Question about Dual XDVD210 6.2" Touchscreen DVD Receiver
What format do i use to play video threw the usb
I cant find the right format to use to play videos its says cant read
  • Charles Hilliard Apr 18, 2013
    what format do i use to play videos threw the usb
I cant play movie through usb with my DAV DZ777 home theatre
Sony 3 285 995 11 1 Operating Instructions Manual Page 63 Sorry. You cannot play movies on a USB thumb drive. You can only play still pictures in jpeg format not movies.
Sep 06, 2016 | Sony DAV DZ777 Music Home Theatre System
The video files on my usb doesnt play in my pensonic tv
As far as we know, codec support is likely to be limited to whatever Panasonic decided to support in their TV. Unfortunately the video's you play on the TV will need to be formatted in such a way that they are encoded using codecs supported by the TV. Panasonic may have the list of supported codecs in the manual of the TV hopefully otherwise you would need to ask them or play the game of encode and test until you find something that works.
If your Panasonic TV can't either read some video file like MP4, MKV, MOV etc or when it does the images are kind of distorted with poor audio, you may get some videos encoded beyond Panasonic TV's support. Something even worse, you will not be able to install codecs onto a TV like you would a PC unfortunately. An ultimate solution to get unsupported format detected by your Panasonic TV is to convert unsupported videos to a Panasonic TV more friendly format with Pavtube Video Converter
Read Guide:
Best Way to Play unsupported videos on Panasonic TV from USB
Sep 11, 2014 | Televison & Video
How to format DVD that you put on a USB card to play in flip up DVD player
I'm a bit confused with the terminology? You want to format a Card or a USB drive? If you insert a USB or a Card drive into a computer, open the Computer folder select the USB or Card, right click, select format. Usually the Camera has, in settings, a format procedure, select format/erase, and OK/Yes.
Apr 06, 2013 | Car Audio & Video
Cant find right video format for my go video
Check the specification of your MP3 player to determine the type of video file format it uses. Most common video files that MP3 players use are, AVI and WMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is an incompatible video file format, then you need to convert that video file to a format that your MP3 player uses. After video conversion then copy the video files to your MP3 player using the USB cable from your computer. Click on this link for instructions on converting video files for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
Oct 28, 2012 | Audio Players & Recorders
I want to use my seagate 500gb freeagent to store movies and to play them on the tv, but when i load movies on to it, it comes up as an unsupported device. i cant open it up at all. thanks.
The video you want to play must be in the correct format and your tv must be USB compatible to read off of the usb.
If you have an Xbox, or Wii and put XBMC on it, it should be able to play various video types such as .avi, .mov, and etc.
Mar 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB video file wont play
.avi format it supports
Apr 24, 2010 | Samsung DVD-VR357
Nikon s51 can't transfer video from camera to comptuer
Try removing the memory card and insert it into a USB card reader and connect it to the computer to read/copy the images/video files.
You should format your memory card using the camera functions before you take the next lot of pictures and videos.
Nov 30, 2008 | Nikon COOLPIX L10 Digital Camera
Dual XDVD210 6.2" Touchscreen DVD Receiver Logo
99 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
