Question about X2Gen MG19MY 19" LCD Monitor
My monitor won't come from sleep mode?
Power up nothing happens?
  • 56 Answers
Have you tried another monitor, the issue pretty much sounds like is from video signal. pc video card adapter!
Posted on Mar 25, 2014
2 Suggested Answers
  • 1684 Answers
SOURCE: Power turns off and on fr abour 5 minutes before finally staying
This is a classic symptom of a failing power supply. After 2-3 years of use many LCD power supplies will start fail because of parts called capacitors that start dying due to the heat buildup in the monitor case. If you can solder then you should be able to do the repair yourself. Check out this page on our web site; http://www.ccl-la.com/blog/index.php/capacitors/ This article explains what capacitor are, how they fail and what you will need to get for the replacement parts. The parts can be ordered from many places on the internet, we stock they too. If you don't want to do the repair yourself we do offer a repair service, that info can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps you, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on May 01, 2010
Won't go into sleep mode
Which operating system ?
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work.
This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation.
Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money!
Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow.
The Shut Down menu appears.
Point at "Sleep" and click on this option.
Your Windows 7 computer goes into sleep mode.
Wake your computer from sleep mode by jiggling the mouse.
There may be a delay of a few seconds before your hardware powers on.
All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode.
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time.
Click "Start" and select "Control Panel." Click "System and Security."
Click "Power Options."
A menu opens.
Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode.
If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Your Computer in sleep mode
First, save all of your work. Information in computer memory is not saved while your computer is on standby.
From the Start menu, select Settings, then Control Panel, then Power Management.
Click Standby Beside When I Push the Power Button.
Push the Power button.
Automatically Putting Your Computer on Standby
Save all work before leaving your computer.
From the Start menu, select Settings, then Control Panel.
Double-click Power Management.
Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks.
Click OK. Your computer will go on standby according to the schedule you have entered.
Putting Your Computer in Hibernation
Double-click Power Settings.
Click on the Advanced tab.
At the When I Push the Power Button On My Computer screen, click Hibernate.
Click the Power button.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
Forgetting that the computer was on, I went to turn it on and shut it off while in sleep mode. The screen won't work.
A monitor does not normally save any states such as sleep. If unplugging the monitor from the power source for ten to twenty minutes and re-plugging it in does not fix the problem check and see if the monitor's menu comes up.
Even in sleep mode, the menu for the monitor should show. If it does, try resetting the monitor to factory default settings. If the menu does not show up, then there is an issue with the monitor.
Jul 04, 2012 | Dell Computers & Internet
Hp elite l2201x monitor won't work
I am experiencing the same issue. My monitor will not come out of sleep mode. HP informed me to purchase another power cord, but it yielded the same results. Any solutions????? Thanks
May 28, 2012 | Dell Computers & Internet
Dell 8200 beeps 10 times monitor won't come on says power saving mode
Hi
Remove the sound card and blow the slot with dry air to rid off dust.
Examine it to make sure nothing's damaged and fix it again.
Checkout the RAM's.Probably remove them,wipe the slots off dust and fix them again.Make sure they're well seated on their slots.
Feb 05, 2012 | Computers & Internet
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
For a long time the monitor wouldn't come on right away when the computer was in sleep mode, or hibernate. I'd move the mouse around and nothing would happen for 2 to 3 minutes - sometimes. Other...
Probably not a setting
If you are on windows : Can you change the power setting in the interim , to stop it going into hibernation - sleep mode
settings > control panel > power options>high performance should be clicked and then click change plan, PUT THE COMPUTER TOP SLEEP > NEVER
Does not solve the intial issues, but tis impossible to diagnose in this forum
Hope it helps
Apr 21, 2017 | ViewSonic VP2030b 20.1" LCD Monitor
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
Power on and monitor goes to sleep mode
You need to try it on another PC, alos verify if the VGA cable is good. If nothing change, then you need to open it up, first thing to look for are the capacitors in the power supply. Look for cpas with bulging top/seal, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 19, 2010 | Acer AL2216W LCD Monitor
Stuck in sleep mode w/black screen
If possible, try a friends monitor first. If it works, you can then change the sleep mode setting so that it won't come on again. If the other monitor does not work, the video card is probably defective.
Oct 26, 2007 | Computers & Internet
X2Gen MG19MY 19" LCD Monitor Logo
110 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
