Http://www.amazon.com/Dell-Workstation-Performance-Interlaced-Professional/dp/B008D3NKAS/ref=sr_1_1?ie=UTF8&qid=1366389036&sr=8-1&keywords=dell+precision+380
On the left side are different views. I am looking at the REAR view
At the Bottom, of the Rear of the computer, are 6 expansion slot openings.
Two of the expansion slot openings have an adapter card in them.
The other 4 are covered with an expansion slot cover. (Metal)
One of the adapter cards is a Graphics Card.
Looking at the Back of the computer, and from Left to Right;
there is a;
1) S-Video port
Black in color, round in shape
2) DVI port
White in color, parallelogram in shape
3) VGA port
Blue in color, parallelogram in shape
This article shows a graphics card with the same setup,
http://www.hardwaresecrets.com/fullimage.php?image=879
S-Video,
http://en.wikipedia.org/wiki/S-Video
http://www.hardwaresecrets.com/article/Video-Connectors-Tutorial/157/4
You can use the S-Video port, or the VGA port, or the DVI port; to connect a monitor.
However out of all three, the DVI port is the best.
VGA is Analog.
Your computer puts out a digital signal. (Digital video signal)
DVI is Digital Visual Interface. In otherwords - Digital.
Therefore DVI is the best.
http://en.wikipedia.org/wiki/VGA_connector
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Armed with the above information, can you clarify more about your problem?
For example;
Monitor cable has three prongs........
Using the above information, can you tell me what monitor cable it is?
Computer has two...........
Can you tell me where on the computer, you are trying to plug the monitor into?
Please post back in a Comment.
Regards,
joecoolvette
SOURCE: dell precision 3100 machine will not boot up
Hi there
The beep codes indicate that there is a problem with the system memory, it may have to be changed.
Thanks for using fixya!!!
SOURCE: I was trying to hook up 3 monitors on my dell
Take out the two last cards you added and boot again.
Then turn it off and insert only one card at the time to find which one is the faulty.
Good Luck!!!
SOURCE: i got a dell precision
i think you dont have proper power coming try to stabilize the power and try changing the ram slots if this does not work then i think you have blown your motherboard
SOURCE: dell precision 490 led 1 & 4 on
If you are getting no video at all, then we can use the diagnostic LEDs and the power LED to help determine the failure.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
