Question about Pool & Spa
My pool motor does not turn when I turn it on it just makes a humming sound. Can it be fixed ? Century LASAR Pool/Spa motor model # SD-20-2N11CD
  • 5,089 Answers
Probably the capacitor is bad.
It can be replaced.
Do not let motor hum, because motor is getting hot and will burn up pretty quick, or trip the reset.
Call pool company.
Motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
Posted on Apr 19, 2013
MOTORWIZJ
  • 1338 Answers
SOURCE: Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Posted on Dec 28, 2011
  • 760 Answers
SOURCE: I have a proline pool
C. MOTOR HUMS, BUT DOES NOT START—
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
http://www.haywardnet.com/products/Manuals/pdfs/manual113.pdf
Posted on Aug 17, 2010
  • 93 Answers
SOURCE: I have an A.O.Smith Century Pool & Spa motor
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Posted on Jun 20, 2009
SOURCE: I HAVE A CENTURY LASAR POOL/SPA MOTOR W/ A HIGH
Faulty centrifugal switch, internal, faulty, temp sensor, internal, faulty start run capacitor (If used). bad brushes, (If any) Faulty Winding.
Posted on Feb 03, 2010
  • 990 Answers
SOURCE: pool-spa control problem
You will probally have to replace the air tube that runs from the spa to the equiptment. With time you will build up condensation in the tube and that will cause the problem you describe.
Posted on May 14, 2010
Testimonial: "thanks, i will try that"
How to replace seal on century lasar spa motor
split the motor from the wet end then take off the cover to the impeller remove screw for impeller backwards thread might have to hold the shaft on the back of the motor then unscrew the impeller regular threads separate the motor from the backing plate replace seals then reverse process
Jul 05, 2014 | AO Smith A O Smith Motors Century 1hp 115v...
I have century lasar pool/spa motor bn50 115volts 16.4/4.4amps 1.5hp 2spd runs on lowspeed but will not run on high speed can it be repaired or what?
I'd start by checking the relay that controls the motor first. Put a meter on it and verify that the high speed terminal is getting voltage. If not, it is the relay or something other than the motor. If the high speed terminal is getting voltage but not kicking on, a fix is possible, but you may want to weigh that against the price of a new motor.
Aug 16, 2013 | AO Smith A O Smith Motors Century 1hp 115v...
Capacitor type
take capacitor to electric supply store to match up
Apr 20, 2012 | Century New Magnetek Pool Spa Pump Motor...
I have a proline pool pump model # SD-15-1N11CC and it worked fine until I back washed my pool and now it stopped working. It makes a humming noise and nothing else.
Check for:
Aug 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Installing a replacement pool pump and motor
there is a green screw and two other screws. green is ground and the others two are universal, it's not like a DC motor.
Jun 02, 2010 | Smith AO Pool Pump Motor
Pool & Spa Logo
276 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
