Question about Whirlpool Dishwashers
My Whirlpool W10073320 dishwasher will not start.
The door is shut and when I push start the lights come on but it doesn't do anything.
SOURCE: Whirlpool dishwasher will not start
There is a small replacable part on the control panel circuit board which is like a fuse. It actually is a temperature fuse and it blows when the environment gets too hot for the circuit board. Unplug the dishwasher and take the door apart so you can see the circuit board. If you trace the power wires one of them leads to a little white module with 2 electrical tabs. Unplug the 2 wires and unsnap the module. You can check it with an ohm meter. IF its good the meter will register almost a short. f it's bad it will be open. The parts place I went to didn't even need a model number and he says he goes through a lot of them.
Posted on Nov 09, 2008
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
  • 50 Answers
SOURCE: Whirlpool dishwasher stops midcycle and control panel goes blank
I would check you door switches.
Posted on Feb 26, 2009
  • 128 Answers
SOURCE: My dishwasher simply won't start
Start with the simple things and work your way from there. You will be amazed how many people call a plumber who flips a breaker or simply clears a stuck float valve (for $80 minimal fee).
If no lights are coming on.
First check the breaker to the machine.
If you have an exposed power source to the machine such as a plug or junction box open the box and check the wiring is intact and not rusted etc. Take care here and shut the breaker off first.
No go so far?
Check if your float valve is jammed.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
Not the float valve either?
Check the door interlock latch.
Much like a washing machine a dishwasher will only operate with the door closed (or when it thinks it is closed!). There is a metal tab that engages a switch in the door. This is the same switch that activates as you operate the handle to open the door. If it is misaligned it will not signal the machine that the door is closed and the machine will not operate.
You can check this by overriding the locking tab. Put a screwdriver in the door latch and press the switch. You should see the lights come on and power flow to the machine.
Note: if the machine is in run mode you will get water spraying.
To fix this problem bend the tab to properly engage the switch. Or if necessary loosen the screws retaining the switch and move it to correctly align with the tab.
Not it?
OK now you are into electronics.
First is quite simple. Some units have an internal fuse to protect the control panel. Check that first. Take your time and take care. Turn the breaker off.
The control panel is screwed in place. Remove the screws and gently remove the control panel. Take care not to have parts of the door latch fall out or springs drop out etc. On newer units it is very simple as it is just a circuit board. Look for the fuse and check that it is OK. Replace if necessary with correctly rated thermal fuse.
Do you have water in the bottom of the machine?
Power is there, lights are one, seems to want to work. Water will come in but will not drain.
A small amount around the drain is normal for some machines. This is held to keep the pump primed in some units. However it should not fill the bottom of the unit. You know what it normally looked like so it if is full then you probably have a jammed float valve as above or a clog in the drain.
Drain clog.
Remove the cover from the drain in the bottom of the dishwasher. They usually lift out or have a few screws holding them down. Simple to figure out just take your time and try not to force anything. Look for a clog and clear if necessary.
Your drain can run either direct to the drain under the sink or to the disposal unit if you have one. The drain can clog at either point.
Check by disconnecting the drain line from the dishwasher where if connects to the sink or disposal unit. Look for a clog and clear if necessary.
Water exits the machine via the drain pump. If it is not operating the machine will not drain. It will fill usually to the point where the float valve lifts and does its job by stopping the machine before if floods your house.
If you have water in the machine to the point the float valve is lifted then drain it out first.
Your machine should be running now. Lights will come on and it will run again to the point where if fills with water and trips the float valve again. If so then check the pump and timer (see also timer below).
Remove the units as per below.
If your pump is belt driven check he belt (very few have belts).
If direct drive switch the unit on and let if run to the drain cycle. If the pump does not come on check for voltage at the pump during the drain cycle. If you have voltage replace the pump. If not it is the timer that is faulty (see below).
OK now your are getting to some deeper issues. Not necessarily hard but only go here if the simple things are OK.
If you are not getting water into the unit but you have lights on and you hear clicking and the timer runs and things are trying to work then we know you have power and the timer is running.
No water coming to the unit.
Make sure nobody shut the supply line off. There should be a tap under the sink on the water supply line to the unit.
Turn the unit on an listen at the base for a click as the water supply solenoid (electric switch) opens. No click?
Check the solenoid. Remove the machine from under the counter. There will be screws holding it to the underside of the counter. You may have to lower the legs to get it out. They turn with a wrench to lower.
Under the unit where the water supply line comes in is a solenoid switch it opens to allow the water to enter the machine. Water comes in under household pressure (it is not pumped in by the unit). Chances are it is faulty. Replace it as it can't be serviced.
Still no luck?
The unit is guided by a timer. The timer tells the machine what to do and for how long. If it fails the unit will stop or jam in one cycle. If you have a physical switch the you turn to select the type of wash cycle check it. If you are all touch control then replace the whole board or machine.
To check the switch open the control panel above and use a voltage tester to see if you have current at each cycle point. Cleaning sometimes helps if not replace.
Hope this helps you. Please rate this tip for me.
Adrian
Posted on May 03, 2010
SOURCE: Frigidaire Dishwasher Model:FDB1050RECO - When
same problem, wash light would flash, just like if the door was open during the wash cycle....took door apart and suspected the door switch was bad, fiddled with the wires that go to the door switch and the washer worked after that. so i had the door disassembled and used my hand to close the door latch switch then wiggled the white and black wires that go into the bottom of the switch, that is when it started to work.
wiggled with the wires for a while more while the washer was working to make it stop and start, until i found a good spot where it stayed working. been a few days and it is still working. need a new door switch if'/when it quits next time.
the door switch keeps the washer from running with the door open, it tells you the door is open by flashing the "wash" light when you try to start it. cheesy switch, my washer is only a few years old. i tried all the other things suggested, power on and off and hold down different combo's of buttons while standing on your head with your right eye closed, none of that worked so out came the screw driver.
figured if it was coming out to go to the dump i could not hurt it much more than it was at that time.
anyhow door switch was the problem, i hope this helps more people out there, i was close to throwing it out after not finding much for helpful advice online.
Posted on Dec 21, 2010
Dishwasher WHIRLPOOL DU930PWPQ2 stays locked and doesn't start. Even when i push on "heated dry" during 5 seconds. What can i do ? Some one gets an answer ? Thank you
washer Will Not Turn On - How To Fix ...
removeandreplace.com/2014/.../dishwasher-will-not-turn-on-how-to-fix/
Oct 6, 2014 - If your dishwasher won't turn on or start, here are a few things to check yourself ... Frigidaire, Kenmore, Whirlpool, and Bosch) work the same way. ... This door switch is also sometimes called a door lock or door interlock switch. ... All the lights light up on my dishwasher but the thing doesn't turn on at all.
Troubleshooting Why the Dishwasher Won't Start ... - YouTube
? 3:58
https://www.youtube.com/watch?v=8ZrtcdtmyEk
Jun 20, 2012 - Uploaded by PartSelect
In this video you'll learn what happens when the dishwasher won'tstart. ... Here are a few things you should check if yourdishwasher won't start: ... Replacing the Thermal Fuse & Harness (Whirlpool #675813) - Duration: 6:01.
Whirlpool Dishwasher DU930PWPQ2 Troubleshooting ...
Jan 14, 2016 | Whirlpool Dishwashers
Anti theft system
find kill switch and shut it off. there is a ground in the system
Jul 11, 2013 | Chrysler Voyager Cars & Trucks
How do I shut off B-Service due light so it doesn't come on every time I start car
if their anything like bmw then it has to go to dealership to be reset with a computer
May 23, 2013 | 2009 Mercedes-Benz C-Class
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
Jun 17, 2017 | 2003 Volkswagen GTI
The door ajar light is on, but all the doors to the van are shut. The sensor beeping is always activating when I'm briefly stopped, and accelerate upon starting again...the beeping will not shut up un
You will note a simple contact switch on the door sill. It has probably jammed, dislodged, or is broken by someone kicking it upon entry/exit. Realign it and see if the warning light goes off when you press the switch in (simulates door closed). If it goes "off", you're home free. If it doesn't you will have to order a replacement switch from the dealer. They are easy to replace by carefully prying away the rubber grommet and sliding the switch out... there should be a simple wire plug for it... unplug it and plug in the new one. Note the grommet position so you don't have to take it loose again to friction the grommet in properly. Test it with your finger pressing it down again, engine "on", door open. Should cure your problem. Good Luck
Oct 05, 2012 | Cars & Trucks
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Jerking at acceleration and braking! no engine lights what could it be.
Leave the car at some shop or dealer,don't use it like that
If a shop doesn't seem to find things, there usually are
several reasons why
Try another more capable shop & spend some time
there,so you both understand the time to be applied
to diagnosing,your costs & the shop has to welcome
you into the service bay & prove they have the technology,
tools & personel to work on your car problems
May 18, 2012 | 2005 Audi A4
Dishwasher is locked but the door is open start/resume light flashes continuously
shut the door and push the start/resume button and wait 5 min before doing anything else. if the start button is flashing that means the cycle was interupted in some way.
Apr 08, 2012 | Dishwashers
Dishwashers Logo
717 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
