Question about Citrix GoToMeeting
Audio connection lost - Citrix GoToMeeting
The Akai TV MA TE02 lost sound
It sounds that the audio output section circuit has the fault. Check it audio out pre-amp sockets at its back, connected to any external Amp. See whether audio comes out by this way. If not, the main digital board is faulty. If yes, audio output section is faulty.
Dec 31, 2012 | Televison & Video
Lost 50 in.tv audio
Check audio connections if it is an external source and also check other input sources like a DVD player to see if the audio comes from that. If you never get any audio it could be a power supply issue or a amplifier that has broken solder joints on the board. I have had to repair many wave soldered boards over the last 40 years due to little solder on the component leads and then some parts that handle power or get hot develop what is called a thermal break in the soldering that connects the component lead. If it is not a bad setting or cable into the display device then you might need to consult a Technician.
Aug 10, 2012 | Sanyo Dp50741
Lost sound
You burned out the audio chipset, (Unless when you downloaded the audio drivers, you did not Install them. You have to download AND install)
Suggest you purchase an economical sound card. Just ONE example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2177471&Sku=D10-2092
Regards,
joecoolvette
Jun 15, 2012 | Computers & Internet
LOST MANUAL HOW O YOU HOOK UP THE SURROUND SOUND TO TV
1. Does your TV has an Audio OUT? If it does then connect the TV audio out to your Home Theater system's Audio In.
2. Are you using Cable box? If you do then connect the Audio out of your Cable box to the Audio In of your Home Theater system. video out of your cable box to the video in of your TV.
Jun 25, 2010 | Philips Magnavox MRD500VR System
I have compaq presario F700 laptop, recently lost dvd driver and now lost wifi connection , husband says something about code 31 and when i search it on our regular computer all i get is stuff about audio....
plz help me and solve my problem of compaq c794wu audio driver installation .
Posted by mail2renga on Oct 18, 2008 Hi,
I have Compaq presario c700tu. but sound and micro phone is not working.
Please help me.
Reza
Dec 06, 2009 | Compaq Presario 700 470024-192 Notebook
How do i connect my M-AUDIO FIREWIRE SOLO to my sony vaio if I don't have a firewire port?
when i use m-audio firewire solo recording interface ,my computer was shut down and my sound were lost
Nov 12, 2009 | M-Audio FIREWIRE SOLO Sound Card
JVC CarAudioModel KS-RT404 lost rear panel containing connections
http://files.ddrservice.info/Audio/jvc/ks-rt404.pdf
This link will take you to the manual. On page 7 you will find the connection Info. you need.
Sep 18, 2009 | Car Audio & Video
I have lost the CD to my webcam model number 98067. When I try and connect the webcam, all I get is audio. Can anyone help?
Jun 07, 2009 | GE EasyCam Webcam
Lost sound
First check the controlpanel there is an option to take Sounds And Audio Devices Properties. then click on the AUDIO tab, check the Default Sound Playback Device.select the correct Audio divice.if the problem persist do the driver for sound ( multimeadia audio driver) from the acer driver cd.then try.
Dec 08, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
24 people viewed this question
Top Citrix Computers & Internet Experts
xxxxxx xxx
alibaba69
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
