If you use another name, the variable must appear as an argument of the function, and as variable.
Mar 13, 2012 | Casio Algebra FX 2.0 Calculator
Whenever the command expand, diff or integrate are use it comes up with wrong argument. I have tried to clear all variables and default the set up but to no avail.
I believe you are using the wrong syntax for the commands.
diff ( function, variable) Example: diff (sin(x^2), x) sgould give you 2.x.cos(x^2)
expand( will expand an expression that has parentheses: expand( (a+b)^2) will give a^2+2a.b+b^2
Integrate $
$ ( tan^-1(x), x) willl give x.tan^-1(x) -(1/2) ln ('x^2+1')
Check the syntax of a command before using it. You will find the list of all comands and their syntax in the reference manual.
Aug 22, 2011 | Casio ClassPad 300 Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
How to solve for the trigonometric functions in the casio scientific calculator?
Press the relevant function key [SIN],[COS],[TAN] followed by the angle value.
For inverse trigonometric functions [SIN^-1], COS^-1], or [TAN^-1], Press [SHIFT][SIN], [SHIFT][COS], or [SHIFT][TAN].
For other functions
sec(x)=1/cos(x)
csc(x)=1/sin(x)
cot(x)=1/tan(x)
When calculating trigonometric functions one must make sure that the angle unit the calculator is using is the correct one.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
Why the cos of 90 is -0.44... ?? and the tan sin its'nt correct in the calculator what can i do ?
The trigonometric function evaluations depend on the angle unit you are using: degree, radian, grad
While cos(90 deg)= 0,
cos(90 rad )=cos(90* 180/pi degrees)= -.448073616
ALWAYS CHECK UNITS before using trigonometric functions or their inverse functions.
May 13, 2010 | Casio FX-7400G Plus Calculator
Dont have a owners manuel so i dont know what the fuse numbers are 93 ford taurus
1996 is all I have. Look on back of cover for fuse chart.
Location
The fuse junction panel is located to the left of the steering column. To expose the fuse junction panel, remove the fuse panel cover (14A003) as outlined.
Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 — — Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 — — Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 — — Battery Saver Relay 35 — — Driver Unlock Relay 36 — — Rear Defrost Relay 37 — — Interior Lamp Relay 38 — — Driver Power Window Relay (One Touch Down) 39 — — Accessory Delay Relay
Apr 09, 2009 | 1993 Ford Taurus
18 people viewed this question
k24674
jasbo
jasbo
