Question about Panasonic DP-C264 Color Copier
Panasonic dpc264 jams the colour photocopy but not black and white
When i make a black and white copy it works fine. but when i do a colour copy it jams the paper.
  • 33 Answers
SOURCE: Panasonic DP 2500 J81-J82 paper jam
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
Posted on Mar 05, 2008
  • 18 Answers
SOURCE: Paper Jam
first try to eliminate the finisher. turn off main power switch and unplug from the power outlet. Now unplug the finisher cable from the rear of the copier, then slide the finisher out of the way. Check to see if you still are having jamming issues. if not then yes the issue is with the exit of the paper or the finisher.
Many possibilities try to narrow it down.
Good Luck
Posted on Nov 27, 2008
  • 990 Answers
SOURCE: can not print and photocopy on panasonic dp-2330
Hello sir; Check the paper path where the paper stuck,there have a senser , may be come off or out of track, just put it back to right place.
Posted on May 15, 2009
  • 224 Answers
SOURCE: panasonic dpc264 error u29 what is this
u 29 requires you to change drum unit, as this is a general instruction, the control panel would say which drum it is. there should be instructions in the front cover, if not there usually is supplied with the drum depending on your supplier, but yes one of the drums needs two be replaced.
Posted on May 04, 2010
  • 224 Answers
SOURCE: Our Panasonic FP-7722 photocopier is printing
it could be the developer dropping toner or the cleaning section clogged up. i would recommend a technician.
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white.
programs recorded from tuner are now in black and white
Frank, try new cables and inputs if you can, cables or inputs could be faulty.
Apr 01, 2016 | Panasonic Televison & Video
Toshiba colour photocopier jamming when copying or printing in colour. error code cee0. O k in black
"CEEO" indicates Transfer belt position detection abnormality.
U need to service the transfer belt unit, especially the reflection tape and sensors.
Apr 01, 2011 | Toshiba E-studio 281c Copier
Cannot photocopy document
hi...
the colour catridge has nothing to do with the black and white print out if it is a text document. please check you have placed the black catridge propely and in correct positon. and try printing out the pages
Jul 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
I have an epson DX4050. I currently have a full blank ink cartridge but have one empty colour catridge and 2 other colour catridges which are running low. I want to photocopy a peice of document in black...
First, using B & W to copy a photo will cause large black blotches.
B & W are actually made up of shades of Black. To get the best quality for a B & W photo, switch to "Grayscale"
Next, is the black cartridge full? Are you using any type of refilled (absolutely worst possible choice) or a third party cartridge (second worst possible choice).
Feb 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
HOW TO TAKE PHOTOCOPY IN EPSON STYLUS CX 2800
place the document in side, by the left hand top you will see copy, with two different buttons one is coloured and the other, click on the coloured to get coloured document and click on the black to give you black and white, just once and make sure there is paper in the feeder, thanks
Jul 13, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Canon FC 120 Photocopier. Red Paper jam light keeps flashing
hi,clean any sensor & clear any hide misfeed sheet.send me result.
thank you.
May 31, 2009 | Canon PC-160 Black and White Copier
Panasonic DP-C264 Color Copier Logo
126 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
