Question about Brother HL6180DW - HL-6180DW Wireless Laser Printer
Black line down left side of paper - Brother HL6180DW - HL-6180DW Wireless Laser Printer
  • 320 Answers
SOURCE: old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Posted on Jan 24, 2009
  • 133 Answers
SOURCE: solid black line at the left side of paper after reset the drum
Try moving the blue panel to clean the drum after you install the toner.
plus before you do that, you need to clean up your drum by using the duster.
Posted on May 22, 2009
SOURCE: dark line down the left side of paper - changed
When you say changed cartridge. Do you mean toner? It's much more likely the drum that's causing the problem.
Posted on Jun 25, 2009
prashanthcl
  • 460 Answers
SOURCE: black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Posted on Aug 22, 2009
Testimonial: "This has been extremely helpful .. many thanks"
  • 72 Answers
SOURCE: When I use the paper tray I get a black line the
Align the paper guides with the paper.
Posted on Aug 31, 2009
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Black line on left side of paper
I forget the terminology but I believe there's either dirt or a sheet of paper on an internal roller.
You might try here for HP help.
Aug 12, 2012 | HP LaserJet 1300 Printer
A Solid black line down the left side of the page
It could be 2 things...
1. Your scanner glass is dirty...open the doc feeder and clean the glass. probably Wite-Out.
2. A segment of your scanner assembly lamp is burned out. Not good, uneconomical to repair.
Jan 21, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
A black line is printing on the left side of the
Pull out the toner cartidge, lift the flap and look at the drum, it should be clean. you will have to buy a new cart to fix
Jun 03, 2009 | HP LaserJet 1300 Printer
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
A Dark Vertical line appears 1 inch into the left side of scan
Most Mustek scanners have a black inside cover on the lid, this can give a black line down the side of the job.
ether cover the inside of the lid with white paper or place a bigger sheet on top of the sheet to be scanned!
Jan 24, 2009 | Mustek A3 USB Flatbed Scanner
Lines down left side of paper
replace the Black PCU
http://www.websitetoolbox.com/mb/copierquestions
May 15, 2008 | Ricoh Aficio CL2000N Laser Printer
Black line
take out cartridge, look at he inside of machineis there toner on the left side of a thin glass, look at the fuser ( where it gets hot) are the rollers O.K. ?
Nov 27, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Brother HL6180DW - HL-6180DW Wireless Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
