Question about Bladez Fitness X350P Homecrosstrainer
How to adjust magnets X350p - Bladez Fitness X350P Homecrosstrainer
I hav an edge 426 magnetic bike an there is no resistance/tension. how do i correct this?
Hi There, does this machine adjust resistance with a turn knob or via electronic buttons? If it's a crank or turn style resistance adjustment, this is usually positioning a pair of magnets near a spinning disk inside that front cover. Electrical "magnetic" resistance units use an Eddy-Current brake system which also produces a magnetic field near the spinning disk, either way the magnetic attraction properties will stop any metal (conductive) disk from spinning, or at least provide a resistance to it spinning ;o) Crank tension units have a cable and pulley system inside. Good Luck
Mar 08, 2016 | Exercise & Fitness
SPACE MATE
please proceed. and fix it. God bless you
Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Mar 29, 2013 | Exercise & Fitness
Belt tension won't release to zero
please follow the next steps. God bless you
Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2 Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • 3 Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4 Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5 Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Dec 04, 2012 | Bladez X350P Elliptical
    Bladez elliptical
    see the steps and fix it. God bless you
    Adjust the magnet with bolt attached there are loose, tight very well and ready the resistance is the main parts that need repair,
    However if the resistance is faulty, you must test again the magnet from the refrigerator by attracting or repeled, if do not pass this test replace it buying small cheaping from home depot or similar.
    GoD BLess you
  • 1 Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • Sponsored Links
  • Read more: How to Fix an Elliptical Machine ' eHow.com http://www.ehow.com/how_4681374_fix-elliptical-machine.html#ixzz2DLrv9YSH
  • Sponsored Links
    Nov 25, 2012 | Bladez X350P Elliptical
    Too difficult to use even on easiest setting
    ask your persona trainer what he recommend you, in base to your need physical.
    God bles you
    Jul 16, 2012 | Bladez Fitness X350P Homecrosstrainer
    Epic E 950
    1= the resistance is adjusted magnetically.
    2=the resistance is not adjusted o.k
    3=check the bolts that secure the magnet
    4=if there are slips, the resistance will slip,adjust
    5= test the magnet, with the magnet withe the refrigerator. for attraction +resulpusion. and replace if do not pass the tests.,because they are de-magnetized.
    God bless you
    Jul 12, 2012 | Epic E 950 Elliptical Resistance...
    Nordictrack Asr 1000 Elliptical Resistance Motor
    1) Adjust the cable tension
    2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
    God bless you
    Jun 10, 2012 | Exercise & Fitness
    Adjustment knob not working
    1) you must tight the bolts the mechanism
    2) if the magnet is loose will not work,do it
    3)check the bolt, and adjust it.
    4) Check the magnet againt with the magnet from refrigerator for; repel or atraction, otherwise is faulty.
    God bless you
    Jun 01, 2012 | Exercise & Fitness
    Schwinn 150 is hard to pedal how do I adjust the tension
    LUBE the pedal, Retight the bolts with some wrench.
    2) The tension adjust the magnet with the bolts, if there are loose retight the magnet. Test the magenet with the magnet refrigerator for to repell or attracted, change if necessary.
    sincerely. God bless you
    May 05, 2012 | Schwinn 150 Upright Bike
    My car Navigator system is Binatone Carrera X350P I was told @ time of purchase that upgrading of maps was free. The web site refers one to TomTpm - with maps for sale - even when opened under Free Maps.
    The software for Binatone Sat Navs is not free. You could always contact the retailer if they mis-sold this item to you. Alternatively, for an update call/email Binatone and they will send an SD Card to you for around £32.99.
    Feb 23, 2011 | Toymax Binatone Carrera X350 Car GPS...
    Bladez Fitness X350P Homecrosstrainer Logo
    Top Bladez Exercise & Fitness Experts
    gbob59
    ray gallant
    Tom Chichester
    Are you a Bladez Exercise and Fitnes Expert? Answer questions, earn points and help others
