HK AVR255 goes into PROTECT mode
I have HK AVR 255 with HKTS 30 speakers. The system was working fine until I encountered the PROTECT mode problems since last 3-4 months. As soon as I switch the AVR on, it goes into the protect mode. I have tried the following : 1. Disconnected all the speaker wires/HDMI cables etc and checked the AVR in bare mode, it still goes into PROTECT mode. 2. However, when I took it to the dealer's place, it switched on in the bare mode;which was quite surprising! 3.I have still been able to make it work by following these steps : -Select Zone 2 on the AVR remote -Switch on the AVR in the Cable/Sat mode -Switch the Zone Selection to Zone 1 -Select Cable Sat/DVD or any other mode and it works ..... I am unable to figure out as to what the problem is still ..Any suggestions ?
4 Suggested Answers
sparky1500
  • 1066 Answers
SOURCE: 1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
Posted on May 17, 2008
SOURCE: Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
i have the same problem . denon had changed knob and circuits ?! one day later ... same issue !
i have 5.1 evo tangent 4-8ohms and 2 technics 8ohmsand i use frquently A+B configuration
Posted on Nov 08, 2008
SOURCE: Audio problems using a Playstation 3
First try ensuring that "OPT 1, 2, or 3" function is selected depending which one you are using on the H/K 146 (see manual for selection instructions). Next please ensure that the PS3 audio out set to "optical" (Settings/sound settings/audio output settings/digital out+DD 5.1). That should help.
Posted on Dec 24, 2008
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
I have an HK AVR 355 system, that worked just fine. Yesterday I tried to hook up a new TV, and ended up taking a few cable out since they were not imoportaint any more and only used HDMI cable. Now when I...
Obviously you removed (or disturbed) something that was really necessary to the DVD's digital audio path. "Doesn't work" is pretty non-specific.
Do a web search for "HK AVR 355 manual" and download it. Then read the part about assigning digital audio sources and speaker configuration setup.
Look at the Troubleshooting Guide part that mentions the Channel Indicator Display (page 33).
Aug 17, 2011 | Harman Kardon Audio Players & Recorders
HK AVR-247 protect mode
This is an indication of an internal problem. Typically this is shorted output transistors. Expect a parts cost in the $25-$40 range for this repair.
Dan
Apr 06, 2010 | Harman Kardon AVR 240 Receiver
Reciver goes into protect mode as soon as I turn it on.
Remove speaker wires and try again. If it still goes into protect mode, the problem is internal...shorted power transistors or some other fault. Check fuses also.
Apr 01, 2010 | Harman Kardon HK 3480 Receiver
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
Front audio channel burnout
Resistors can fail from being turned up to hire, wires getting bumped together or against metal, speakers being wrong ohms, or just plainly overheating.
May 22, 2009 | Harman Kardon HKTS 5 System
HK AVR25 MKII goes on and off numerous times on cold power up
The relay on the PWR SUPPLY board clicks once when the PWR switch is turned on then 2 to 5 sec. later it clicks again and 'off' it goes.
The small transformer ( standby power) on the board appears to be leaking crud (looks like wood glue) all along one edge.
Can I bypass this relay to see if the power transformer is 'ok'?
Jan 16, 2009 | Harman Kardon AVR 25 MKII
HK AVR 120 (left speaker not working)
Hi, your analysis are right, your speakers has no problem, the problem is in your receiver.
there are several factors that affects it, try some troubleshooting: and answer this questions:
1. During this event, what is the source of your INPUT audio signal?
Have you tried to replaced your RCA cables that connected to the source of your receiver?
If YES, then problem really exist in the internal system of your receiver. may be you have overdrive your receiver unintentionally, which cause the Power Amplifier to malfunction,
On this event, I would suggest that you bring your receiver to it's Service Center for repair,
This problem needs technical troubleshooting of a qualified technician.
Dec 25, 2008 | Harman Kardon AVR 120 Receiver
 Grubhead
Grubhead
