Question about Pioneer DEQ-7600 15-Band Car Equalizer
My screen is off
On my dsp screen is very low power to view
How do i repair dsp fw update altec Lansing imt810
First, there is NO screen on the boom box.
The issue is with whatever you have the speakers connected to.
Mar 08, 2015 | Altec Lansing Audio Players & Recorders
How do i turn off the dsp and run stereo mode?
Pressing the PROCESS button opens up the various screens that determine the signal path setup and that control processing parameters for the DSP modules: I/O, PEQ, XOVER, DEQ, DELAY, and LIMIT.
I/O
The I/O module sets up the signal routing inside the DSP from input to output. Press and rotate the SELECT encoder knob to choose between dual mono, stereo, bi-amped, or bridged routing options.
STEREO
STEREO mode routes the signal from both the A and B inputs through a single series of DSP modules. The parallel DSP modules process the A and B signals with identical, linked settings (only module "A" parameter settings appear on subsequent DSP module screens).
The manual is available at: http://www.behringer.com/assets/NU6000DSP_NU3000DSP_NU1000DSP_M_EN.pdf
Jun 02, 2014 | Behringer Inuke Nu6000dsp 6000-watt Power...
Can i connect a powered subwoofer to center channel pre-out connection inYamaha DSP-A1
Jun 14, 2012 | Yamaha DSP-A1 Receiver
Camera dsp error
Welcome to FixYa,
DSP means Digital Signal Processor and this is the part in your phone responsible for processing digital imaging.
The amount of image data gathered by camera nodes in WMSNs is very large. They need to be compressed before transmission. JPEG2000 is the image compression standard which has many advantages, such as high compression efficiency and high image fidelity. However, its high computational complexity makes it a big problem when using it in WMSNs. To satisfy the low-power and high image quality requirements of WMSNs, studies shows the low-power JPEG2000 realization on DSP-based camera node.Fixed-point LS9/7 wavelet is used instead of CDF9/7 wavelet to decrease the complexity of computation. embedded block coding is improved for high efficient DSP parallel processing.
Some experiments results show that the improved JPEG2000 leads to a great reduction in implementation time, and hence saves energy consumption of camera nodes.
But sometimes, in my experience, pulling out the battery and try to insert it again, will solved the issue.
I hope this information help you to resolve yuor issue.
Thank You for using FixYa.
Mar 04, 2011 | Cameras
My camera view finder shows"Check
Good day,
The CHECK DIAG appears in the view finder when the camera's automatic self diagnostic function detects an abnormality.
From here you must first perform error checking on your camera by doing the following:
Press the menu dial.
This will perform the error check on the Digital Signal Processing(DSP) and the Memory Circuits.
When no error is detected OK will appear.
If an error is detected it will be displayed next to DSP or Memory on the screen. Diag Error will also appear.
If Diag Error appears contact your Sony dealer!
What this means is that the camera is doing a routine check or has detected an abnormality with the system.
I hope it is just performing a routine check and there is nothing wrong with your camera!
Best of luck and let me know if this was useful!
Kind regards
Dec 01, 2010 | Sony DSR-500 Mini DV Digital Camcorder
When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Jun 10, 2010 | Canon PowerShot SD850 IS Digital Camera
How do i fix dsp camera error
The amount of image data gathered by camera nodes in WMSNs is very large. They need to be compressed before transmission. JPEG2000 is the state-of-the-art image compression standard which has many advantages, such as high compression efficiency and high image fidelity. However, its high computational complexity makes it a big problem when using it in WMSNs. To satisfy the low-power and high image quality requirements of WMSNs, the paper studies the low-power JPEG2000 realization on DSP-based camera node. Fixed-point LS9/7 wavelet is used instead of CDF9/7 wavelet to decrease the complexity of computation. embedded block coding is improved for high efficient DSP parallel processing. Experiments results show that the improved JPEG2000 leads to a great reduction in implementation time, and hence saves energy consumption of camera nodes.
Mar 03, 2010 | Samsung Alias 2 SCH-U750 Cell Phone
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
DENON AVR 2802 (NO SOUND)
If "Digital" sign blink on front panel, it means DSP do no start properly. If DSP do not start, main UC mute audio. Change IC, AT49LV002-70TC (IC 817 ) at DSP board (Denon P/N: 262 3010 006).
Jan 01, 2007 | Denon AVR-2802
Effect off
Dear Zforce, The Yamaha DSP A1000 has three different options of on-screen display. Try using the On-screen button on the remote control in order to remove the disturbing display. If this fails or if your remote control malfunctions then you should contact Yamaha for further assistance.
Oct 31, 2005 | Yamaha DSP-A1000 5-Channel Amplifier
Pioneer DEQ-7600 15-Band Car Equalizer Logo
32 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
