Question about AOpen Computers & Internet
I am looking for a motherboard for a DVR...the part number is MBM-AX4SG-350
BIOS battery type
open cpu motherboard looks bios battery then change
Jul 29, 2012 | AOpen i865G (AX4SG MAX II) Motherboard
I reformetted my pc. the sounds were fine prior to the reformatting but when i tried to play a sound i get error messages. when i looked at the device manager i found a yellow sign with a black question...
you most likely have onboard sound and video. you will have to check the model number of your motherboard and search online. there should be a sticker or writing on your motherboard. otherwise most motherboards display the model name during the first few seconds when you switch your computer on. you might have to do it twice to get the monitor to switch on first. its usually a code or number like MBM-3434-234 (this is purely an example as it might be a longer or shorter with different characters)
hope this helps
Aug 28, 2010 | Intel Motherboard
Setup with AX4sg-UN Motherboard won't boot into win7
Have you tried booting into safe mode? If the hdd was preloaded with Windows 7, it's trying to use the old drivers to the old board. I've ran into this same problem when I tried to move a preloaded hdd to a different mobo. Do you still have your Windows 7 disc?
Dec 30, 2009 | AOpen AX4SG-UN Motherboard
I have a AX4SG-UN system and first of all it takes a long time to come on.
How long? Some motherboards run an "extensive" P.O.S.T. (Power On Self Test) in order to confirm that the motherboard is running correctly.
Has it _always_ taken a long time, since the day that you purchased it?
Dec 27, 2009 | AOpen AX4SG-UN 865G+ICH5/800FSB/Dual...
Long beeps on start-up & shows nothing
I can almost assure you that those beeps are telling you that you have burnt out your memory due to the static electricity of your body. If you are sincere give us the information we ask: (1) Manufacturer's name and Computer Name; (2) Model Name and Number; (3) The ID information of the mother board. If you can't find it we will help you! (4) We need a detailed report from you about what happened! Before the failure, during the failure, and after the failure. Send that info. and we will be in business.
My name is Constantin (arzconst is mu internal nickname with Fixya.com)
Jun 16, 2009 | AOpen AX4SG-UN Motherboard
93 camry
either your car is running cold,or your 02 sensor is bad
Jan 10, 2008 | AOpen AX4SG Max Motherboard
Ax4sg-un doesn't start
Do you have any boot devices connected to it at all?
Are you using the correct memory for it?
Are you sure the ram is compatible with the mobo? Try taking all but one stick of RAM out and see if it still does it.
The long beeps tend to point to a RAM problem, or it's possible it can't "find" a hard drive4.gif.
Some motherboards support dual channel (you'll see different color slots), and some don't. If you try to put the sticks in dual channel configuration, and the cpu4.gif or the motherboard doesn't support dual channel, you may experience this.
If you have different color slots, put one stick in one color slot, and another stick in the other color, or vice versa.
The manual "should" tell you the proper configuration for this, and may even tell you what the beeps stand for.
If you can post the make / model of all the components, I can do the "dirty work" for you and see it if should all work together.
Computers & Internet Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
