Question about Vehicle Parts & Accessories
Trying to find out where the tan and white wire goes
    Filmmaker:
    Uploaded 5 video answers.
  • 112 Answers
That looks like a 12 volt lead to an oil pressure sensor or electric choke
Posted on Apr 18, 2013
Identifix not showing color wiring harness for power coming from o2 sensor to ECM on 2003 G3500 6.0
Which O2 sensor ? There are four , Bank 1 sensor 1 Purple / white stripe an Tan . Bank 1 sensor 2 tan/white an PPL/ white Bank 2 sensor 1 PPL an Tan Bank 2 sensor 2 Tan an PPL .
May 18, 2016 | Cars & Trucks
I have 3 black, 1 tan, 1 gray wireing from ceiling. I have a wall switch that controls 2 ceiling fans in a mobile home . i want to connect a new ceiling fan that has 1 black, 1 white, 1 blue wireing.
The gray tan and the other wires usually have plug on the end and the plug into the fan unit when it's put together . The part the mounts to the ceiling should be blue black and white
Aug 28, 2014 | Cars & Trucks
Which wire does what on the IAT/MAS trying to find which ones go to IAT on a 2004 yukon 5.3
black/white goes to ground
black is ref DC from the PCM for the IAT
Tan is the IAT signal to the PCM
Pink is 12 volt power to the MAF sensor
Yellow is the MAF signal to the PCM
Oct 25, 2010 | 2004 GMC Yukon
I bought a replacement Dayton electric condenser fan motor. The original GE had 3 wires. L1 L2 & the fan capacitor wire. The Dayton replacement model 4MB21 has 4 wires, L1 L2 and 2 capacitor wires tan...
The tan/white wire can be insulated/capped and not used. Use and ohmmeter to take a resistance reading between the tan/white wire and L1 & L2. There will be no resistance between the tan/white wire and one of the others. This will be the common wire. Connect it to one side of the contactor. Connect the tan wire to the fan terminal on the contactor and the other wire to the common terminal on the capacitor (that is if you have a 3 terminal capacitor, if you have a 2 terminal capacitor connect tan to one side and the other wire to the other). Then connect the other side of the contactor to the common terminal on the capacitor (on a 2 terminal capacitor connect the contactor to the side that doesn't have the tan wire on it).
Aug 16, 2010 | GE Heating & Cooling
Original AC Condenser fan motor had three wires L1 L2 & Fan Capacitor The replacement Dayton motor has 4 wires, L1 L2 & 2 capacitor wires solid tan and tan with white tracer One goes to the F...
Yes, that can be confusing...hook the tan wire with the white strip onto the same line wire as the one going to the capacitor...usually the L2 wire....so then in reality you have the two tan wires hooked onto the common and the F terminals of the cap...
heatman101
Aug 15, 2010 | GE Heating & Cooling
1997 Jeep wrangler rear emergency brake cable replaced and now brake light stays on
possible cable out of adjustment to loose.try forcing brake aplicator towards full off and see if it goes off. if so adjust switch or cable
Jun 26, 2010 | 1997 Jeep Wrangler
Wiring problem
It goes:
Tan/white (wire closest to the spark plug)
Purple/white
black/red
tan/black (furthest from the spark plug)
Dec 01, 2009 | 1993 Chevrolet S-10
What is the color code for the stereo wires in an 08 land rover l
Battery BROWN/LIGHT GREEN(+)IGNITION SWITCH HARNESS
Ignition 1 WHITE (-) IGNITION SWITCH HARNESS
Accessory 1 WHITE/PINK (-) IGNITION SWITCH HARNESS
Starter 1 WHITE/RED (-) IGNITION SWITCH HARNESS
Tachometer WHITE (-) AT IGNITION COIL
Speed Sense YELLOW/GREEN (AC) AT MODULE UNDER PASSENGER SEAT
Parking Lights ORANGE/RED (-) AT MODULE UNDER PASSENGER SEAT
Brake Lights GREEN/BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock BLACK (-) AT MOTOR IN DRIVERS DOOR
PowerLock BLUE (-) AT MOTOR IN DRIVERS DOOR
All Door Trigger VIOLET/GRAY (-) IN HARNESS TO RIGHT OF STEERING COLUMN
Trunk Trigger VIOLET/YELLOW (-) AT MODULE UNDER PASSENGER SEAT
Hood Trigger VIOLET/WHITE (-) AT MODULE UNDER PASSENGER SEAT
Headlights-Lo BLUE (-) AT MODULE UNDER PASSENGER SEAT
Wipers-Lo PINK/LIGHT GREEN(-) AT MODULE UNDER PASSENGER SEAT
Trnk Release WHITE (-) AT TRUNK RELEASE SWITCH
Battery RED/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Ground TAN (-) RADIO HARNESS
Illumination GRAY/BLUE (+) RADIO HARNESS
LF Speaker (+) BLUE/WHITE
LF Speaker (-) TAN/WHITE
RF Speaker (+) RED
RF Speaker (-) TAN/RED
LR Speaker (+) RED/GREEN
LR Speaker (-) TAN/GREEN
RR Speaker (+) BLUE
RR Speaker (-) TAN/BLUE
Radio Security YES
(thats for 07 but shoe to what u need)
Aug 24, 2009 | Alpine Car Audio & Video
Im installing a new sterio in a 95 mustang ----i need a colour code dia. of the wires on the old factory sterio. Which wire goes where?
A Right Rear Spkr (-) Dark Brown w/ Pink Stripe Purple w/ Black Stripe
B Right Rear Spkr (+) Tan w/ Green Stripe Purple
C Right Front Spkr (-) Green w/ Orange Stripe Gray w/ Black Stripe
D Right Front Spkr (+) White / Green Stripe Gray
E Left Rear Spkr (-) Tan w/ Yellow Stripe Green w/ Black Stripe
F Left Rear Spkr (+) Tan w/ White Stripe Green
G Left Front Spkr (-) Lite Blue w/ White Stripe White w/ Black Stripe
H Left Front Spkr (+) Orange w/ Green Stripe White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black w/ Green Stripe Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Thin Black Wire Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Green w/ Black Stripe Yellow
Jun 17, 2009 | 1995 Ford Mustang
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
