Question about Dell Precision Computers & Internet
My monitor has 3 sets of prong hook up but the computer I just got has only 2 sets of prongs can I get an adaptor or a new cord for this
  • Dell Master
  • 3,799 Answers
What are you talking about? What is your monitor? and the Computer model number.
Posted on Apr 18, 2013
  • 17 Answers
SOURCE: Hi boughr Acer monitor 191w.IT
No just connect the 15 prong vga plug and dont worry about the 24 prong one15 prong is vga and 24 is dvi both are for video and will not affect the sound. The audio should have a jack plug on it.
Posted on Dec 03, 2008
  • 24 Answers
SOURCE: I have a Gateway 702Ge desktop. I have upgrade the
High-end graphics cards require more power from your system to process all the graphical goodness. The manufacturer probably has several different versions of the card and is using a standard manual for all different models (hence the different listing in the manual). I would tend to say that if it was in the manufacturer's retail packaging then everything that is required is in the box. Look at the card itself and see if that 2 prong power fits your model. If you're having no luck, bring the product back to Best Buy and get a replacement and let them know what happened.
Posted on Jul 16, 2009
danielizapat
  • 87 Answers
SOURCE: Computer HP Pavillian won't start
try another cable. if that doesnt work then it has been damaged the plug in the power supply quick fix if the cable doenst fix it replace the power supply. u can find a 350 watt power supply on craigs list for 10-20 bucks. If you can handle replacing the power supply. If you want to try that and need help I can walk you thro it.
Posted on Sep 24, 2009
efs_perpends
  • 1996 Answers
SOURCE: My USB Prongs Are Bent Both Of Them My Ethernet
You can buy a new PCI card with ethernet plugs or a new usb card, and with a minimum of fuss, install it yourself. Make sure you ground yourself to some metal on the case before removing or installing the card. To be safe, check the specs of your system by entering the service tag # at Dell.com, so you can make sure the new cards you purchase are compatible with your older system. Or, if you prefer, take it to reliable local tech shop. They may even have good used cards they'll be willing to sell you inexpensively, if they recycle old desktops.
If you search the internet for 'PCI cards' or 'install PCI card', you'll find more details to guide you...
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Dec 19, 2009
Testimonial: "Thanks"
leecom72
  • 4806 Answers
SOURCE: I accidently removed 3 sets of jumpers (power,
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light to see the marks.
Regards.
Posted on Feb 07, 2010
Manuals free
Your question was worded poorly and it's difficult to understand what you are asking. As a guess, if you are looking for a 30-amp adaptor cord set, perhpas this will work:
Conntek 20601 25 Foot 10 4 30 Amp 125 250 Volt 4 Prong L14 30 Transfer...
If it's a 3-prong adaptor:
Camco 55333 30 AMP 3 Prong Generator Adapter
Or a 15 to 20 adaptor:
Coleman Cable 09020 12 3 9 Inch Generator Cord Adapter 5 15P to L5 20R
Aug 27, 2014 | Electrical Supplies
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
Don't know how to switch from 4-prong to 3-prong power supply
Your new 3 prong power cord needs to be wired up just like the 4 prong you just dont have the seperate ground . in the use of a three wire cord ground runs thru neutral .Hook black to black on the terminal block on unit. hook red to red on the other side of block and white to white or green in the middle reinstall the cover ....Plug in and your ready to dry
Aug 14, 2010 | LG DLE2532W Electric Dryer
The 4 prong to a three prong..here goes it its a cord that is 1-2-3 all facing the u that connects them, old cord off new cord on 1-2-3 one to white one to red one to black same order ...the man a t sears...
If I understand you are using the 3 prong cord now. The L shaped prong is the middle one or white. The 2 flat ones are for the red and the black. If tho original cord was 4 prong there was a ground (round prong). There should be a ground strap connecting the white post to the cabinet in the 3 post setup. Ask me to clarify if this is not clear, better to be sure than hurt..... Eric
If you had a wire incorrect it may have blown a fuse or worse depending on which wire was wrong.
Jun 17, 2009 | Frigidaire FEQ332E Electric Dryer
Power cord hook up
Hi Jay
Middle terminal is White and goes to the "L" shaped prong
Red and Black go to the Flat prongs (Doesn't matter which)
Round prong to cabinet Ground.
There may be a strap from the White lug to the cabinet. This must be removed for the 4 prong plug arrangment.
Eric
Jun 08, 2009 | Electrolux Dryers
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
Trying to hook a 3 prong hook up with 4 prong cord how do i do it?
A 3 prong plug is for 240 volt (hot-hot-ground) the 4 prong plug is for 120/240 volt (hot-hot-neutral-ground). If your device requires a 4 prong plug, it is not a good idea to connect it to a 3 prong circuit (you will create a possible lethal electrical condition). If your device requires a 3 prong connection, a 4 prong cord can be used by not connecting the neutral (white wire). If you have any questions, let me know.
clarkco
Mar 31, 2009 | Maytag Dryers
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
How to hook up flat screen monitor??
That's all you need. Just a standard power cord plus the VGA connector cable. Plug the new monitor into the same spot as the old one.
Dan
Apr 09, 2008 | ViewSonic VE155b 15" LCD Monitor
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
