Question about Panasonic TH-37PW5B 37 in. EDTV-Ready Plasma Television
Panasonic TH-37 PW5 TV
How do I connect a freeview box i.e. what scart to use
CanadaBruce
  • 58 Answers
SOURCE: PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Posted on Dec 06, 2007
SOURCE: Volume Problems: Panasonic TH-42PZ700U
please could you send me tips of what the problem of my plasma keeping stuck pixiel panorama LCD Tv model 42LC68T
Posted on Mar 31, 2009
SOURCE: green screen when connecting old bush dvd with
Not all scart are the same... especially older ones, IF it has a Composite Out, Yellow, Video, and Red & White, R&L Stereo Audio. Use that it is better.
Posted on Mar 28, 2010
  • 135 Answers
SOURCE: will using a gold hdmi lead as opposed to scart improve picture
only on the hd channels
Posted on Apr 13, 2010
  • 11 Answers
SOURCE: I want to connect a Virgin HD box to my Panasonic
what you need to do is obtain an HDMI cable for your Virgin HD box. Leave the rest on scart (you can probably even add a another box now that you've freed up one port). Basically just press the button on your TV remote, saying 'Source' and you can flick through all your scart soxkets and HDMI ports. Simples.
Posted on Apr 18, 2010
Panasonic User Manual
as far as I am aware, you need a standard analogue aerial to receive Freeview, not a dish. The aerial plugs into set top box, which is connected to tv by scart. Freeview is different from Freesat
Nov 08, 2013 | Lands Phones
Connecting up CRT TV, VCR, DVDR and digital box
I think the better task is (A)
You can try switch scart's!! Then try to record on DVDR or leave as it is and look out for picture on your VCR!!! If you do (B) you will lose a picture quality!
good luck
Jan 31, 2008 | Televison & Video
I have a Panasonic TV with inbuilt Freeview TH-42PX70BA. I also have a Hitachi VCR VT-FX980E which I use to record analogue channels. Now that the analogue signal is disappearing I would like to record...
The simple solution is to connect your VCR to a Freeview set top box, which you can pick up for around £10. Simply connect the box via a scart lead. If the Video has two scrat sockets use the other for the box. For recording set the VCR up the same way but instead of selecting channel one or two etc set it as AV2 if that is the place the box is connected. When recording leave the box on the station you want to record and the VCR will record it. Don't forget to allow a few minutes either way for the start and stop times. Also if the VCR has PDC switch it to off.
You should be able to record this way whilst watching another channel on the TV. Some Freeview set top box's have timers on them so if you are out and want to record two shows on different channels you can.
If you have only one scart then a scart switching unit such as this below will solve that problem. Found on Amazon.
Sep 13, 2011 | Televison & Video
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
CNNECTING DMREZ27EB FREEVIEWDVD RECORDER, TO MY TV 2 SCARTS, AND MY PANASONIC VCR VIDEO RECORDER
I CONNECTED SCART TO TV 1 TO DVD FREEVIEW SCART 1, THEN I VCR SCART IN/OUT TODVD FREEVIEW RECORDER SCART 2, THEN RF CABLE FROM FREEVIEW RECORDER OUT TO VCR RF IN ,VCR RF CABLE OUT TO TV RF IN. RF SLOT IN ON FREEVIEW LEFT EMPTY THEN CHANGED TV TO AV 2 WHEN USING TO RECORD /PLAY EITHER VCR OR/ FREEVIEW DVD . I DO HOPE THIS HELPS SOMEONE. IT TOOK ME A WHILE TO SORT OUT REGARDS R. ELLIOTT.
Feb 22, 2008 | Televison & Video
Top box conns
your freeview box tv scart goes to the tv /the dvd goes to the aux on freeview and you can connect your vcr to the tv if it has a spare scart socket or the dvd player
Jan 14, 2008 | Computers & Internet
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Problems using video to record from tv
The tv has 3 scarts try connecting to AV3.
If still no luck go to the TV Menu and then 'Setup Menu' find settings and change AV2 OUTPUT TO TV.
Nov 11, 2007 | Panasonic TH37PX60 37 in. Plasma...
Panasonic TH-37PW5B 37 in. EDTV-Ready Plasma Television Logo
118 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
