Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Engine growing black smoke
Engine throwing heavy black smoke when mowing, slows but still there at idle
    Problem Solver:
  • 16 Answers
Usually this is a sign of oil being in the ignition chamber. Check the oil level, if too high drain and refill to proper level. Also if you have hills or slopes in your yard make sure that you are mowing up and down not across. If you must mow across the slope make sure to do it with the oil to the downward side. Caution if you do this too often the engine will be deprived of oil all together and seize up.
Posted on Apr 18, 2013
Testimonial: "Thank you, changed the oil. Now when I mow I can see my house,"
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
The engine could be running too rich. it could also be burning oil. Of course, if it's a two cycle engine, it's supposed to do that. If it's a four cycle, maybe someone mistakenly put a two cycle oil/gas mix in the fuel tank.
Posted on Jun 19, 2016
15hp Briggs Vanguard 1cylinder runs like it's on choke emitting black smoke. What can be wrong ?
The "black" smoke has me wondering... I would suspect that you may have a broken ring on the piston, or even ha hole in the piston.
Several weeks ago I found two of my neighbors mowing lawn and pumping out heavy clouds of smoke. I went to each of them and they told me they just filled the oil. They filled it up until it came out of the dipstick hole. This results in too much oil in the crank case and not enough air, so the engine forces the oil past the rings and then you are burning oil with the gas producing a large amount of smoke. I took my turkey baster and a can to each and removed the oil until it was at the proper level. Then I showed them the dip stick and explained that the oil level must be between the two marks on the dip stick. This situation of too much oil produced a huge amount of smoke, but the smoke was more white than black.
- Joe
May 11, 2014 | Tools & Hardware - Others
Last weekend my wife mowed on Friday evening and she says tractor ran fine, I went out Saturday morning and tried to start it and it made a banging noise and started backfiring and blowing black smoke, it...
Black smoke would indicate it is burning oil, Has the machine been working on an incline.? check valve clearences. My guess is that oil is somehow getting into the cylinder.
Jul 30, 2013 | Craftsman Garden
Why does my snowthrower engine bog down when throwing snow
It should slow down some as it is under a load. As long as it throws the snow far enough no problem. If not the speed governor may need adjusting. Make sure you have fresh fuel.
Jan 16, 2013 | Garden
Excessive white smoke out of blow by
Just letting you know that white is water, blue is oil and black is gas coming out of the exhaust.
Jul 20, 2017 | Cars & Trucks
Black smoke>fuel consumption>rough idle
Hi there:
Black smoke is caused by excess fuel that has entered the cylinder area and cannot be burned completely. Another term for excess fuel is "running rich." Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a fuel odor.
How did the fuel get into the cylinder in the first place? Some of the causes of excess fuel are a carburetor that is out of adjustment, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or computer sensor. If black smoke is present, check the engine oil as in the white smoke example to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil. Call your mechanic and advise him of what you have found.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Mar 04, 2012 | Cars & Trucks
330 excavator with a c9 cat engine, heavy SMOKE
Why did you do all of the engine work? Due to the same problem? Have you ran an ET on it to check for codes ?
Feb 25, 2010 | 2006 Lamborghini Diablo
Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
Sep 11, 2009 | Briggs & Stratton Garden
Husqvarna yth1848xpt with a kawaskie 20 hp puffs black smoke
I had the same problem with my YTH1848XPT . Believe it or not it is simply a dirty air filter....you must remove the filter and blow it out with an air compressor...or better yet replace it. you can not clean it well enough without the force of the air compressor. Mine works great now.
Jun 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Black smoke on acceleration diesel x-type jaguar
can anyone tell me where the intercooler is on a 05 plate jaguar x type 2.0 diesel thanks
Dec 07, 2008 | 2005 Jaguar X-Type
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
197 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
