Question about Compaq 6710b Notebook
DVD writer not working
My dvd writer is currently behaving like a ROM.it reads data but cant write.
On nero it shows a ROM,but i did write sometime ago.
Any idea!!!
  • 3 more comments
  • rajesh_city Mar 11, 2009
    when i right clicked any file i didnt find my dvd-rw drive in the pop-up list....but the drive still reads any data
    can you send me the link for the driver......i have hp compaq 6710b pc notebook
    OS: xp prof with sp-2
    its not that my drive is not detected......its no longer act as a writer...now it only reads
  • rajesh_city Mar 12, 2009
    serial no- CN47402S60
    dvd drive : MATSHITA DVD-RAM UJ-860H
    previouly it was showing something like this
    MATSHITA DVD-R/W..............
    hope this will help your find
  • rajesh_city Mar 16, 2009
    The link was too some helpfull......but i've a dvd/rw drive and proper drive type for it was not mentioned in the link
    drive type 1 -> cd-r
    drive type 1 -> cd-rw
    drive type 3 -> cd-rom
    my drive type was initially set to 3 & i changed it to 2.
    but not worked.......need to know drive type of a dvd/rw drive
    i just found my drive doesnt detect any empty disc....may be just may be this is the reason why any burning software not working.........i tried it with nero,roxio........can you provide any more help on this
    Scholar:
  • 54 Answers
Let's make sure that Nero is not causing the problem. Try this:
-Insert a blank CD or DVD
-Find a file that you want to burn to disc
-Right-Click on said file and select Send To --> DVD-RW Drive (D:) (or whatever your recordable drive is labeled)
-Open My Computer, double click on your recordable drive
- You should see your file ready to be burned to disc
- In the left-hand panel, you should see a link that says "Burn these files to disc" or something similar - click this link and see what happens
If this process works and properly burns a disc, your issue is not with your drive but with Nero. If this process does NOT work, then you may need to reinstall drivers for your DVD writer or replace the drive if it is faulty.
Hope this helps. Please take a moment to rate this solution. Thanks.
Posted on Mar 11, 2009
  • 1 more comment
  • RSBennett
    RSBennett Mar 11, 2009
    Upon researching at HP's website, there is no specific driver for your DVD drive. Most optical drives (CD & DVD) use the same generic Microsoft drivers.
    If you remove the drive via the Device Manager, then reboot your PC, your PC should automatically detect the drive and install the default driver. If your PC does not detect the drive, you can attempt to install via the Add Hardware Wizard found in the Control Panel. If your drive is still not detected the drive is most likely faulty and needs to be replaced.
    Hope this helps.
  • RSBennett
    Got it. Sorry for the misunderstanding. Let me do a little more digging to see if I can find a different driver or a firmware update for the particular drive. If you can send me a product number or serial number for your computer, that may help me identify exactly which DVD drive you have.
    Thanks.
  • RSBennett
    RSBennett Mar 13, 2009
    I have not been able to find a specific driver for your drive. I did, however find a bulletin at support.microsoft.com that addresses this issue. Check out the following link and let me know if this solves the problem.
    http://support.microsoft.com/default.asp...
In my sony dvd writer(DRU 8705), the prblm is that when i write any data frm my HDD into a dual layer dvd, the burn process succesfully completes but after that when i try to run the datas such as games,...
Hi ,
For video , use NERO Recode
For data , use NERO Burning Rom
If the issue persists , try using burning with another unit and compare the results . If you are still stuck , change software . If this still doesn't work , install Malwarebytes and make a full deep scan of your system ( http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html )
One of these solutions should help .
Best regards .
Jan 22, 2011 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
My DVD-Rom is unable to read (detect) any blank DVD.It is reading movie or any other already written DVD,but not a blank one.I am not getting whats wrong with my DVD-Rom.Please help me.
try using nero as explorer may not readily detect blanks.Also ensure the writer is a dvd writer and not just a dvd rom
To ensure compatibilty with the ever increasing range of media, an update to the burner .is usually all that is needed, this is called firmware upgrade
Most drives will read anything, and most burners are
now "all formats", but you may have a burner that is
either one or other, not both, thats to say, your burner
maybe only a "DVD+R/RW" - note the "plus" sign.
whereas your blank media maybe "DVD-R/RW"
Jun 17, 2010 | Hi-Val DVD Kit (DVD6X-00R1) Internal DVD...
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    My dvd writer was working perfectly but when i format my wondow now it is playing only cds & when i insert a dvd it is not giving any response & my driver is also showing as cd-rom
    When you formated you erased the driver you need to use your dvd writer as a dvd writer and player. If your dvd-rom came with a cd use it to reinstall the driver and program it uses. Otherwise you can search for your driver thru the manufacturer website or go to www.driversguide.com and find it there.
    Dec 17, 2009 | LG 16X Internal DVD-ROM, E-IDE / ATAPI/...
    Nero problem
    You should reinstall your nero software and DVD/ Writer should be on master and CD rom shoul be slave. Then it will work at all.
    Thank You
    Jul 30, 2009 | Sony Optiarc AD-7170S Burner
    DVD Writer not burning
    I have come across this quiet abit. U could try updating the firmware but I would say that the lazer is past its best. I presum it still read the cds fine? I would suggest getting another drive if firmware update doesnt work
    Oct 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
    Cant read dvd on my sony 18x dual layer dvd writer
    go to nero 6.66 and use imation discs, if your os is running ok and you do not suceed whith that i told you, your dvd unit is bad.
    Mar 14, 2008 | Sony AW-Q170A-B2 BLACK 18X DOUBLE & DUAL...
    LG DVD writer problem
    You should be using the software "NERO" to burn discs.Goto>start>all program>Nero>Data>NeroExpress
    Here you clearly see the two types to burn disc "data cd" and "Data dvd".
    Need More help?.if yu are using another software whats that?
    Mar 07, 2008 | Computers & Internet
    Will write dvds but not cds ??
    Try using nero to burn, be sure to select cd as the type of media... e.g Start > all programs >> nero >> data >> nero express .. Then
    select cd, data cd,, drag some pics across and burn it.. If that dont work.. i hope u got warrenty... or if you wish to keep trying let me know
    Dec 30, 2007 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
    Dvd re-writer not burning
    what operating system are you using? has there been some upgrades in your system? have you tried to update the driver for your device? did you try to check if the imapi services is set to automatic and running in (click start>control panel>click administrative tools>services>double click IMAPI set to automatic and click start
    Dec 24, 2007 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
    Compaq 6710b Notebook Logo
    806 people viewed this question
    Top Compaq Computers & Internet Experts
    Alun Cox
    Abhinandan  Patil
    Abhinandan Patil
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
