Question about Compaq PRESARIO SR1475CL AMD Athlon 64 3400+ 2.40GHz, 512MB DDRAM, 200GB Hard Drive, LightScribe DL ... (PW711AA) PC Desktop
Motherboard failure Hi I have been told that my motherboard in my Compaq Presario , which is 2 .5 yrs old and has not been used for 1 year , has failed. Can someone please tell me how a motherboard can fail. I bought a new monitor and plugged it into the PC and I got "No Signal" on the screen for a few seconds before it went blank. The monitor is OK on my other PC. I have been quoted 400 AUD / 600 USD for a new motherboard. Is this a reasonable cost? Thanks
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 166 Answers
Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. The dead giveaway is the fact that you are not getting a monitor signal and if you listen to your computer as it starts up, a few of the devices may not start (hard drive, etc). A failed video card will also give you "No signal message", but the computer should sound normal when starting up. Mobos are usually expensive to replace because the computer makers have them made especially for them and only order so many. They usually do not have a lot of extras laying around. There are a few companies that will repair broken capacitor issues. Hope this explains why they can fail. They can also fail if overheated (like when a case cooling fan fails), the cpu is overclocked and not cooled down (which raises temps), the power supply fails or by lightning and power surges. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations.
Posted on Mar 11, 2009
My compaq f700 laptop won't boot up
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the compaq f700 ac adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Jan 30, 2013 | Compaq Presario F700 Series Laptop...
My compaq presari0 v5000 is in sleep mode and will not wake up
The problem's with the video card or the vga cord; the monitor is just reacting to no signal from the graphics card. Check that the pins aren't bent. If they are, you can possibly straighten them once. The second time, they may snap off.
Since the KB just flashes once, it could be the power supply, or the motherboard. If the motherboard has any caps that are swollen on top or leaking, you might need a new motherboard.
Feb 26, 2018 | Compaq Presario 5000 PC Desktop
Display on Compaq Presario V2665US notebook cuts in and out.
BIOS does the screen fail in BIOS< no OS running?
power on hit ESC, F10 or what it told you to hit for 11 years.
does BIOS work
that button top left is the standby sleep switch .
if bad , no sure what will happen, but something wrong will.
the aCID TEST IS BIOS.
works on demand all the time or not.
LAMPS:
the back lamp is dead, CCFL
all do, on all old screens 2010 and older
the magic year is 2010 as that year LED phased in.
see? use flash light see, that data there? do you'?
no sure what button you are pressing?
an 11 year old Laptop 2006, so CCFL is there
test those.
for sure use a flashlight.(test)
and see if there is data if see that, the CCFL tubes dead, there inverter is dead, or the power to it or out of it is cut.
here is close manual for free.
https://www.manualslib.com/manual/30176/Compaq-Presario-V2605tn.html
Nov 28, 2017 | Compaq Presario V2665us Notebook
My notebook is Compaq Presario V3646TU, motherboard manufacturer: wistron Model: CD30 Version number: 80.52 Pristine CPU is T7250 My question: change CPU to T8300 or T9300,...
why do this, there is no benefit, (that you will see)
only HP can answer this, they now own Compaq,
no story told, buy a ***** motherboard
or just want to throw money on this old PC 2007 PC
10 years old now.
2 things must match the other chips, north and south bridge
and BIOS to change CPU.
the formore, HP fails to document clearly.
the BIOS changes lists on the HP site (we are not hp)
are"
last F13.
Adds support for Intel Pentium Dual Core Mobile T2310 and T2330 Processors.
and
Adds support for the new generation of Intel Core 2 Processor Family CPUs.
https://support.hp.com/us-en/product/compaq-presario-v3600-notebook-pc-series/3543723/model/3559132/manuals
your cpu aboe is gen 8 an 9
last one certified for this pc is G7
the fastest on certified was
intel Core 2 Duo processor T7500 - 2.20GHz (Merom, 800MHz front side bus, 2MB Level-2 cache per core, 65 nm process technology)
i will attempt to show the HP parts surfer data nexe.
click processor here.
you never posted your PC, service tag so answers will be weak.
the p/n was not posted by you, like GJ831AV
or the the other 40 models seen here.
http://partsurfer.hp.com/Search.aspx?type=PROD&SearchText=GJ841AV
why not ask HP and not fixya, HP is real....
the real deal here. HP
https://h30434.www3.hp.com/
Oct 21, 2017 | HP (302203-001) Motherboard
Soyo k7v dragon plus motherboard continuous
2 beeps = memory problems. Since you get them even after the memory has been replaced then the problem is in the motherboard itself. Check the capacitors for bulging. If you can't find ones or you can't replace them then the motherboard is dead.
May 13, 2010 | Soyo SY-K7V Dragon Motherboard
Looking for a manual and motherboard layout for a compaq presario 4090us 4000 seirs 900MHz duron processor built sometime in the late 1990's the motherborad has a name on it between the 3 pci slots that it...
the mother board is 17 years old and will not run the later ad on or plug in cards
The power supply problems can be corrected with a new power supply
discuss the matter with a computer repair shop as the unit can be upgrade for less than 1/2 the price of a new unit , be faster more reliable with a bigger ram capability
there are sshd hard drives that have no spinning disc so it never wears out and crashes
it never costs to just talk and get ideas and once you have the ideas you can always install it all your self
Mar 20, 2017 | Compaq Presario 4000 System Board...
Compaq presario s3010cl motherboard replacement
Just about any Socket A / 462 Motherboard in the mATX form factor will work. make sure your memory and CPU are compatible with the motherboard before you buy.
Nov 24, 2009 | Compaq Computers & Internet
A new motherboard for a old compaq presario 5240
You will need a new case and a new power supply. I would replace the memory as well.
Compaq had a tendency to make cases to only fit their boards back then. Youre better off building a new unit and starting over again.
Jun 14, 2008 | Compaq Presario 5240 (353200-003) PC...
Computers & Internet Logo
205 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
