Strying to connect pc to tv by wi-fi with digi-sender I need to find my ssid and password
So I need the access key password how do I find this
  • 7,733 Answers
Depend on your router model / brand you can log in on the router web UI and find or change the password.
Posted on Apr 20, 2013
serra_baby
  • 144 Answers
SOURCE: Belkin Wireless G Plus MIMO (F5D9230-4)
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
Posted on May 30, 2008
kakee
  • 1269 Answers
SOURCE: asking me for wi-fi password
The wifi password is the same as wireless network key (either WPA or WEP key). That's the same password that you used when you tried to connect to the wireless network using your laptop.
Posted on Apr 27, 2009
anandg27
  • 1272 Answers
SOURCE: connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Posted on Jun 26, 2009
SOURCE: i can not remember my wi-fi password. i need it to
If you have tried the default passwords (blank, admin or sysAdmin) and they don't work, you will need to reset it back to factory settings. You can do this by finding a hole at the back of the unit and pressing the hidden switch there for a few seconds. After that it should be back to its original configuration. You will obviously have lost any changes you made to it since you took it out of the box.
Posted on Jul 02, 2009
anandg27
  • 1272 Answers
SOURCE: i don't know what the password is for netgaer
I would nt recommend resetting the router.
Please follow the steps on a computer connected to the router so as to check the network key:
3. Login to the router with the Username as admin and password as password (unless you have changed it).
7. If WEP is selected, copy the code entered in the key that has been checked.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Aug 11, 2009
How do I go on-line? my wi-fi is on, but when I try to go on-line all I get is off-line (data or wi-fi turned off)
Hi Fred,
You'll need to know the SSID and Security Key for the WiFi source. Public places may have open security - not require a key - and others may not provide a key so that you can not access the internet from their WiFi router. Once you have determined that you have the SSID and Security Key (again - if needed) you'll need to make sure that the Android device has Wifi on. Then, the phone will alert you to the presence of a WiFi signal. Locate the signal that matches the SSID you were provided and select it. Enter the SSID when prompted for the security key. You may be prompted to agree to terms of service at public WiFi or hotspots such as McDonalds, etc. instead of a key. Use of a WiFi or Hotspot with other connected can subject ALL of the information you send or receive to unathorized eyes.. so accessing email, banking info, etc may not be wise. Casual web browsing should be OK, but think twice about sending any user name, password, credit card number etc. while connected to a public wifi spot - regardless if a security key is needed or not.
If your phone does not see the SSID of the hotspot, it may not be broadcast. In this case, you will need to manually enter the hotspot SSID to allow the Android to detect it. Then select it and enter the security key as above. Good luck!
Apr 10, 2015 | Google Cell Phones
Tip
How to Connect Wi-Fi Connection
laptop user must know how to set up. to connect toWi-Fi locations. Using Windows XP in this tutorial, we'll go throughthe steps for setting up a laptop to access a Wi-Fi network. Some Wi-Ficards can be set to automatically detect and connect to Wi-Fi networks,though it is still important to know how to manually set up your Wi-Ficard to connect to a wireless network.
  • Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP keys are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their Web site or they'll give you the information when you purchase access.
  • Ensure you have a firewall program installed and running. This will protect your data.
  • Start up your laptop and look for the Wi-Fi network icon in the bottom right of the screen.
  • Click on the Wi-Fi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click onthe Properties tab
    This window shows the type of networking card installed. Click on the Wireless Networks tab.
    Once the Wireless Network Connection Properties window is open, you will have two options depending on how you set up your laptop. If you do not see any networks listed in Preferred or Available networks,you will have to manually add the SSID. Click on Add. You will have toenter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available Networks box.
    If you see the correct SSID showing in the Available Networks, then youn eed to click on Configure in order to enter the WEP key if that is required.
    In this window, enter the SSID for the Wi-Fi network you want to a ccess. Make sure you do not have CAPS lock or NUM lock while entering the information. If a Network key is required, click on "DataEncryption and then enter the Network key you have been provided with.Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly, a message will pop up and you will need to re-enter the key.
    Next go to Start - and where it says Connect To click on that and you should see choices similar to the graphic below. Click on WirelessNetwork Connection and it should work. Potential Problems & Their Solutions:
    Thereare occasions when the connection doesn't work. In these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall programd isabled, you will need to change your firewall settings. If your firewall program is not the problem, check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
    on Jun 24, 2010 | Computers & Internet
    Using my phone as mobile hotspot how do i get my network ssid.
    You can use your Android phone as a portable hotspot and get your iPad, iPod Touch, or any other wireless device online. This is a great save when there are no available wireless connections available.
    1. Go to the Home screen.
    2. Select the Menu key.
    3. Select Settings.
    4. Select Wireless & networks.
    5. Select Tethering & portable hotspot.
    6. Select Portable Wi-Fi hotspot checkbox.
    7. Select Portable Wi-Fi hotspot settings.
    8. Select Configure Wi-Fi hotspot.
    9. Input a Network SSID for your connection.
    10. Select a security protocol. Options are Open andWPA2 PSK.
    If you select WPA2 PSK, input a password for the connection and then select the Save button.
    You will use the Portable Wi-Fi hotspot checkbox from above to enable and disable the connection. Once the connection is active, go to the device you wish to connect and configure its wireless connection to the Network SSID for you Android device and input the password (if you are using WPA2 PSK). You now have wireless access for your iPad, iPhone Touch, Zune HD, etc. anytime there is a cellular connection for your Android phone.
    Aug 08, 2014 | Cell Phones
    3. Select Settings.
    10. Select a security protocol. Options are Open and WPA2 PSK.
    -regards and update me
    What does need a data connection mean
    To use Google maps or some other programs (like games), you need to be connected to a Wi-Fi network, not the cellular network. You will need to be in an area with an open wi-fi network or have a wireless router in your home. Find your password for the router's wi-fi network (it should be password-protected) and the SSID; you also need the encryption type (WAP, WEP, etc.).
    Press Apps on the Home Screen. Then press Settings and then Wi-Fi. Select Scan to locate available networks. While on the Wi-Fi tab, press Add Network. Enter the SSID with the keyboard, then touch Security type to select the encryption for your router. Then enter the password and finally press Save. (Some wi-fi routers will want the MAC address before you can add a device to the network. Go to the Menu - Advanced from the Wi-fi tab to get the information.)
    If the wi-fi network has been set up on the Tab, press Apps on the Home Screen. Then press Settings and look for the Wi-Fi On/Off icon. Toggle this to on. (You can also access this by touching the time on the Home Screen. Then touch Wi-fi on the Quick Settings list.)
    I hope this helps.
    Jan 16, 2013 | Samsung Galaxy Tab 2 7.0
    Wireless g router network set-up
    Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
    thanks for choosing fixya.com and kindly rate this post.
    Jan 03, 2012 | Linksys Wireless-G WRT54G Router
    What is the security Key I am trying to set up my wireless connection but can not find Wireless Network Name (SSID) or Wireless Encryption Key:
    Connect your router to computer with ethernet cable then you can access it with following default link.
    http://192.168.0.1
    or
    http://192.168.1.1
    If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
    Then it ask for user name and password.
    Type user as "admin" and password as "admin" or "password" or blank.
    Then you can see configuration page of router.
    Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
    You can also find SSID to set network name in wireless settings.
    Then you can connect your wi fi network with that code.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    Jun 02, 2010 | Gateway Wireless-B Router (wbr-100)
    Cant get out thru the gateway to the internet. it keeps asking for a password to get out to the internet. we have already set up the SSID and can connect to the router but have no intenet access
    First connect your router to computer with ethernet cable.
    Then you can access it with following link
    http://192.168.1.1
    or
    http://192.168.0.1
    type user as "admin" and password as "admin" or blank or "password"
    then go to wi fi security set your WEP code it is your security key to connect wi fi network.
    Change it and then save settings and restart router.
    Let me know if you need more assistance.
    Thanks
    Oct 22, 2009 | Kyocera Mobile Router KR2
    Problems with wireless
    hi dear
    try this
    1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
    2. Ensure you have a firewall program installed and running. This will protect your data.
    3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
    4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
    6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
    8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
      • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
      • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
    9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
    11. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
    There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
    oke post in me back
    i hope this usefull for you
    thanks
    cropp
    Mar 23, 2008 | Computers & Internet
    Computers & Internet Logo
    24 people viewed this question
    David Payne
    David Payne
