Question about Garmin nuvi GPS
I have old garmin nuvi sat nav and when I use car charger it goes in to charging mode and would not display any map
Cannot find model number
  • Garmin Master
  • 2,130 Answers
Broken/loose USB jack is the cause of the problem. Seen it many times. The connector either needs to be replaced or resoldered. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
Posted on Apr 19, 2013
  • 1111 Answers
SOURCE: My garmin nuvi 360 goes in simulated driving mode
if you recently plotted a course and used the simulation mode, it will stay there either till you deactivate it, or you arrive at the destination. go to the simulation mode and see if its in simulation, if so, stop it.
Posted on Aug 06, 2009
SOURCE: Update for Garmin nuvi 200
I just got a Garmin Nuvi 660 and cannot figure out how to charge the unit. Help!!!!
Posted on Aug 13, 2009
SQUIRESXX
  • 486 Answers
SOURCE: My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Posted on Dec 19, 2009
  • 638 Answers
SOURCE: what is the OS of Garmin Nuvi 205 Sat Nav
No, Garmin units are set to proprietary mapping so you have to use Garmin or Garmin-compatible maps.
Posted on Jan 04, 2010
SOURCE: LOOKING TO GET FREE MAP UPDATES FOR MY GARMIN NUVI 250
there is no such a thing as free map update,unless there was a special offer on when you bought your Garmin.
In order to register your product,go to this address:
https://my.garmin.com/mygarmin/marketing/register.htm
Posted on Jan 26, 2010
Hi! I bought Garmin 265W sat nav with full EU mapping. Are the EU maps preloaded or do I have to download them from the internet myself? There was nothing in the pack (apart of course charger, nav unit,...
The maps are preloaded. If you want to see what maps are on it press TOOLS (the spanner symbol)
Then press SETTINGS (or LOCALE if your model does not have SETTINGS)
Then press MAPS
Then press MAP INFO
The name of the map installed on your satnav should be shown there
Oct 12, 2010 | Garmin Nuvi 265WT 43Inch Widescreen...
Can i download free maps for my 2year old garminnuvi200 satnav and from which site
You can update mapping software on most sat nav units to take into account alterations to the road network. Either from your PC, in the case of portable sat navs; or via your phones GPRS connection, in the case of phone models. Always check the level of mapping that comes with your equipment in the first place. Is it up-to-date?
. Every couple of years Garmin will release a map update, which you can get on DVD or download - you've got to pay for it though!
Oct 18, 2009 | Garmin nuvi 200W GPS Receiver
I've got a RAC Sat Nav,it takes cver 20 mins to get signal,help
make sure the batteryb is fully charged by AC charger not car charger which is only a mani\tenance charge
Oct 17, 2009 | Garmin Nuvi 760 Car GPS Receiver
Nuvi 250 will not turn on when charging.
There are two types of leads that you can buy.
The one supplied with the Garmin expects you to plug the GPS into the PC via the USB and if you use this to try and charge your Garmin in your car it will think it is connected to the PC and show the connection screen. it will charge the unit but you can't see the map.!!!
Make sure that you buy a lead specially for the Garmin for use in the car its the only type of SAT NAV that you will have this problem with.
LOL
Sep 12, 2009 | Garmin nuvi 250W GPS Receiver
Garmin 350 cannot charge and nav at the same time
Your battery is faulty. Did it come with an AC Charger? Ac chargers do a better job than the car Dc which really only manages to maintain a reasonable level of input. i suspect your internal batter is critical and either needs a thorough charge or replacement
Jul 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
Jul 17, 2009 | Garmin Nuvi 660 GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Don't Want to Buy the Updated Maps (nuvi 200W)
If the PC icon comes up while using the car charger, then there is a problem with your charger or mini-USB port on your Nuvi. Many after market chargers are not wired the same, causing the PC icon to show up on the screen. In this mode, your Nuvi will not charge nor can you use your Nuvi for navigation.
You can use your Nuvi with old maps. No one says you have to update. You'll just get an occasional reminder that your maps are outdated.
- Jim
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Charging while driving(using the cigar plug)
I too just got mine from Santa... it's designed to operate while plugged into the lighter. It also charges the Li ion battery. If the Garmin screen comes on while you are using it I would suspect an error or what ever. (you DID move the little switch on the top left corner to unlock didn't you?) Just call their number 800 800-1020 and ask them. They were most helpful and were there well after the hours posted in the instruction book.
Jan 03, 2009 | Garmin nuvi 250W GPS Receiver
GPS Logo
46 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
