Question about Toro Power Lawn Mower
Repair manual for toro "26624"
The blade will not engage
carolinabeck
SOURCE: my toro mower disingages the blades after it runs for awhile
ik ben carolina beckers en ik heb met jaak coppens iets gaan drinken
Posted on Aug 08, 2009
harlan301
  • 205 Answers
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
Posted on Oct 13, 2009
  • 6468 Answers
SOURCE: toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Posted on Apr 12, 2012
  • 6468 Answers
SOURCE: toro walk behind runs but dies when you engaged blades model# 30112-90901 kawaski fb460v motor
Posted on May 15, 2012
  • 4 Answers
SOURCE: Toro groundsmaster 120 engine kills when engaging blades at switc. Clutch? clutchWhat's your problem?
unplug wire form temp sensor on right side of engine and then try to engage pto
Posted on Nov 09, 2012
Blades won't engage on my toro ss 5000 zero turn mower
for any ride on machine that the blades don't engage id start at looking at occupancy seat switch , these are most times the culprits then if that's ok I move on to the actual engage switch and then on to clutch as last element
don't forget that past 2013 mfg machines operator must be in seat and weight over 80 lbs , the clutch pedal must be depressed and transmission not in reverse to engage the blades on a consumer grade lawn tractor (thank the CSB for that )
Aug 27, 2015 | Toro Garden
Toro tractor model 14AP80RP744. Motor shuts off when engaging blades
Either not enough power to spin the blades, because the engine needs maintenance/repair, or the blades are jammed. Either way take it to a competent repairman. It's too dangerous to mess with it yourself.
Oct 08, 2014 | Garden
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
Toro repair manuals
I have this same problem on my 36 in toro pro line sfs i ohmed the clutch the wire the safety switches and the PTO engagement switch all checked out good if u find any thing let me know the clutch its a adjustable clutch and its supposed to be set at .018 at all three springs there will b a slot that's where u check that but. U can get a multimeter and test the clutch by putting it on ohms and hooking up on both sided of the plug once u have unplugged it.the clutch should ohm out at like .003 or .004 max if more the clutch is shorted out
May 07, 2013 | Toro 52" Cut Wide Area Walk Behind Lawn...
Toro 20056 engine runs but the cutting blade does not engage
you have a Toro and for whatever reason it is listed in the flat panel TV area.
Aug 29, 2012 | Televison & Video
Toro 52 inch walk behind blades won't engage
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
Blade won't engage - mower starts and propells itself, but when the yellow arm is pulled and lowered to engage the blade, nothing happens.
The blade is probably belt driven, and the belt is either broken, need adjusting, worn that bad, or there is a pulley problem. Get it in the air and check that the belt tightens. It will not be completely tight, there should be a tiny bit of play when engaged.
Mar 29, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 216 triple mower . the electric clutch will not switch off leaving the blades in drive all the time . can the clutch be striped down and repaired
the switch where the blades are engaged try to unplug from the back of the switch if the blades are still engaged after you unplug the switch then the clutch is at fault. If the blades disengage and shut off after you unplug the switch then all you need is the switch!! The clutch can be repaired but the parts are very hard to get if you can even find them!
Aug 26, 2009 | Garden
Toro Power Lawn Mower Logo
27 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
