Question about Android Apps
How to set the right temperature - Android Apps
    New Friend:
    Problem Solver:
  • 12 Answers
Need better video
Posted on Apr 18, 2013
Why can you turn dryer to a higher temperature on different settings
Some settings will not function at higher temperatures. Things like delicate or permanent press will not turn out right at high temperatures.
Jan 03, 2017 | Dryers
How do I set the temperature on a true refrigerator model GDM-26EM?
40 degree is a perfect temperature for produce if its lower that stuff will turn brown. Maybe you thermometer has failed. Go to the food store and get a red stick and put it in there. Then adjust with that temperature indication. Hope this helps and good luck.
May 09, 2014 | True Refrigerators
Where is the reset button on my electrolux fridge?
Good Afternoon Friend, thank you for your post! I see the temperature in your Electrolux refrigerator is too warm and would like to know how to reset it. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the right side wall. With this information I can better address the issue at hand. In the meantime, please double check the temperature control. If the temperature is set too warm, set control to a colder setting and allow 24 hours for temperature to stabilize. Thank you - Z.
Apr 22, 2014 | Electrolux Refrigerators
Does not heat to right temp.
You didn't give any specifics which makes it difficult to respond because there are many reasons why a Traeger grill might not heat to the right temperature.
One of the most common is problems is the outside temperature. If it's hot, the Traeger may overheat unless it is tended constantly. When it's cold, the Traeger may not get as hot as it should based on a normal setting and you may have to set it higher to reach the temperature you want.
Other reasons could be mechanical in that the hot rod may not be keeping the firebox as hot as it should or the fan may not be running as hard as it should to get the temperature to the right setting.
If your firebox has not been cleaned, ash will effectively insulate the fire, preventing heat from building up in the cooker.
Some people clean their Traeger thoroughly after every use. Some never clean theirs until something goes wrong. I clean mine after every 4-6 uses, depending on how long my cooking sessions have been.
If I've been cooking pork shoulder low and slow for many hours, I'll clean it more often than if I had grilled steaks multiple times for 15-20 minutes at a time.
Likely, if you're cooking in "normal" outside temperature of 60-80 degrees, your Traeger should be holding fairly close to the temperature you've set. If it's not then you may have a fan or hot rod problem and you ought to contact Traeger to set what they suggest.
Mar 03, 2014 | Traeger Industries BBQ075 All-in-One Grill...
Convair instructions
Maybe that 30 degrees you are seeing is the room temp
Mar 02, 2018 | Heating & Cooling
Lower thetermostatv temprature to 66. it's set to 77 right now and doesn't go lower
Question is not clear.
Add a comment and say what you want to do.
You have 240Volt electric water heater.
Lower thermostat is set as low as it can go at 77.
But you want water temperature set to 66?
First thing to remember is that water heater thermostat settings are approximate since they read temperatures through the steel tank wall.
Second thing is that thermostats for electric water heater are generic, and are not made for lower temperature range settings. This is probably since most people complain that water is not hot enough.
I'm looking at a generic lower thermostat from Lowes right now. The low temperature setting is 90 degrees F.
Looking at some older thermostats from a drawer right now: one does not have a lower temperature mark, the other is a Reliance with low temp of 95, the old craftmaster goes down to 80.
So I don't even have a thermostat that goes as low as the one you have, except for gas water heater thermostats that traditionally can be set to 50 degrees for vacation mode to prevent freezing.
More thermostats can be seen on following link:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Jul 12, 2011 | White Rodgers 0754-1 Electric Water Heater...
How do you lower the temperture in the refrigerator?
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Jun 23, 2011 | Kenmore Refrigerators
    The heat in my 2006 grand prix will not get hot. We replaced the thermostat and got nothing. So I got the radiator flush and force filled again. Still nothing. Temp of the motor still gets to the middle,...
    Are the 2 tubes that go to the heater core getting hot? If so, then the blend door is not opening to allow heat to get to the cabin.
    Possible vacuum motor problem, either disconnected, or the controller for the blend door is broken is likely problem.
    Troubleshooting by Symptom Poor Heater System Performance CAUTION
    Check all fluid levels and adjust as needed, before operating vehicle for extended periods at idle.
    1. Start the engine.
    2. Idle the engine until the thermostat opens (upper radiator hose will be hot) Is the engine at normal operating temperature (approx. 200° F)? If yes, go to the next step. If no, go to step 16.
    3. Set the mode selector to FLOOR mode.
    4. Set the heater control selector to the warmest temperature setting.
    5. Set the blower speed the lowest setting.
    6. Carefully feel the inlet and outlet heater hoses at the heater core. Is the inlet heater hose significantly hotter than the outlet heater hose? If yes, go to step 14. If no, go to the next step.
    7. Set the mode selector to PANEL mode.
    8. Select the maximum blower speed.
    9. Select the warmest temperature setting.
    10. Place a thermometer into the center I/P PANEL air outlet and affix a second thermometer to the heater core outlet heater hose.
    11. Record the temperature at the center I/P PANEL air outlet and at the heater core outlet heater hose. Are the two temperature readings about equal? If yes, go to the next step. If no, go to step 13.
    12. Inspect and repair the cowl, cowl area, recirculation door, and the HVAC evaporator/heater core case for cold air leaks. Repair any problems found, go to step 17.
    13. Inspect the temperature door operation. Repair any problems found, go to step 17.
    14. Turn OFF the engine. Back-flush the heater core. Start the engine. Select the FLOOR mode and the lowest blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Is the inlet heater hose feel significantly hotter than the outlet heater hose? If yes, go to the next step. If no, go to step 17.
    15. Replace the heater core. When the repair is completed, go to step 17.
    16. Check for low engine temperature problems, Repair or replace as needed, go to step 17.
    17. Operate the system in order to verify the repair. If the system operates properly, the repair is complete. If the heater still does not work properly, repeat the entire procedure.
    Air Door Actuators/Motors Removal & Installation Recirculation Actuator To Remove:
    1. Remove the right lower instrument panel (I/P) insulator.
    2. Remove the glove box assembly. Recirculation actuator (Typical) gm-10-00-3695.gif
    3. Remove the mounting screws and recirculation actuator from the HVAC module assembly.
    4. Disconnect the recirculation actuator harness connector.
    To Install:
    1. Align the recirculation actuator slots with the flats on the actuator door shaft.
    2. Install and secure the recirculation actuator on the HVAC module assembly with the mounting screws.
    3. Connect the recirculation actuator harness connector.
    4. Install the glove box assembly.
    5. Install the right lower I/P insulator.
    6. Calibrate the recirculation actuator.
    Mode Actuator To Remove:
    3. Remove the mounting screws and mode actuator from the HVAC module assembly.
    4. Disconnect the mode actuator harness connector.
    To Install:
    1. Align the mode actuator slots with the flats on the actuator door shaft.
    2. Install and secure the mode actuator on the HVAC module assembly with the mounting screws.
    3. Connect the mode actuator harness connector.
    6. Calibrate the mode actuator.
    Air Temperature Actuator Right Side To Remove:
    2. Remove the glove box assembly. Air temperature actuator (right side) gm-10-00-4356.gif
    3. Remove the mounting screws and right air temperature actuator from the HVAC module assembly.
    4. Disconnect the right air temperature actuator harness connector.
    To Install:
    1. Align the right air temperature actuator slots with the flats on the actuator door shaft.
    2. Install and secure the right air temperature actuator on the HVAC module assembly with the mounting screws.
    3. Connect the right air temperature actuator harness connector.
    Left Side To Remove:
    1. Remove the left lower instrument panel (I/P) insulator. Air temperature actuator (left side) gm-10-00-4357.gif
    2. Remove the mounting screws and left air temperature actuator from the HVAC module assembly.
    3. Disconnect the left air temperature actuator harness connector.
    To Install:
    1. Align the left air temperature actuator slots with the flats on the actuator door shaft.
    2. Install and secure the left air temperature actuator on the HVAC module assembly with the mounting screws.
    3. Connect the left air temperature actuator harness connector.
    4. Install the left lower I/P insulator.
    5. Calibrate the mode actuator.
    Oct 18, 2010 | 2006 Pontiac Grand Prix
    Install trim and adjust the thermostat on a Grohe shower faucet
    Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
    Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
    Best temperture to keep up right freezer and a different refrigerator
    Freezer temperature for storage depends on the type of product you are putting into it. Ice Cream as an example must be kept below zero °F as also with bread dough type products. Refrigerator temperatures are best kept below 41°F.
    Jun 30, 2008 | Refrigerators
    Android Apps Logo
    Top Apps Experts
    Brett Duxbury
    Brett Duxbury
    Are you an App Expert? Answer questions, earn points and help others
