Question about Kenmore 97912 Top Load Stacked Washer / Dryer
I have a Kenmore Stack Washer/Dryer Model # 97912. The problem is with the washer. I set my washcycle the basin fills but will not agitate. I have to adjust the control and set it at the point in which it will drain. The machine will then spin and drain. Once done, I again have to manually set the control to refill for the rinse cycle. And again to spin and drain. Any help would be greatly appreciated. Thank you
  • criviello
    criviello Apr 22, 2013
    I was hoping someone on this site was able to help me fix my my problem inexpensively before I paid a technician to come out and look at it. Thank you to those that yook the time to view my question
My Kenmore stack washer/dryer 110.88752793 the washer fills and agitates then will not always spin. Then if I let it set sometimes for a day it will just start and spin on it's own. Sometimes I can reset...
Could be the molex connection to the timer is loose or corroded. Inspect the timer and make sure that connection to it is clean and tight. Vibrations makes the plug back out.
Dec 30, 2009 | Washing Machines
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
likely the lid switch is bad - if not the ECU/timer is.
May 28, 2009 | Kenmore 43042 Front Load Washer
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer/dryer model#11098752790
Check your lid switch ,if its not engaging replace it.
Jun 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Sheet caught under agitator
the agitator comes out..... by simply taking off the cup that holds fabric softner, just pull upward if needed wiggle and pull. under that you will see a raised plastic piece the raised plastic pc is pulled of by using a pliers pull upward under this you will find a bolt 1/2 or 9/16 socket remove bolt and pull out agitator same way by wiggling and pulling upward
Jan 08, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing machine doesn't respond to the low, medium or high water settings and keeps filling. Spin and drain cycle works. Won't stop filling and doesn't go into the wash cycle.
My GE WSM2780DAWW stack set dryer and washer was encountering the same problem (water kept filling up not stopping). I saw this page, but the SOLUTION described didn't really draw a picture for me.
Here's how I fixed the leaking washer. Sitting in front of the washer I removed two small screws on the bottom left and right of the front panel. Then sliding the front panel DOWN, it comes off. This allows a view into the machine. Around the LEFT side of the wash basin you will find a white tube. This tube is about the diameter of a pencil. My tube was not attached, and when the wash basin filled up past the point where it should stop, water came out. Reaching around the side of the wash basin with my left hand I could feel where the white tube was supposed to connect properly. Then I attached the white tube. This fixed the problem.
I left the front panel off for a day to make sure it didn't continue to leak and also for the area to dry out.
Jun 17, 2006 | GE WSM2780DWW Unitized Spacemaker Washer...
Kenmore 97912 Top Load Stacked Washer / Dryer Logo
83 people viewed this question
Sal De
 Brian Main
Brian Main
