Question about Tools & Hardware - Others
Hole in kitchen wall. How do I fix it? - Tools & Hardware - Others
    New Friend:
First I would cut around the hole using a dry wall knife -I would make it a square. Then get a piece of wood ( 2" high and Then measure the length of the hole if it is 9" then you would need the wood piece to be 11" long.) Insert the wood piece inside the wall (hold on to it) and then drill using dry wall screws from the out side wall into the wood piece you installed. Then cut a piece of dry wall the size of the square you made and insert into the wall then screw into wood piece. Then take some joint compound and spread light over insert dry wall spreading on the old dry wall and let dry and then sand so it is flush with wall.
Posted on Apr 18, 2013
  • camillew81 Apr 20, 2013
    Thank you :0)
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Good answer I would also buy a can of knock down texture and spray it own to match the existing texture
Posted on Nov 23, 2014
How can i fix my freezer because iv pierced a hole in the wall?
You can't fix it if the hole in the wall has pierced the refrigeration tubing inside
Apr 26, 2014 | Refrigerators
Want to remove present dishwasher for replacement with a new one. How do you do it.
Most dishwashers are housed in a cabinet next to your kitchen sink.
Not knowing how exactly your machine is set up I will just advise you on common setup features and removal.
First open the doors to kitchen cabinet under the sink. If you see two hoses connected under the sink, they most likely are from your dishwasher. One is an inlet hose which would be connected to a water tap. The other would be a drain hose which would be connected via a clamp to the drain under your sink.
Turn off water tap to remove inlet hose. Unscrew or undo the clamp fixing your drain hose to drain pipe. Note when you remove the drain hose the hole to the drain pipe is exposed. You need to block this off as it will leak water when ever the sink is running. I normally get a plastic bag and twist it inside the hole and tape it off.
Next you need to locate the power cord and plug for the dishwasher. This is normally under the sink cabinet as well. However, check either side of the dishwasher. Sometimes they are behind the dishwasher.
Once you have disconnected the hoses, open dishwasher door. Look on the inside walls of the dishwasher. Some models are screwed into the wall of the cabinet so you need to unscrew machine. The screws go in either from the side walls or from the inside roof of dishwaser to your benchtop.
You need to also remove the kitchen kickboard if one has been installed infront of the dishwasher.
When machine is free open the diswasher door and grab either side of door and gently pull machine out. Have someone help you feed the hoses through as you pull out.
If the machine does not easily pull out check again for hidden anchor screws around the edges of the machine or even clamps which fix the hoses to the cabinet.
If you have issues pulling it out see if you can take some pictures and I will help you.
ash
Sep 11, 2011 | Dishwashers
I would like to put my cook top on an island in the centre of my kitchen how would i vent down thru a crawl space???
Get a downdraft cook top and drill a hole. Then run the piping to the outside wall of the house and drill again and run the piping thru to the outside. They make outside wall vents like dryer vents only bigger to accommodate the bigger vent pipe. Happy crawling. It will look and work great if you get a good stove. Do your research.
Sep 01, 2010 | Electrolux Icon Downdraft Ventilation...
Need to know how large a hole to drill into wall for manifold to fit no instructions came with my faucet set
If you can't find any documentation, the manly(easy) way would be to buy a hole saw set, find the part of the faucet that goes through the wall, and select the closet fit possible of hole saw that will fit the part. It's okay if the hole's a little bigger than the pipe because the cover plate will probably cover it up, but please double check before drilling that the hole really will be covered by the coverplate.
Oct 23, 2009 | Peerless Industries Peerless Wall Mount...
Range hood installation
you can reseal the hole with aluminium tape
you can use screws with metal flat washer that has a rubber backing
May 28, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Leaking by freezer door in bottom
your drain line is clogged remove back wall and trow hot water in hole please unplug unit
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Range unit stands too far away from wall
There are mounting plates that recess the plug in the wall. Hardware stores have them in the electrical parts department.
Apr 15, 2017 | Frigidaire FEF336BC Electric Kitchen Range
My krugs dolce gusto coffee machine will not 'switch on' when i press the 'on' switch ie no green light and no water heating. Fuse replaced, and power source checked. No preceding incident to damage...
not ideal but if you cant get a refund, remove the switch join the 2 brown wires together and insulate. poke back in the hole and cover the switch hole with tape. You can then use the socket on the wall switch to operate as normal. just done it and it works..... remember to turn it off at the wall after use. hope this helps.
Aug 21, 2008 | Kitchen Ranges
Tools & Hardware - Others Logo
251 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
