Question about Freezers
Caravell Tropicalized Chest Freezer will only cool to 12 degrees, need it to cool to zero.
I have a freezer that is a Caravell Tropicalized, says Nestle on the front, same as the ones in convenience stores for prepackaged ice cream. Problem is, it will only get to 12 degrees. I need it to cool to zero. It runs all the time and does not shut off. There is no ice build up around the compressor. What could this be?
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
  • 176 Answers
SOURCE: Used chest freezer not cooling
Slobberlips,
One of two situations has occured with your used freezer:
1: The unit freon needs to be recharged, this happens when you develope a leak in the freon coils, or the unit is old enough that the freon has reached it's usable potential.
2: The compressor may seem to run fine, but in fact, has an internal problem.
My suggestion, return the unit if you can, and walk the isles of your local Menards, Sears, or any other local vendor in your area, and see how much prices have declined for the chest freezer.
The initial investment for a new freezer will offset any problems you might have with any other used unit, and the warranty is always a plus if you do have problems with the new unit.
Hope this helps you out.
Posted on Feb 01, 2009
  • 31 Answers
SOURCE: freezer compressor running, but no cooling
If the compressor is running and there's no cooling, chances are you have a sealed system leak somewhere. Meaning the machine has lost it's refrigerant charge. Pretty much need a set of gages at this point and start checking for potential leaks.
Posted on Mar 14, 2009
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Is there an ambient temperature range outside of which the freezer won't work well? Will it go down to zero degrees?
    It seem ambient temperature will not affect so much inside temperature since any freezer has good insulation. Normally freezer will go down to below zero degree
    Oct 10, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
    I have an old Caravell CL200 which used to work ok. We haven't used it now for about 1yr and now trying to get it to go again. It just won't get cold enough what can be wrong?
    What could be wrong:
    compressor not running
    freon leaked out
    low on charged
    txv plugged
    dirty condenser
    these are some of the things that could be wrong
    hope this was helpful
    Mar 27, 2010 | Caravell 5.5 cu. ft. / 156 liter Chest...
    Kenmore Deep Chest Freezer
    Correct temperature for residential freezer for food is zero degrees Fahrenheit
    Jun 07, 2009 | Kenmore Freezers
    Temp
    jtcarlier
    20 Degrees is good
    I am happy to assist you!
    Neil
    PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
    Aug 24, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
    Feb 19, 2008 | Kenmore 22.7 cu. ft. / 643 liter Chest...
    Freezers Logo
    104 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    Are you a Freezer Expert? Answer questions, earn points and help others
