Question about Garden
Deck on craftsman lt2000 is not level-
Wondering if the deck has lost a spring or wire or something that may cause the deck to be unlevel- which in turn may be why the grass is being cut shorter on one side of the cut
5 Suggested Answers
  • 7 Answers
SOURCE: deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Posted on Sep 05, 2008
woobie dog
  • 1273 Answers
SOURCE: 42" deck not cutting level
I had a similar problem, and the problem was fixed by airing up one of my front tires. This may not be all of the problem, but you should eliminate this before you go adjusting.......
Just a thought, --W/D--
Posted on Aug 05, 2009
  • 138 Answers
SOURCE: 2003 DLT3000 Craftsman riding mower. Air in tires
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Posted on Aug 26, 2009
perpetually
  • 360 Answers
SOURCE: uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Posted on Sep 21, 2009
I have craftsman b & s 18.5 ohv, 42 in cut, lt2000, intek plus. Belt keeps stretching
Make sure all pulleys on the mower deck move freely. Also a major issue with that mower is the idler are. This will be the pulley with a large spring attached to it make sure it's pulley isn't worn turns freely and the arm travels back and forth as it should.
Sep 09, 2016 | Craftsman Garden
I have a 2011 Craftsman LT2000 Model # 247.288851. The blades will only engage when I raise the deck to level 5. Ive replaced the Seat Safety Switch so Ive eliminated that. Help please! Lol
what actually engages the blades an electric clutch or a manual lever both of my craftsman mowers have elec clutch and when you pull the button the blades run deck height has nothing to do with it .
Apr 08, 2015 | Craftsman Garden
How to locate where the deck spring connect on sears 2000 lt2000
if you provide the model number from the placard under the seat I can try to help you.
Aug 30, 2014 | Craftsman Garden
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
Belt on my craftsman LT2000 is stretched.is there a way to tighten the tensioner ? or is it automatic ?
tensioner will only work within a range- although the spring may be weak they do fatigue and go bad-sears should be able to get you a new spring -I would get a new belt at the same time-cheersDenny
Oct 26, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HOW DOES THE CABLE ON A SEARS CRAFTSMAN RIDING LAWNMOWER LT2000 17.5 HOOK INTO THE DECK
ON TOP OF THE SMALL IDLER PULLEY THE BOLT IS LONG AND IT HAS A HOLE IN THE SPRING GOES ON THAT BOLT AND THEN A WASHER THEN A PIN THAT HOLDS IT IN PLACE
Nov 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT2000 transmission won't engage
Sounds like you either lost a bearing inside the transmission or that something in the linkage system has come loose and shifted. easiest way is to jack the unit up and visually follow the shifting hardware, while having someone trying to engage it with unit shut off and see is you can visually find where the shaft is slipping or failing to move. Hope This Helps Don
Nov 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
486 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
