Question about Costco Megabrite Self-Powered Turbo Torch Mini Super Bright LED Flashlight Megabrite
Manual flashlight with a crank megabrite - Costco Megabrite Self-Powered Turbo Torch Mini Super Bright LED Flashlight Megabrite
SAKAR MAXIMO CONCEPTS MAX30722 WHERE DO I FIND AN INSTRUCTION MANUAL?
You might try Google or etc, search "PDF owners manual " followed by the name of the product.
Dec 23, 2013 | Sakar Maximo Concepts MAX33722 Emergency...
Rayovac 3Led Crank Flashlight
You will have to take it apart and replace the battery pack. They use the same as a portable house phone of a remote. Get lithium rechargeable.
Dec 19, 2012 | Rayovac Brilliant Solutions Dualpowered...
What type of motor
Motor should be a standard dc motor that produces 1.5 to three volts. As a rule most crank flashlights will give you a 10/1 ratio (crank one minute, shines for 10. Hope this answers your question.
Oct 26, 2012 | Energizer Crank Flashlight 3 Led ()
Megabrite model mb-dlm-82. It sometimes work and then not. The batteries are good and turns on with on-off switch. Is there an owner's manual? I think I've done everything correctly. Had...
From MegaBrite Lighting website:
http://www.amerasiaenterprises.com/P_faq.htm#p1
Why does my light keep flashing on and off when nobody is around?
There can be a number of reasons why this problem occurs.
A) It's possible that the battery life is too low after some time of usage. Please replace all 3 batteries with new ones.
B) Your product needs resetting (very similar compared to rebooting up your computer). Please follow directions below:
  1. Rotate the motion sensor white ball facing at a 45 degree angle downward.
  1. Use at least 3 pieces of black tape and place it over the photo sensor completely to simulate darkness. The photo sensor looks like a small circle located on the top right hand side of the 8 or 10 LED's.
  1. Turn the Light ON and then OFF. Please repeat this process 3 times.
  1. Then switch it to AUTO.
  1. Place the Light against the wall on the floor. Make sure the Light is facing upward leaning against the wall. The LED's should be facing towards you.
  1. Step back at least 25 feet away from the Light. Do not move otherwise the Light will turn on. Wait until the Light starts to dim down and turn off (approximately 20 seconds).
  1. When the Light turns off, wait for approximately 4 seconds and then approach the Light waving your legs and arms. The motion sensor should be able to detect your movement and then the Light should turn on.
You have just completed the resetting process. Now you may return the Light back to where it was installed. Be sure to leave the switch at AUTO and remove the black tape.
Jun 27, 2011 | Costco Megabrite Wireless Motion Sensor...
What will a wobbling harmonic balencer do on 95 dodge ram 5.9?
Your car may **** a little or shift really odd, it may throw motor off balance
Aug 17, 2009 | NRS Hand Crank Flashlight
Need battery charger
Bought a universal charger from Radio Shack with plug that match spotlite.
Jun 23, 2009 | Duracell Crank Light 3 In 1, 3 Led...
Need owner's manual
e548fa9.jpgafae0af.jpg3e075ea.jpg4392de5.jpg Max is 150K so sorry for bad quality.
Dec 16, 2008 | Duracell Crank Light 3 In 1, 3 Led...
Radios and flashlight from innovage wont work
I would return them to the place of purchase and tell them they don't work. Most stores have a defective product replacement policy where they'll either replace your units or refund your money. Be sure to bring your receipts.
Mar 14, 2008 | Audio Players & Recorders
Costco Megabrite Self-Powered Turbo Torch Mini Super Bright LED Flashlight Megabrite Logo
55 people viewed this question
Top Costco Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Costco Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
