Question about Paragon Hardware & Accessories
My paragon timer model number 23001/215 is running slow
The clock seems to be running slow
  • 52 Answers
SOURCE: Paragon timer parts
electricalexpeditors.com
Posted on Oct 05, 2009
  • 52 Answers
SOURCE: Need tripper pins for AMF Paragon Timer Model 7218
Go to electricalexpeditors.com for replacements.
Posted on Dec 30, 2009
  • 52 Answers
SOURCE: My timer won't cycle the motor on and off.
you may need trippers
Posted on Feb 26, 2010
SOURCE: I need trippers for an
I don't recognize Paragon TC-2.
http://waterheatertimer.org/Paragon-timers-and-manuals.html
Intermatic cross reference does not have that model number either.
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Paragon sent e-mail last month saying they were no longer making timers and parts, except for defrost timers. Your water heater timer is not defrost timer.
Here is a wide selection of water heater timers, electro-mechanical and digital:
http://waterheatertimer.org/Boxtype.html
Manuals and wiring diagrams are shown for most products on page.
I recommend simple 240Volt Intermatic WH-40 for price and reliability. Drawback is minimum 1 hour on-off.
Or Intermatic T-101 for 120Volt heater or T-104 for 240Volt heaters sold at Lowes.
Intermatic trippers and motors are available and interchangeable, and are made of steel.
Some new timers are made with plastic parts:
GE 15207 is universal 120V 240V and sold at Home Depot.
Tork has new universal electro-mechanical timer, TU-40 for 120 and 240 applications
I use GE 15070 in-wall timer from Home Depot for my water heater because I change times frequently and try to shave every dollar:
http://waterheatertimer.org/Compare-13-electric-water-heater-timers.html
Add a comment if you need more help.
You can also take advantage of fixya phone support.
Fixya expert will walk you through any problem for a price.
Posted on Dec 23, 2010
  • 16 Answers
SOURCE: I need a wiring diagram
Paragon 8145-20 is a 240VAC (2 phase) timer. I doubt you will be able to find a 3 phase type timer.
I would suggest you use this timer as a control and purchase either contactors or relays rated to handle the 3 phase load.
Posted on Dec 26, 2010
The clock on my paragon 4004-71m is not working
1) Clock motor has gone bad, but replacement clock motors are no longer made.
Copy following link for Paragon resources:
2) Paragon is not making parts or replacement motors.
4007-41 is 240Volt timer, replace timer with Intermatic T104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
3) Crossover wiring from Paragon 4004-71 to Intermatic T104:
Paragon 1 to Intermatic 1
Paragon 2 to Intermatic 2
Paragon 3 to Intermatic 4
Paragon 4 to Intermatic 3
Intermatic terminal A is generally not used for 240Volt
4) Add a comment if needed
Jan 17, 2013 | Paragon Hardware & Accessories
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
Timer does not work properly timer motor not count proper time
If the clock motor is not keeping correct time, then it has gotten weak and needs to be replaced.
Paragon is still making defrost/HVAC timers and parts.
Clock motors have numbers.
Mar 28, 2011 | Paragon Electric A-706-00 Hvac Timer...
On parAGON 7000 MODELS where are the motor connections, is it on each T terminal
1) Paragon 7000 series clock motor is terminals A and B
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
2) If you have EC7000 digital timer, then wiring is different.
With EC7000 120V, clock motor is terminals 1 and 4 with jumpers added between 1 & 2, and between 3 & 4.
With EC7000 240V, clock motor is terminals 1 and 4 with jumpers added between 2 & 3.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 21, 2011 | Paragon Hardware & Accessories
Hello I need to replace a paragon model 4003-0 can you tell me what is compatable to this model? thanks maury
As you probably know, Paragon is no longer making timers and parts except defrost timers.
4003-00 is not a defrost timer
4003-00 is DPST 120Volt timer 24-hour mechanical timer
Paragon timers and manuals
Intermatic cross reference shows that T-103 is replacement for 4003-00
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T-103 has 120Volt clock motor and can control 1 or 2 - 120V loads or 1 - 240Volt load
Dec 29, 2010 | Paragon GENERIC REPLACMENT MECHANISM 110V...
Where do I get a replacement motor for the 7008-00?
Intermatic clock motors are everywhere, but Paragon and Tork clock motors are a mystery.
Shows manuals and resources
According to Paragon accessory chart:
http://www.paragontimecontrols.com/parts_accessories.htm
7000 series 240V clock motor M3193-71
7000 series 120V clock motor M3099-00
7008-00 is listed as 120V clock motor
http://waterheatertimer.org/pdf/Paragon-7000-series-manual.pdf
I cannot find M3099 120V clock motor on internet
Now Paragon has contact-us page for customer service:
http://www.paragontimecontrols.com/contact/default.aspx
I will also contact Paragon, and post results here if Paragon responds.
Nov 17, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I have a model 7005 outdoor timer ,brand new but no instructions to proceed with settings .Can you help me?
72d1511.jpgParagon 7000
Paragon 7005 is a heavy duty 7-day mechanical timer that can handle 4 loads. It is DPST. One of two wiring diagrams applies to this timer:
1d6e8ec.jpgThe question is the the timer clock motor is 120V or 240V?
36b7dc9.jpgParagon EC 7000 is a 7-day digital timer with 16 set points per week
Manual for EC7000
http://waterheatertimer.org/pdf/Paragon-EC7000-wire.pdf
Please re-post your questions as you start sorting out which timer you have.
Paragon is improving their site so there is less confusion over model numbers and functions. but information about the 7000 are still sketchy.
Oct 15, 2010 | Paragon Hardware & Accessories
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Replacement timer motor needed
If you have Intermatic timer, then clock motors are available for most hard-wire box-type timers. Most pool and spa timer modules are available or have same/similar replacements. If you have plug-in timer, including power pack or portable outdoor timer or indoor plug-in or in-wall timer, then no clock motors are available.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
If you have Tork timer, then clock motor is available for 1100 series.
http://waterheatertimer.org/Tork-timers-and-manuals.html
If you have Paragon timer, clock motors will be hard to find
If you have other brands of timer, then clock motors are not available except Deihl, DIGI and Grasslin timer modules, but post brand and model number of timer so I can search my files.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Sep 11, 2010 | Intermatic WH40 - Water Heater Time Switch...
Hardware & Accessories Logo
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
