Question about GE Washing Machines
Clothes stuck under infuser - GE Washing Machines
Unable to remove infuser, no warning light, reset multiple times, brews coffee fine
You should go to test mode and try moving infuser up and down to position when you can take it out it needs some skill of timing. After that you need to disassemble infuser completely clean it up and lube with special food grade lube. Also there could be a problem with transmission kit that cause this problem.
Mar 22, 2014 | DeLonghi ESAM3300 Magnifica...
Brewing unit stuck
make sure you are trying to remove the infuser when the machine is turned off. you can damage the unit if trying to remove the infuser while the machine is on (and you won't be able to get it out).
Jan 10, 2013 | DeLonghi EAM3500 Espresso Machine/Coffee...
I want to ddownload my itunes music, movies, etc... My sell phone is a samsung innfuse from T&T. Can you help me?
Hello Jane! Welcome to FixYa!
First you need to download the itunes agent for your Samsung Infuse.
To download it CLICK HERE
After download it you need to install it on your PC, After installing it, Open the itunes agent and go to the itunes Store. You can download it your desired music music and movies, Or you can also free download the Movies and Music from HERE
When you will download the music you need to transfer it on your Samsung Infuse follow the given procedure:-
1. Plug the Samsung Infuse 4G into your computer's USB port and mount it2. Touch the USB icon that appears in the menu bar at the top of the display, and drag it down to expose the Android Notification Pane. Tap on USB Connected, and select Mount. Create a folder on the mounted Infuse 4G called Music and the music and movies which you downloaded before, Copy and Paste then into that folder.
The second section, below, details how to create a configuration for the Infuse 4G in iTunes Agent's Preferences
  1. Right-click on the iTunes Agent icon in the system tray
  2. Click Preferences
  3. Leave all defaults checked and click the New button
  4. Give the device a name (Infuse 4G in this case)
  5. Leave Synchronize pattern: set to iTunes
  6. Click the Choose button and select the Music folder you created on the Infuse 4G
  7. Click the Create button and select the Music folder you created on the Infuse 4G
  8. Click Save and then Close
The final section explains how to add music to your Infuse 4G
  1. Launch iTunes and you will see a playlist folder called My Devices, under which you will see the Infuse 4G
  2. Simply drag the music you wish to synchronize from your iTunes library to your Infuse 4G into this playlist
  3. Finally, right-click on the iTunes Agent icon in the system tray and selectSynchronize devices
Music is now copied to your Samsung Infuse 4G and can be played using the Infuse 4G's Music application.
I hope you have a clear picture in your mind, Feel free to let me know if you have some confusion.
Sir, If you consider my service helpful for you then please Don't forget to Rate my Service as FIVE STARS and give the Words of Appreciation as Feedback for me
Thank You for taking my service
Concerned: Muhammad Uzair
Team : FixYa
Dec 10, 2011 | Cell Phones
Yesterday and today the machine did not come on as normal it said press next + change, nyesterday when I did that it said generic alarm, but then worked, today the generic alarm would not go off. the book...
I had the same problem with the infuser stuck at the top and the triangle light staying lit. I fixed it by unplugging it from the wall. I then removed the side panel and the back panel.
Facing the rear move the sprocket that the motor drives. The best way to start it (if it is stuck) is with a flat screen driver on the right side of the motor and push the sprocket towards the front. Once it starts you can either pull the belt from the other side or push it from the right side. It took 10 minutes to get the infuser to completely come down.
After that I pulled it out and cleaned everything. When I put everything back together the light stayed on and the machine would not respond. I did fix it by turning on the machine, pulled the power plug, and when I plugged it back in the system went through its cycle. Everything is fine now.
Jun 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Took tray and grounds tray out to clean and it won't go back in - it is jamming. Have cleaned inside but still stuck. Tried pulling infuser out but this is stuck as well. Appears that central unit has...
I had this problem last night. The infuser was stuck down too low and the tray wouldn't slide in. I got the solution from FIXYA, and it worked for me.
First make sure machine is off at power, then put just the coffee grounds collector and not the whole tray back into place, gently close the door, and then turn the machine back on. At first I couldn't close the door, but I fgured that the grounds collector was a bit too low, so just put something in there to hold it up while I shut the door. Turn the machine back on at power and HEY PRESTO, it all started up again, and then the infuser moved back into correct position.
Make sure you have a cup handy just incase water starts to rinse out.
Hope this helps
Tania
Sep 10, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Infuser stuck up my delongi magnifica
I have a problem. I removed the infuser and the internal bracket is now in a "down" position and I cannot get the infuser back in. I need to know how to raise the internal bracket to its proper place. Any ideas?
Apr 06, 2010 | DeLonghi Coffee Makers & Espresso Machines
DeLonghi Magnifica always asks "Insert Infuser Assembly"
DeLonghi "Insert infuser assembly" error
Easy Fix - Delonghi Coffee machines which have built-in coffee grinders often suffer from a problem that produces an error, "Insert infuser assembly" that appears at random times.
The problem is usually caused by distortion of infuser lifting mechanism limit switch mounting (Orange colored plastic)!
The mounting is very close to the water heater so with heat and pressure from the infuser lifting mechanism the mounting gets bent over time. The switch mounting (Orange colored plastic) gets permanently distorted so the striker arm on the lifting assembly only just presses the micro switch button causing the error message "Insert infuser assembly".
To easily fix the problem on ESAM 5500 machines and should work on other similar machines:-
    1.Unplug the machine and remove the rear cover screws and remove.
    2.Slide out the two side covers.
    3.Remove the grinder lever screw in the top cover coffee bean compartment.
    4.Carefully lift the top cover pushing it slightly back so it does not stick under the front cover (you may have to loosen the 4 front cover screws on the side).
    5.The limit switch is clearly visible on the top (see photos).
    6.Wedge some insulated material (wood, plastic etc, I used bamboo) between the heater assembly and the switch mounting so the switch is in a VERTICAL position. The thickness of the packing is around 3-4mm (see photo).
    7.Re-assemble the machine and enjoy your coffee. JTS
    Alwar, Rajasthan
    India
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
