Question about Palm Tungsten T3 Handheld
Need Screws for T3
Where can I get screws for he TungstenT3. All 4 have now come out. This Seems to have been a problem with the T3.
  • 170 Answers
I have no stake in this website, it was just the first on that popped up:
http://www.freescreenprotectors.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PA1694&Category_Code=PDA-Parts-and-Accessories&Store_Code=FSP&Affiliate=froogle
you might even just check out your local Hardware store
also get you some loctite and make sure they don't com out again....
If this helps please rate my solution...
Thanks,
David
Posted on Mar 11, 2009
Honda odyssey 2010 fender - how to remove driver side fender
Need to remove mirror this will allow you to remove the part behind mirror. You ?lso need to remove headlight assembly allowing the screws behind to be removed
Mar 22, 2016 | 2010 Honda Odyssey
How to remove rear door panel on 1986 crown victoria
Typically, there are a few hidden screws right on the arm rest/grab handle. There may be a few hole plugs that need to be removed to access the screws.
After all of the screws are removed, pull the panel away from the door slightly to release it from the push pins, then lift up slightly and it should come off.
May 12, 2014 | 1986 Ford Crown Victoria
Water is not hot
If your water has NO hot water, then click circuit breaker
Next, click red reset button.
Turn off power.
Open cover on water heater.
If heater has 2 covers, open top cover
After re-seting water heater, insulation must be put back over thermostat to prevent cooler air from affecting thermostat.
1) Reset button is a good starting place to check water heater.
Reset clicks off for a number of reasons, including overheated water.
2) Reset will not reset, then replace thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Resets clicks on, but clicks off again later, you should diagnose the problem.
Clicking reset is not a hazard
Click the reset as often as you want until you have time to diagnose.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
4) Reset is not tripped, and you still do not have hot water:
Then use tester on top two screws (T1 - T3 screws -or- 1 and 3 screws) of upper thermostat to check if you have power.
If you have power, then replace thermostat.
If problems continue, a full diagnosis is needed as per the link above
If you need more help, add a comment and I will respond
Oct 29, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How to install 25amp 3 pole relay
There should be 8 screws on the relay L1, L2, L3, T1, T2, T3 and two additional screws either at the top or bottom, or one on each side. The incomming, constant power in from the circuit breaker, should connect to L1, L2 & L3. The power out to the load should connect to T1, T2 & T3. The control wire from the switch or timer you will be using to close the contactor will connect to the remaining two screws. THE MOST IMPORTANT PART IS THAT THE CONTROL VOLTAGE MATCHES THE COIL VOLTAGE OF THE CONTACTOR. They will make 12vac, 12vdc, 24vac, 24vdc, 120v, 240v, 277v, etc. coils for the contactor.
Also keep in mind that when the contactor closes L1 & T1 make contact, L2 & T2, Etc.
Oct 08, 2009 | Eaton ARC FAULT CIRC BREAKER
Removing the hex screws from the table fan
you need a security bit it will have a small hole in it just for the screws you are trying to remove
Jul 26, 2009 | Honeywell HT-800 Table Fan
Hitachi CP-S225 projector - spec for screws
Hi Brian
The $18 footpiece you will unfortunatelly have to pay if you want the right thing.
As for the screws to mount the bracket onto the Projector , simply look right beside the hole at the bottom. Normally the size screws that you require is printed in the plastic.
Apr 15, 2008 | Office Equipment & Supplies
Repairing razr V3M
more than likle it's loose open it w/a t3 and t6 ad use scotch take to hold it down and also pull up those gray caps they reveal the torx screws
Mar 30, 2008 | Motorola Mobility RAZR V3
KYOCERA SLIDER REMIX FACEPLATE INSTALLATION
I had the same problem and I was lookin on a forum/blog on how to do this,but not many helped.I'm about to attempt to change my faceplate and I noticed when you take the battery cover off,there are 4 screws under the cover,and one near the antenna.You probably have to take apart the back part of the phone to get to the screws that are attatched to the sliding part of the phone.Its probably a little risky and tricky,but Im guessing thats how you get to the 2 hidden screws.
Nov 20, 2007 | Cell Phones
Palm Tungsten T3 Handheld Logo
43 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
