Ricoh mpc 2000 when machine starts without disply gives error codes. error message gives sc 202 in ark disply please give me detailed reply
    Master:
  • 435 Answers
Video might not help but this problem is due to the charge spring arching on the back of pcu, suggested fix eould be to restore spring to its original condition and add conductive grease to the charge plate on tge rear of the pcu. Hope it helps
Posted on May 03, 2013
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Posted on Jul 17, 2008
idriss47
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
  • 990 Answers
SOURCE: Ricoh Aficio 1224C/1232C problem code SC 792
Hello sir; try to turn off and back on the machine to reset, if don't work next few steps need to follow;
1, press "clear mode" then enter 107 then press and hold "clear/stop" key until SP mode show up.
2, turn power off and back on .
Posted on Jan 09, 2009
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
Ricoh mpc 350 error school 972 what is the resion Ricoh mpc 3001 error code sc 972 how I can fixed it
If you wish to get some details about printer repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 31, 2016 | Ricoh Office Equipment & Supplies
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Hello, i have a SC-534 error code on a Ricoh MPC-2500 I have change the BICU board, nothing change, change the two fan on the right of the fuser, and i still have the problem, could this be the sensor on...
I think the sensor you're talking about is the thermopile. If that is what you mean, should give another different code.
Have you sow the fusing exit sensor fan motor (at the front right side of the machine)?
Jan 31, 2011 | Ricoh Office Equipment & Supplies
Mpc 1500s sc 202 and af 1075 sc 995
are you sure the codes SC202 is ink related and you need to check the covers on the cartridges as the ink has run out...or the head is not recognising the cartridge..
the sc995 is due to a NVRAMM missmatch or failure.. the serial numbers are not recognised.. if you have replaced the controller board it is not correct or faulty. you can get a sd card and do SP5825 to download new details to the new NVRAMM
Jul 10, 2010 | Ricoh Aficio 1035 Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
SPANNER SYMBOL ON MESSAGE PANEL
What SC code is the machine giving? Watch the LCD display and the machine will give an SC Code. Let us know this and we may be help to further.
Mar 10, 2008 | Ricoh Aficio 1018 Printer
Error code sc 202
This code is a problem with your machine polygon motor it is defective or the cable running to it is defective , it is quite a big job getting to that motor so i sugest you get a profesional to fix that up for you .
Jan 02, 2008 | Ricoh CL4000DN Laser Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
Related SC code: SC 543
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
454 people viewed this question
k24674
jasbo
jasbo
