Question about Amana NED7200TW Electric Dryer
I have an Amana NED7200TW suddenly stopped working. Power is on, panel lights up. replaced the thermistor still will not start. no error codes come up. What else should I look at?
  • Terry Apr 21, 2013
    No fuse next to thermister on this unit
  • Amana Master
  • 8,220 Answers
How about the fuse right beside the thermister? Did you maybe remove a wire from it by accident while replacing thermister?
Posted on Apr 21, 2013
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
How to find and replace the thermistor on an amana ned7200tw dryer?
Hi Marissa,
Have you run the diagnostic program to find the fault?
Your problem could be the high limit thermostat, thermal fuse or the heater. Take the panel off at the back and locate the tech sheet. On the tech sheet you will find the instructions for running the diagnostic program. Run the diagnostic program and this will tell you where the problem is and the corrective actions needed.
It is a bit involved to get at the thermistor, but easy to replace. see http://www.youtube.com/watch?v=mCmGRijX_14, as this leads you through the process very well.
Feb 02, 2014 | Amana NED7200TW Electric Dryer
T5 error code
test the thermostat and thermistor too and replace, if the problem persist, clean the ducts, or need to replace the control board if the problem . If the problem continue
make this test.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Oct 01, 2013 | Amana NED7200TW Electric Dryer
NED7200tw t5 error Code
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
5. Power ON
Aug 08, 2012 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
How do i clear the code " ts" after replacing thermister Thank you
The error "tS" actually means the thermistor is shorted. It flashes when the thermistor is indeed shorted, the thermistor wires are shorted, or the timer/control is faulty. There's no necessity to reset the machine. The problem here is not the thermistor but a shorted wire or a faulty timer/control. One simple way to find out is by disconnecting the thermistor and insulating the wire terminals then starting the dryer. If the error code does not vanish, then it is proven with moral certainty that there is a wire short circuit or a timer/control problem. Check and make sure that there's no such wire short circuit or no part of which is touching the dryer cabinet then if the error is still there, disconnect the wire harness from the the timer control. The timer/control is indeed faulty if the error code persists even after the wire harness is disconnected therefrom.
You have a faulty thermistor if the error code vanishes after the thermistor is disconnected. Normal thermistor resistance is around 10000 ohms at room temperature.
Aug 12, 2011 | Amana NED7200TW Electric Dryer
Code looks like an upside down F with either a 5 or s. Push the start button and code keeps showing. all the other functions of the control panel seem to be working.
The upside looking F is really a lower case T and the 5 is an S. The code ts is related to the Thermistor which is on the outside of the blower housing. The part runs about $30
Jun 22, 2011 | Amana NED7200TW Electric Dryer
Dryer LED displayed HE and when you go to push start dryer wont start just clicks.Unplugged and plugged back in still same results. Does not show any error code though only the first time when it wouldnt...
hE=Heater error, Restricted vent. Replace thermistor. you can bypass the thermistor for test purposes by taping the wires together. it is located on the blower wheel assembly, here are pictures of opening the dryer. once it is verified that the thermistor is the problem untape the wires and replace. this is a fire safety feature and should never be operated in the bypassed mode. Safety First, unplug before opening. hope this helps Tim:
http://www.appliancehelponline.com/dryerblowerassy.html
Apr 17, 2011 | Amana NED7200TW Electric Dryer
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
T5 error code comes in my amana dryer ned 7200tw
That is actually a Ts error.
Thermistor Short Sensed
The Thermistor resistance is very low.
Check for:
- Clogged lint screen.
- Restricted vent system.
- Check Thermistor resistance.
Thermistor is Item #27 HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2010 | Amana NED7200TW Electric Dryer
Amana NED7200TW Electric Dryer Logo
206 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
