How do i turn on wireless on my MSI notebook.i can even see the available networks but it just doesnt get connected
When i go to the networks and select wireless am able to the available ones i do everything correct i think.it cant still load
  • 4 Answers
Make sure you a) have wireless ability b) have the wireless drivers loaded
Posted on Apr 18, 2013
djnick989
  • 1067 Answers
SOURCE: Latitude D600 Network problem
unplug roughter then back in after 1 min and modem ok then rebooot give it a min
Posted on Jan 20, 2008
rtrahan
  • 741 Answers
SOURCE: wireless network detected not listed in view available wireless
Two things. First go into Device Manager and make sure the driver is loaded. Right click on Network Adapter, then right click on your wireless card. you can update driver, remove driver and let plug n play pick it back up, or if looks like no problems then leave it be. second, did you set it up going thru the Wireless Network Wizard..Its under Accessories>comminication in Windows XP.(You didn't indicate which OS you are using). What is probably happening is you are not quite set up correctly and your WEP is blocking you from connecting because the computer does not have your WEP key....if you have any questions let me know.
Posted on Apr 03, 2009
  • 84 Answers
SOURCE: no wireless connection on acer one notebook
Make sure the LAN is not set to use any IP address. It should be on DHCP ok. Some times, the WLAN has to be configured to use IP address, so get the addresses of the Wireless Router: IP, Subnet Mask, Default Gateway and Pref DNS and assign these to the WLAN. Only the IP addr should be different by adding one or two to the Router's IP ok. Restart the pc and it will get connected. Good luck
Posted on Apr 28, 2009
ChobPT
  • 220 Answers
SOURCE: cannot connect to wireless internet
make sure you can detect networks
If by mistake you disabled the wireless, you can re-activate it by pressing fn-f11
Good luck
Posted on Jun 21, 2009
mail2pvs
  • 390 Answers
SOURCE: My wireless connection works on all the other
hi
check for the necessary ip addressing formats as well as if any DNS server addresses are required to connect to the network
if all is fine then try
right click on the network icon click on repair
try surfing if still not able to surf try the steps a couple of times
cheers
Posted on Jun 23, 2009
Wireless lan not working on my acer aspire 4520
The wireless feature (Wireless LAN) on an Acer notebook allows you to connect to available networks. This convenience allows you to use the Internet with network cables, modems or network installation. Acer laptops come with a wireless switch to turn the wireless feature on or off. Once you enable the wireless feature, your Acer notebook can connect to wireless networks within range.
Instructions:
1.Locate the Wireless LAN switch located on the front of your Acer Notebook. Move the switch to the right to turn on Wireless connections.
2.Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks.
3.Select the network you want to connect to and click "Connect."
Sep 07, 2011 | Acer Aspire 4520-5582 Notebook
Just got aspire 3000 .How do I turn on the wireless capeability
Follow these Instructions
Feb 12, 2011 | Acer Aspire 3000 Notebook
Wireless connectyion does not work on Msi U120
Are you using windows utility to connect to the wireless network. If you are not then switch over to windows utility.
Remove the preferred networks from the list, and then try to connect.
If that doesn't work then try to uninstall and reinstall the adapter using the found new hardware wizard.
Click Here for more info about networking
Oct 07, 2009 | MSI : MP54G Wiress 802.11g Mini PCI Card...
Wireless adapter doesnt work at my new place
can you see your home wireless network in the avail wireless networks if so can you connect and enter the security key
Jul 20, 2009 | IBM ThinkPad T41 Notebook
Cannot connect to wireless internet
Good luck
Jun 21, 2009 | MSI Wind U100-030US Laptop
Wireless stopped working on my msi laptop
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Apr 06, 2009 | MSI MS-1022 Notebook
Can't find the wireless antenna on my msi u100 series laptop
Not really sure what you are expecting. The wireless antenna is within the computer--you won't see it.
What you will need to do is to turn the wireless networking on. This is done in some computers with a small switch on the case (in this case, there is usually a light that comes on when you turn the switch on). In other cases, you will have to use the Fn key plus one of the special function keys at the top of the unit (has a picture representing a wireless connection on it--possibly something like an antenna).
If this fails, go into your network connections and see if the wireless connection is actually turned on. If you have Vista, this is sorta easy as you click on "connect to" and then choose "wireless network"
Apr 03, 2009 | MSI WIND U100 Notebook
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
MSI wireless 802.11 LAN network connection not connecting
i don't know how should i connect to the internet with wireless in msi cr400 laptop!
May 05, 2008 | MSI : MP54G Wiress 802.11g Mini PCI Card...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
