Question about Vehicle Parts & Accessories
I need to know how to change the timing chain and gasket on my 202 olds alero 2.2L
    New Friend:
  • 17 Answers
TDC is crucial. There will be a mark somewhere on the crank/pulley/gear and a mark on the block. The cam gears also have a mark. They MUST be lined up. If they ate not chances are they're 180' off. Rotate the crank 360' to get them to line up. Tip the crank spins two times for every one time the cams spin.
Posted on Apr 19, 2013
I have a 2001 Olds. Alero, what do I have to change to put in a 1999 Pontiac, Montana 3.4?
If it's running I would sell it and get another vehicle the cost to repair out ways the vehicle worth
Apr 21, 2014 | 2001 Pontiac Montana
2.2 alero bogs
Plugged catalytic converter ?
Jun 25, 2017 | 2002 Oldsmobile Alero
Changing the water pump in the 1999 oldsmoble alero involve the timing chain? and is it easy to chance it?
YEP THE 2.4 ENGINE YOU HAVE TO REMOVE TIMING CHAIN TENSIONER AND TIMING CHAIN.THIS JOB NOT EASY OR HARD BUT IF YOU NEVER DONE ANY KIND AUTO MECHANIC WORK BEFORE JOB WILL BE HARD.IF YOU WANT TO TRY IT.BUY A HAYNES REPAIR MANUAL READ THROUGH IT.THAT WAY YOU KNOW WHAT YOU HAVE TO DO TO REMOVE AND REPLACE WATER PUMP.
Sep 21, 2010 | 1999 Oldsmobile Alero
2004 Olds Alero - Just curious - does this
2.2 L 4 cyl timing chain. 3.4 L 6 cyl timing chain
Mar 02, 2010 | 2004 Oldsmobile Alero
My 1999 alero is overheating and engine coolant is leaking
hi, i dont know about the dipstick, but your overheating problem is most likely to be the thermostat...sounds like its stuck in the closed position,not allowing colder water to circulate, hence the overheating.......needs changing
Jul 27, 2009 | 1999 Oldsmobile Alero
1999 olds alero timing belt
2.4L engine dont have timing belt.it has a timing chain.fixing timing chain dont cost much.but the damage that occur when it broke.you probably got bent valves.damage piston heads.you can buy car if they dont charge arm and leg.you can repair timing chain your self for at least .$300.00.you have to buy timing chain.it come in a set.you get timing gears and tensioners.about.$190.00 and .$40.00 for timing cover gasket and seal.dealership going to charge you at least.$600.00 including labor.
Jun 25, 2009 | 1999 Oldsmobile Alero
2003 OLDS ALERO WONT START
Check to make sure the Security light in dash on right hand corner is not on. If it is on , your passlock is enabled. to dissable it turn your key on but not start it and wait for apx 10-15 minutes. this should re-set it.
Jan 22, 2009 | 2003 Oldsmobile Alero
Vehicle Parts & Accessories Logo
98 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
