Question about Microsoft MS OFFICE 2007 SBE MLK (NA) SW. (RZ365A#ABA)
HOW DO I INSERT OR DELETE THE COLUMS BASED ON CELL VALUE
I HAVE EXCELL SHEET IN WHICH I HAVE GIVEN FORMULAS IN COLUMN ''B'' SAME WILL BE COPIED FOR 5 COLUMN, C,D,E,F & G
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
If you want the result of your formula in colum "B" to be appeared in 5 others column, simply put new formula in the other colum with syntax "=CELLID".
i.e:
put "=B1" (withoud quote) in cell C1, D1, E1, F1 and G1. do the same for the others cell, or just drag your cell to the bottom of page. it will copy your formula automatically.
If that not what you want, please update ypur question with more understandable phrase...thank you
Posted on Mar 11, 2009
How do I check that I have copied the formula to a new cell?
Click on the column-heading to select the entire column.
Right-mouse-click to select "copy".
Move the mouse-pointer to where you want the copy to appear.
Right-mouse-click and choose "insert copied cells".
Sep 16, 2014 | Microsoft 1994 Office Excel Spreadsheet...
Tip
Microsoft Shortcut keys for Microsoft Excel
Here's what you are looking for. Browse it and you can find it there all you want for shortcut keys. Follow this link below:
Microsoft Excel Shortcut keys
Enter data by using shortcut keysToPress
Complete a cell entryENTERCancel a cell entryESCRepeat the last actionF4 or CTRL+YStart a new line in the same cellALT+ENTERDelete the character to the left of the insertion point, or delete the selectionBACKSPACEDelete the character to the right of the insertion point, or delete the selectionDELETEDelete text to the end of the lineCTRL+DELETEMove one character up, down, left, or rightArrow keysMove to the beginning of the lineHOMEEdit a cell commentSHIFT+F2Create names from row and column labelsCTRL+SHIFT+F3Fill downCTRL+DFill to the rightCTRL+RFill the selected cell range with the current entryCTRL+ENTERComplete a cell entry and move down in the selectionENTERComplete a cell entry and move up in the selectionSHIFT+ENTERComplete a cell entry and move to the right in the selectionTABComplete a cell entry and move to the left in the selectionSHIFT+TABWork in cells or the formula bar by using shortcut keysToPressStart a formula= (EQUAL SIGN)Cancel an entry in the cell or formula barESCEdit the active cellF2Edit the active cell and then clear it, or delete the preceding character in the active cell as you edit the cell contentsBACKSPACEPaste a name into a formulaF3Define a nameCTRL+F3Calculate all sheets in all open workbooksF9 Calculate the active worksheetSHIFT+F9Insert the AutoSum formulaALT+= (EQUAL SIGN)Enter the dateCTRL+; (SEMICOLON)Enter the timeCTRL+SHIFT+: (COLON)Insert a hyperlinkCTRL+KComplete a cell entryENTERCopy the value from the cell above the active cell into the cell or the formula barCTRL+SHIFT+" (QUOTATION MARK)Alternate between displaying cell values and displaying cell formulasCTRL+` (SINGLE LEFT QUOTATION MARK)Copy a formula from the cell above the active cell into the cell or the formula barCTRL+' (APOSTROPHE)Enter a formula as an array formulaCTRL+SHIFT+ENTERDisplay the Formula Palette after you type a valid function name in a formulaCTRL+AInsert the argument names and parentheses for a function, after you type a valid function name in a formulaCTRL+SHIFT+ADisplay the AutoComplete listALT+DOWN ARROW
on Feb 11, 2011 | Computers & Internet
Sum of the greatest run of negitive numbers
Hi, Not sure if this is what you have tried:
1: Assuming each run is on a different column
Run1 Run2 Run3 Run4, etc...and the maxium lenght of each column is 9 values, but each colum has a different lenght of numbers..
Then you can use:
=MAX(COUNTIF(A2:A10,"<>0"),COUNTIF(B2:B10,"<>0"), {keep adding countif for each colum).
If all runs are on the same colum, then using Pivot tables is easier. If you have a copy of your data, please post it so that I can give you the exact formula ;)
Oct 21, 2009 | Microsoft Excel for PC
Using excel to solve problem by trial and error method
In A1, put a random value of d as 0.1. Then in B1, put your equation 5*d^4 - 10.29*d^(-1.333), wherein refer d as A1. Then use goal seek function on Tools Menu. First "Set cell" as B1, "To value" as 0.124 and "By Changing Cell" as A1. Excel will do the Trial & Error and will give you the answer in Cell A1.
Nilesh
Mar 31, 2009 | Microsoft EXCEL 2004 for Mac
Add 20% uplift price to a pricelist in an excel spreedsheet
lets say you have the column B with the prices. Got to column C right beside the first price cell (I'll take B2 as first cell for example) which is C2 and type
=1.2*B2
Copy this formula in the column C all the way down to the last price Cell. That will give you all the updated prices.
Before you delete the column B where all your old prices are you need to do one more thing. Select the entire C column (new prices) go to edit and click on copy. Before you click anywhere else go back to edit and click on paste special and select value. This will change the formula cell you have created a minute ago to a value cell. Now you can delete the old prices. Good luck :)
Feb 25, 2009 | Computers & Internet
Macro code for copying a range of cells from one Excell w/sheet t
You did not respond to my claification request. Here is some code that might help, it copies a selection of cells going down until an emty cell is found and across until an emty cell is found. This is form an earlier version of office but should comeclose to woring in 2007.
Sub copyrange()
' copyrange Macro
' Macro written by Royal 11/22/2008.
'save the return values
wksname = ActiveSheet.Name
returncell = ActiveCell.Address
searchfor = ActiveCell.Value
'go to first worksheet and find entered value (note this is a value serach)
Worksheets(1).Activate
findfor = "A1"
On Error Resume Next
findfor = Cells.Find(What:=searchfor, After:=ActiveCell, LookIn:=xlValues, LookAt:= _
xlWhole, SearchOrder:=xlByColumns, SearchDirection:=xlNext, MatchCase:= _
False).Address
If findfor = "A1" Then
erwks = ActiveSheet.Name
Sheets(wksname).Activate
er = MsgBox("Search item not found on Worksheet" + erwks, , "Search Error")
Exit Sub
Else
findfor.Activate
End If
Cells.FindNext(After:=ActiveCell).Activate
'save this address and start searching for copy area boundaries
begcell = ActiveCell.Address
begcl = ActiveCell.Cells.Column
begri = ActiveCell.Cells.Row
'search amaximum of 1000 rows and 676 columns
endri = begri + 1000
endcl = 26 * 26
maxrow = 0
maxcol = 0
For col = Cells.Column To endcl
If Cells(begri, col) = "" Then
maxcol = col
col = endcl
ri = endri
Else
ri = begri
End If
For ri = ri To (Cells.Row + 1000)
If Cells(ri, col) = "" Then
If ri > maxrow Then
maxrow = ri
End If
ri = endri
End If
Next ri
Next col
maxrow = maxrow - 1
maxcol = maxcol - 1
'copy the selected area
endcell = Cells(maxrow, maxcol).Address
crnge = begcell & ":" & endcell
Range(crnge).Select
Selection.Copy
'go back and paste it in
Range(returncell).Select
' use this if yo want to paste formulas etc.
'ActiveSheet.Paste
' use this code if you want to paste values instead of formulas etc.
Selection.PasteSpecial Paste:=xlValues, Operation:=xlNone, SkipBlanks:= _
False, Transpose:=False
Nov 20, 2008 | Computers & Internet
Excel formulas
type in "=" and then go to the cell in the 2nd sheet and click on the cell that contains the value you want carried to sheet 1. Then drag copy the forumula in sheet 1 to all the cells you want it to relate to. Now, if you place a value in e.g. A1 of sheet 2, then that same value will appear in A1 of sheet 1.
Good luck.
Sep 13, 2008 | Microsoft Computers & Internet
Excel formula
I'm assuming you'd like to assign a numerical value to cardinal references (1st, 2nd, 3rd, 4th, etc.).
Best way to do this is to create a quick lookup table on a separate sheet of the same .xls document. Down at the bottom of the page, click on Sheet2 and create a quick table where column A has 1st, 2nd, 3rd, etc. and column B has your values.
Now click back to Sheet1 where your data is and in A2 put this formula:
=VLookup(A1, Sheet2!$A$1:$B$x, 2, FALSE)
Note: replace the lower case x in the formula above with the number of the last row of data in your lookup table on Sheet2.
You can copy and paste this formula down the column to calculate your other values.
Hope that helps!
Terry
Aug 30, 2008 | Microsoft Excel for PC
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Formula required
at first select the 1st page data and select data-subtotal from the upper menu list.
then enter the formula as =sum(1stpageSubTotal,2ndpageSubTotal,3rdpageSubTotal) then Press Enter.
If not solved pls get me that data as to reference.
thanks
Dec 04, 2007 | Microsoft Excel for PC
Microsoft MS OFFICE 2007 SBE MLK (NA) SW. (RZ365A#ABA) Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
