Question about Water Heaters
Ariston water heater the blue part on the water heater where the control switch for the temperture is like the seal part is dripping what could it be thankyou
  • Water Heaters Master
  • 17,093 Answers
Replace the water heater
Posted on May 05, 2013
3 Suggested Answers
  • 5 Answers
SOURCE: Bosch GL4ti Ariston water heater - have no hot
Check if unit has power to the plug. If so, could be bad heater element or bad thermostat. Also could be reset button on thermostat and yes, the reset button is different from on/off switch. Element about $38, thermostat about $30 from www.plumbingsupply.com
Occasionally, the high temperature limit shut off device may trigger and shut the
system down. This occurs when water temperature exceeds 190° F and shuts off
power to the heating element. The shut off device may also trigger from a power
outage or electrical storm.
To reach the thermostat:
1. Pry off the round cover plate (V Fig. 3/1) from its right hand edge (W Fig. 3/1) with
a small flat-head screwdriver.
2. Remove the Phillips screw revealed beneath the round cover plate.
3. The cover (C Fig. 3/1) can now be removed by pulling out its left-hand edge. When
reassembling, work in the opposite way being careful to insert the tongue of the
cover into the slot.
4. Firmly press reset button (B Fig. 4). Reconnect power.
5. IMPORTANT: Check the operation of the thermostat, turn temperature dial from
high to low, if the red light does not go off on low setting, turn off power supply and
call a service person to replace the thermostat.
6. If the system works, place dial setting to desired setting. Note: a lower setting is
more economical and reduces the risk of scalding. Replace cover plate.
CAUTION: Call a technician if the high limit needs to be reset frequently.
PlumbingSupply.com has the Ariston repair parts that you need.
ariston-gl2546components.png Diagram # Model # Description Price & Quantity 2 570241 Anode Rod for GL6 and GL8Ti $13.99 2 574305 New Style Anode Rod for GL2.5 and 4.0 $12.95 3 994147 Element Gasket $11.95 4 994140 Element Locknut - 4 Each Req. Per Element - sold each $2.99 5 994103 Element for GL2.5 and GL4.0 $37.95 5 994104 Element for GL6 $39.97 11 65105602
old #994062 Thermostat for GL2.5 and GL4.0 $29.52 11 65150322
old #994102 Thermostat for GL6 $32.57 GL25-4KIT Element, Element Gasket and Anode Rod Kit - For GL2.5Ti & GL4.0Ti $47.65 GL6-8KIT Element, Element Gasket and Anode Rod Kit - For GL6 & GL8Ti $48.65 Note: If you don't see your number unfortunately it is no longer available
Posted on Jan 14, 2011
SOURCE: we have an ariston pro
The tank is drained by removing tank, and using hot water outlet as a drain.
Under-counter tanks are not made with thick steel hull that adds cost and weight to product.
Water heater can rust out quickly if anode rod is not checked and replaced each year.
Anode rod depletion is faster if home has water softener.
All tank-type water heaters have replaceable anode rod that protects tank from rusting, and most water heater manuals include general description of anode and maintenance.
http://waterheatertimer.org/Replace-anode-rod.html#ariston
Rusted water heater must be replaced.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 06, 2011
Ariston agent singapore
Try this link: http://www.ariston-heater.com.sg/about.html
Jan 10, 2014 | Water Heaters
Ariston water heater service center
Copy following link for Bosch Ariston water heater resources:
http://waterheatertimer.org/Ariston-water-heater-resources.html
You can fix this water heater yourself, or buy another under-counter water heater if tank is leaking because anode depleted.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
Jul 29, 2013 | Water Heaters
Ariston troubleshooting
Copy following link for Ariston water heater resources including manuals, parts and troubleshoot:
Check if element is leaking. Replace water heater.
Jun 19, 2013 | Water Heaters
We have an ariston pro pi water heater and water is dripping all over from the bottom. How do you drain this? It is less thasn 5 years old
Sep 06, 2011 | Bosch GL4Ti Ariston Pro Ti Electric...
My Ariston 4 gallon water heater is given out hot dirty water?... Any Suggestions?
1) Dirty water implies degraded metal inside unit:
The anode rod protects metal parts. Once anode is depleted, metal parts react with water.
2) Open following troubleshoot pdf showing Ariston parts
http://waterheatertimer.org/pdf/How-to-Troubleshoot-Bosch-Ariston-Water-Heater.pdf
3) Ariston manual: Read manual cover to cover, make sure water heater receives yearly maintenance as outline in manual.
http://waterheatertimer.org/pdf/Bosch-GL_English.pdf
4) Information on anode rods
5) For Bosch gas and electric tankless: Open following link for troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
6) Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 02, 2011 | Bosch Ariston GL4 GL4 Point-of-Use...
Ariston GL6 less than two years old. Water does not get hot.
Troubleshoot Ariston GL6 6-gallon
Mar 28, 2011 | Bosch Ariston GL6-plus GL6+ Point-of-Use...
My ariston electric hot water heater keeps tripping off
Tripping off at the water heater or at the breaker box?
Jan 24, 2010 | Bosch GL4Ti Ariston Pro Ti Electric...
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Not able to top up water level on my ariston microgenus 20 MFFI
Julie... I need more information to solve your problem. Such as make and model of your heater.
Ray
Nov 14, 2008 | Water Heaters
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
