Question about Tacony LauraStar MAGIC i-S6 Ironing System JYLS-S6
LAURASTAR SPITTING WATER - Tacony LauraStar MAGIC i-S6 Ironing System JYLS-S6
DIRT DEVIL SPITTING OUT DIRT
Spitting out dirt usually means there is a clog restricting the airflow.
Jan 14, 2014 | Bissell Cleanview Helix Deluxe Bagless...
Iron will not heat up
See the causes and proceed according, fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord. Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
Sep 23, 2012 | Unknown LAURASTAR PREMIUM S3 Ironing...
My Black & Decker F1050 steanm iron started spitting ugly brown water out today...HELP?
Hi Barb,
It sounds like you have rust buildup in your iron.
I would try cleaning it inside with a mixture of hot water, vinegar, and baking soda. Put the hot water and vinegar mix in first then add the baking soda. The bubbles do the work (scrubbing bubbles...). Then, rinse thoroughly.
Then, never put your iron away until completely dry inside. Let it heat until you're pretty sure it is dry. If you don't, the rust will come back real quickly.
Hope this helps. If you appreciate my response, I'd appreciate your vote. Thanks,
Handie Andie
Apr 05, 2011 | Vacuums
My rainbow vacuum is spitting water
Where is the water coming out? If it's coming through an exhaust port, then it's gone through the motor, which will ruin the motor. If the motor does still run, stop using immediately and take it to a repair shop for thorough drying and possible cleaning. This must be done immediately to prevent rusting. It may already be too late, and a new motor will be necessary.
Mar 17, 2011 | Rainbow Vacuums
My steam iron is spitting out brown liquid and I've ruined several tops. I have a Rowenta Air GLide Stainless Steel Model #DZ 1700. I have misplaced the instruction booklet. It has a...
Run white vinegar through the iron over the sink with iron on high & steam button pressed down. This should dissolve any minerals that build up in it. Then run water through it over the sink to rinse the vinegar out.
Dec 07, 2010 | Rowenta Vacuums
Kenmore canister. Brush is turning but spitting all dirt under and out the back of the head. I guess the suction is very weak or non at all. What is reseting overload protector doesn't work. Haven't tried...
i would look to see if there is a clog. that would be the only reason that the power head would be spitting dirt in back of the power head. check the hose.
Oct 13, 2009 | Kenmore Vacuums
My sanyo power brush is spitting out dust instad of sucking it in
Check for a plugged hose or wand, this is a classic sign of a plug some where between the power head and canister.
Tom
Sep 24, 2009 | Sanyo SC-X1000P Canister Vacuum
Tacony LauraStar MAGIC i-S6 Ironing System JYLS-S6 Logo
53 people viewed this question
Top Tacony Vacuums Experts
JoeVacs
Are you a Tacony Vacuum Expert? Answer questions, earn points and help others
