Question about Toro Power Lawn Mower
Repair manual for toro "26624"
The blade will not engage when lowering and raising the drive bar
carolinabeck
SOURCE: my toro mower disingages the blades after it runs for awhile
ik ben carolina beckers en ik heb met jaak coppens iets gaan drinken
Posted on Aug 08, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
vetteman3002
  • 2299 Answers
SOURCE: I HAVE A TORO SP
It sounds like the cable still needs more adjustment. The cable needs to be tighter. This is going to be hard to explain by typing. But I will give it a try. When you pull the handle in about 1/2 way mark the place where the lever on the drive motor is at. And take the cable loose and reattach the cable back to the mark that you made previously. So when the bar is released, it is like it is pulled in half way now. I hope that this makes sense. Let me know if I need to try to explain more.
Posted on Nov 12, 2010
  • 6468 Answers
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Posted on Apr 12, 2012
  • 6468 Answers
SOURCE: toro walk behind runs but dies when you engaged blades model# 30112-90901 kawaski fb460v motor
Posted on May 15, 2012
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Troy bilt lawn mower
sounds like wrong belt you raise it belts tighter lower belts looser or the tensioner has come loose
Jul 13, 2013 | Garden
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Toro 1991 42 inch mower doesnt cut even how do i
The blades should be a simple bolt on, how ever there are no adjustments at the blade. Your adjustments are on the swing brackets that raise and lower the deck.
Apr 26, 2010 | Toro Lawn Mower With Toro Power Tools
Blade won't engage - mower starts and propells itself, but when the yellow arm is pulled and lowered to engage the blade, nothing happens.
The blade is probably belt driven, and the belt is either broken, need adjusting, worn that bad, or there is a pulley problem. Get it in the air and check that the belt tightens. It will not be completely tight, there should be a tiny bit of play when engaged.
Mar 29, 2010 | Toro Lawn Mower With Toro Power Tools
Model #20064 wheels do not turn when you squeeze the bar to engage them. The pulley under the plastic guard spins but not the wheels.
Have you observed what happens under that plastic guard when you squeeze the bar? Do you feel any resistance at all when you sqeeze the bar? The reason I am asking is because there are a number of reasons why this is happening. The drive gearcase is actuated by a spring loaded arm that engages the drive gear to the spinning gear attached to the pulley. A good way to test this is to disconnect the spark plug, raise the mower just enough to lift the wheels off the ground, engage the arm and spin the pulley by hand; if the wheels move then it most likely is the drive cable...if the wheels do not move, it is the gearcase. On a rare occasion it could be the belt is old and stretched out, you can test that easily as well...start the lawnmower, raise the wheels by pushing down on the handlebar and engage the drive by squeezing the handle, if the belt is stretched out, the pulley will move intermittently or not at all.
Hope this helps!
Nov 05, 2009 | Toro Lawn Mower With Toro Power Tools
Rider cutting uneven
check and see if you have a bent blade. If bent replace. If the blades are not bent then you need to check the levelness of the deck. You can measure the distance from the blade to the ground on all the blades. Make sure you are on level ground. If one set of blades is higher or lower you will need to level the deck. Refer to you owners manual. If no owners manual there is probably some hangers that are threaded and has a nut on it. Loosen one to lower and tighten to raise. Only do one side.
good luck
roundo4
Aug 30, 2009 | Toro Lawn Mower With Toro Power Tools
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Power Lawn Mower Logo
62 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
