Question about Kenwood KM300 Chef Stand Mixer
Dough hook stuck in machine
I have a Kenwood mixer KMC510 and am now on my 2nd machine because the dough hook became stuck in the first one and the unit was replaced. Now after only a few uses the same has happened again. At first the hook went in OK but it has become increasingly tighter with each use and now I cannot remove it to wash it.
I am only using half the amount of dough that the instructions say is the maximum and am following Kenwood's instructions to the letter.
I have also had some problems with the 2nd machine with the head lifting up during kneading.
Can you please help? I need the machine to make the family's bread on medical grounds and am therefore loathe to be without it for any time.
  • JabBerWok Mar 11, 2009
    Thanks for that but the machine comes with a plastic 'splash guard' to prevent such problems and has only been used 4 times at the most.
    I did, after some struggle, get the dough hook out and it appears that the end that fits into the machine is getting scored at the top end by something.
    I will try the oil though.
    We are planning to get it looked at by an approved repairer and if that fails then it goes back from whence it came!!
  • 135 Answers
Hi. Is it possible that some of the dough or flour you are mixing has made it's way into the attachment point with each batch, and therefore gumming it up progressivley ? Carefully lay the mixer on one side, being carefull not to lay it on the side mixer controls. Use a rolled up towel to support the head, this will make it easeir to see the attachment point. If there's a buildup of flour, wet it with warm water and a little liquid soap, until it softens, remove the attachment and clean the areas of contact. Apply a bit food oil to the hook before using next time.
Re: your second mixer The head locking pin may also have flour in it. This would inhibit the movement of the locking mechanism along it's guides. You may have to do some disassembly to get it cleaned out. After cleaning put a drop of regular oil on the moving parts. Be sure to clean the recess that the pin fits into as well.
If that's not your problem, then the pin may be worn enough to not fully engage.
If I have assisted you, please rate my solution. Good luck! ricardok45
Posted on Mar 11, 2009
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
Apr 29, 2017 | Kenwood Kmix Kmx50 Stand Mixer, White
Dough hook
Hi, the new style tools do not fit old style mixers, yours probably had the small circlip on the shaft, the new ones dont have this, and it's this what held your tool in place
Jan 05, 2014 | Kenwood KM400 / KM410 Chef Classic Stand...
Cant releace the dough hook from my kenwood chef. what can i do?
hi the lock nut on the shaft may have been loose allowing the shaft to screw into the dough hook you hve to unscrew the hook out of the shaft then unwind the nut down so you can release the shaft. other problems can occur if the retaining clip has unseated and jammed itself into the planet hub. this is more difficult and a kenwood agent would be consulted see www.kenwood.co.uk for nearest agent.
Feb 09, 2011 | Kenwood KM300 Chef Stand Mixer
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
The dough hook is stuck in the beater shaft of kitchenaid mixer
It sounds like it got overloaded when you last mixed dough. It will only come off the way it went on. If it has been bent on, it may need a bit of gentle encouragement.
Jun 15, 2009 | KitchenAid KSM50PR Professional Series...
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Dough hook plastic guard is broken
The spare part number for this shield is KW434794
Jan 31, 2008 | Kenwood KM800 Major Classic Stand Mixer
Kneading Blade Stuck on Kenwood Mixer KM300
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Jan 16, 2007 | Kenwood KM300 Chef Stand Mixer
Kenwood KM300 Chef Stand Mixer Logo
509 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
