Question about Sewing Machines
I cannot adjust my tension. Have had this machine for over 20 yrs & no problems. I have tried different needles, different thread, re threading several times, tried adjusting bobbin case &
I cannot adjust my tension. Have had this machine for over 20 yrs & no problems. I have tried different needles, different thread, re threading several times, tried adjusting bobbin case & top tension. HELP
  • Sewing Machines Master
  • 7,365 Answers
Try this suggestions
take the thread out of the needle, now hold the needle thread in
your right hand,, with your left hand hold the thread above where it
goes into the top tension guide and floss the tension guide,,like you
would your teeth, and see if that stops the what's called bird nest on
the bottom of the fabric.
also clean under the needle plate and in the bobbin area for lint
make sure the needle is inserted correctly
make sure the bobbin is turned the right way in the bobbin case.
if it doesn't help,,then the machine needs to be taken to a sewing
machine repair shop for service.
Posted on Apr 18, 2013
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
My thread bunches under me material and can' t sew
Sounds like "thread nesting" also called "bird nesting." Usually, it is a result of incorrect threading, incorrect tension, or the thread not being properly seated in the tension disk.
Remove the thread.
Install a brand new needle.
RAISE the presser foot and rethread the machine from the beginning making sure the thread path is correct.
Set the upper tension to the midway point between low & high numbers.
Test.
The correct tension is achieved when the upper and bobbin threads meet in the middle of the fabric. If upper thread is looping under the fabric, the upper tension is too loose. If the bobbin thread is appearing on the top of the fabric, the upper tension is too tight. If it is difficult to determine what is happening with tension, try using a different color thread (but ALWAYS the same type & weight) in the bobbin as what is used as upper thread.
Tension is static--it needs to be adjusted whenever a new project is begun because the needle/thread/fabric combination will affect the tension. A sewist should become comfortable with adjusting the upper tension on a piece of the scrap fabric before actually beginning to sew the project.
The needle/thread/fabric need to be compatible to get the best result. All About Needles
Sewing Machine Thread Bunching Up Here Why
http://www.chholderby.com/tips-tricks-and-help/part-4-bird-nesting
Mar 12, 2016 | Sewing Machines
How can I prevent bobbin thread from bunching up and tangling?
First thing to do: install a brand new needle and clean the lint/dust from the feed dogs and bobbin area. Make sure you are using the right needle and thread for the fabric being sewn.
All About Needles
Second thing: remove all the thread from the machine. RAISE the presser foot and rethread from the beginning making sure that it is threaded correctly through every thread guide (consult the owner's manual). And verify that the bobbin is loaded and threaded in the bobbincase properly.
AVOID using old, fuzzy, and bargain bin threads.
Set the upper tension to the midway point between the high & low number (this is the factory standard although every machine may slightly differ). Now perform a new stitch test.
If the upper thread is creating a thread mess under the fabric, the upper tension is too loose. Tighten it.
If the bobbin thread is coming up to the top of the fabric, loosen the upper thread and retest. Sometimes the upper thread tension is not enough to prevent the bobbin thread from coming up. In that case, the bobbin tension may need to be tightened. (Search the internet for instructions for adjusting the bobbin tension. NOTE: bobbin tension adjustments should be done in micro-increments as a small adjustment will make a big difference in the result. Be sure to test after each adjustment.)
The tension is correct when the upper thread and bobbin thread meet and cross in the middle of the fabric. This will change whenever fabric, needle & thread are changed, so a sewist needs to be comfortable with regularly making upper thread adjustments.
One other thing to try is pull the bobbin thread up through the fabric before stitching and gently holding the thread tails when taking the first couple of stitches.
https://www.youtube.com/watch?v=caPzulMMlMU
Jan 25, 2016 | Sewing Machines
200 thread breaking
1. The needle thread is not threaded properly
2. The needle thread tension is too tight
3. Needle is bent or blunt
4. The needle is incorrectly inserted into the needle holder
5. The needle thread and bobbin thread are not set under the presser foot before sewing
6. The thread is either too heavy or too fine for the needle
7. The needle is not the correct one for the fabric being sewed
8. Check for burrs on the needle plate
Dec 23, 2015 | Sewing Machines
Breaking cotton on top and bobbin
Try loosening the tension for that bobbin
Dec 15, 2015 | Sewing Machines
How do I fix the tensio. It's a birds nest of thread at the bottom
bunching underneath is thread tension at the needle too loose
tension numbers are only a guide as different size threads require different tensions as do different material thicknesses
recheck the threading of the machine as it is possible that the thread is behind the tension washers and not between
you can try adjusting bobbin thread tension but as I stated bunching underneath is normally needle thread tension
you can test the needle thread tension setting by pulling the thread before you thread the needle and if altering the tension doesn't alter the effort required to pull the thread ,then the problem is in the tension plate adjustment
Oct 31, 2015 | Sewing Machines
When I am monogramming with my Elna 8600, the thread continually breaks, what could be the problem?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Dec 04, 2014 | Elna Xplore 8600 Computerized Sewing...
THE COTTON KEEPS ON BREAKING EACH TIME I WANT O SEW WITH MY YAMATA FY940
The needle thread breaks
8. try a different thread
9. try adjusting the top thread tension--to a lesser number or letter
use your manual to guide you through tension adjusting
Dec 20, 2012 | Sewing Machines
I've had this machine for over 10 yrs. The problem is that I cannot seem to get the tension adjusted correctly. I was sewing through a batch of triangles and all of the sudden the thread under the...
try these suggestions,see if they will help
try changing thread--top & bobbin,, some thread does not stay good as some other does
usually needle have a flat side goes to the back of the machine, make sure the needle is pushed up into the needle holder--is it the right needle for the fabric
and even if it's a new needle, I'd try another new one,,it's possible it could be bent or blunt or warped
check the thread take up lever to see if the top thread is still on it, when the thread comes off the take up lever it can jam up a sewing machine
check the needle plate to see if there are any burrs on it
also clean under the needle plate & bobbin area for loose threads or lint
Sep 05, 2011 | Bernina Virtuosa 150
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Sewing Machines Logo
83 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
